07-04-2018 10:51 AM - edited 03-17-2019 01:08 PM
I have configured an Auto Attendant Service on an incoming POTS dial peer (bri 0/0/0). There is another incoming POTS dial peer with a completely differerent configured number on it (which actually should be used ba a fax machine), also this dial peer is attached to a different port (bri0/1/0) which is a different WIC module. However, all incoming calls on bri 0/1/0 are also grabbed by the AA Service.
I tried a restart of the router, but with no success.
This is the dial peer for the application service:
dial-peer voice 100 pots
description PSTN
service autoattendant
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
incoming called-number .
supplementary-service pass-through
direct-inward-dial
port 0/0/0
application
service AutoAttendant flash://voiceportal_greece.tcl
param DefaultNumber +302112345678
param Timeout 3
Is this a feature as design? can someone explain this behavior?
Solved! Go to Solution.
07-04-2018 10:55 AM
07-04-2018 10:55 AM
