AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
579
Beginner
Auto attentand in CME 8.6
Hi!
I want to know if is possible configure a IVR in a CME 8.6 with ephones 6921 sccp.
I found the auto attendand feature, but is it possible in cme 8.6? when an incoming call arrives, a locution must indicate for X department press 1, 2 for another and so on, is it possible? and how can i reach this?
Thanks & Regards!!
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Master
Just enter B-ACD/AA in cisco.com search box and you will obtain all the links.
From there you can read and learn how to do the prompts.
5 REPLIES 5
Highlighted
Hall of Fame Master
Yes, that is called B-ACD/AA,
Beginner
Hi!
Could u give me the link to configure it?
And do i need to record previously the messages and copy them ti te flash?
Thanks!!
Hall of Fame Master
Beginner
ok
thanks!!
Hall of Fame Master
Thank you for the nice rating and good luck!
Content for Community-Ad
August's Community Spotlight Awards
