AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
1100
Beginner
Re: Auto Attendant in CME
Dear Nipun,
Here is the complete debugs, when i have dialled 3214 (aa pilot) the number is showing on the phone display. After few seconds its automatically getting disconnected without any intimation (fast busy or engage or nothing happening)
Nope still not complete. Same thing as before. Can you not take these in a buffer ? Also increase your client scroll back ? It will hardly take additional couple of minutes.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Beginner
Hi nipun,
I have ran the logs, waited for 2 min. Dialled twice. Please take a look at it.
Make the following changes and then test again -
dial-peer voice 30
no session target ipv4:192.168.1.200
session target ipv4:192.168.1.100
dtmf-relay h245-alphanumeric
Nipun Singh Raghav
Highlighted
Beginner
Dear Nipun,
I have done those changes, find the attached debugs.
What was the behaviour this time ? From the logs I can see that the call was handed off to the service
Mar 13 08:53:30.572: //79/D523057D80E8/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 79 with tag 30 to app "_ManagedAppProcess_aa"
Can you try with a SCCP phone once or maybe try calling in from PSTN ?
Nipun Singh Raghav
Beginner
in the 3905 ip phone when i have dialed the number it shows the number dialed, and then after 2-3 seconds it goes blank.
Did you try from a sccp phone or pstn like I asked in previous post ?
Nipun Singh Raghav
Beginner
Yes still the same with SCCP also
That's strange. I see the service being handed off. It might be an issue with the TCL. Remove the existing configuration for both the queue and AA. I have highlighted the changes in bold -
application
service aa app-b-acd-aa
paramspace english index 1
param number-of-hunt-grps 2
param handoff-string aa
param dial-by-extension-option 1
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 3214
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 700
param service-name queue
service queue app-b-acd
Post the above, do the following -
call application voice load aa
call application voice load queue
Test the calls after this. We basically now use the IOS built-in embedded TCL rather than the ones in the flash.
Nipun Singh Raghav
Content for Community-Ad
August's Community Spotlight Awards
