12-21-2010 03:25 PM - edited 03-16-2019 02:32 AM
We have recently installed firmware version 9-1-1-SR1S on our Call Manager 4.1 servers for the 7941, 7970, and 7961 phones. All phones that are in production upgraded successfully. The production phones were running version 8-3-5.
However, when trying to upgrade phones that are running earlier versions such as 8-2-1 and 8-3-0, we get an "auth fail" message. Will I need to do multi-step upgrade on these phone to get them upgraded to the latest version. If so, how can I do that?
Solved! Go to Solution.
12-21-2010 04:44 PM
12-21-2010 10:16 PM
Hello Richard,
you need to upload the firmware 8.5.2 to the tftp server and you can define a phone load on the phone to upgrade version 8.5.2.
After all phones have done the upgrade to 8.5.2, you can delete the entry and apply the config. The phone reloads and downloads the version 9.1.1.
You don't need to reupload the firmware 9.1.1.
Kind regards,
Marcel Ammann
12-22-2010 04:33 AM
Yes.
Please remember to rate useful posts clicking on the stars below.
12-21-2010 04:44 PM
12-21-2010 06:25 PM
Does this mean install 8.5.2 on the Call Manager server? Connect the phones to upgrade them to 8.5.2. Then re-install 9.1.1 on the Call Manager then reset the phones to upgrade them to 9.1.1?
12-21-2010 10:16 PM
Hello Richard,
Kind regards,
Marcel Ammann
09-07-2017 03:58 AM
I am trying to switch from SIP to SCCP on my 7970g phones. As our PBX is Asterisk, i am using tftp for that purpose, but getting errors. Everywhere i look, it says that i need version 8-5-2 to do it.
Now usually i go to Cisco downloads and simply download the firmware, but they have closed downloads for 7970g.
Any chance that you've got SCCP 8-5-2 for 7970g lying around? Been searching around without any luck, and is now getting desperate :-(
Thanks!
12-22-2010 04:33 AM
Yes.
05-28-2016 04:27 AM
I have the same issue on CUCM 8.6.2. Several of my 7970 phones stucked on Upgrading step with the same Auth Fail error. I resolved it this way. I downloaded and then uploaded cmterm-7970_7971-sccp.8-2-2SR4.cop.sgn firmware which my phones agreed to upgrade to. But now they don't want to upgrade to cmterm-7970_7971-sccp.8-5-2SR1.cop.sgn.
How to solve this issue?
05-28-2016 05:11 PM
Please stick to your original thread (HERE) so people who are trying to help and trying to find solution don't get confused between this 2011 thread and your thread.
12-22-2010 09:14 AM
Thank you guys!
