Auto Dialing/Hot Dial option in CP8800 3rd Party Call Control
Using CP-8811 for 3 party call control and registered in Broadsoft v21 sp 1
2 lines are registered on phone. Second line should be use to check the general voice mail.
Message key only dial line one voice mail number.
I want to set up ring down/Hot Dial  to dial voice portal number (9999 or *62 ) as long as pick the VM line.
1 ACCEPTED SOLUTION
Re: Auto Dialing/Hot Dial option in CP8800 3rd Party Call Control
I guess I understand what you are looking for. Change dial plan on Ext 2 to:
(P0 <:9999>)
This should dial out 9999 as soon as you go offhook
5 REPLIES 5
I am not sure if I understand your question. You want two lines registered and use the second line to dial out to just voicemail?
Highlighted
Yes, Second line just dial out the specific number (9999 or *68)  as long as go off hook.
You can configure second line as a speed dial to dial out 9999.
(P0 <:9999>)
This is exactly what i am looking for.
Thank you
Content for Community-Ad
August's Community Spotlight Awards
