03-18-2016 03:46 AM - edited 03-17-2019 06:18 AM
I m facing issue where the requirement is for the Auto fail over for PRI .
We are having 2 Cisco Voice gateway on first VGW TATA PRI was configured & on other VGW Reliance PRI was configured ...we created SIP trunk...& given the priority to TATA trunk over Reliance trunk in Route Group...
is this enough for fail over...i mean if TATA PRI will Down call can automatic go through the Reliance VGW...
or something extra we need to configure.
Solved! Go to Solution.
03-18-2016 03:01 PM
Yes, for outbound it should be sufficient, but remember you do not control inbound as that is telco driven.
Also, you should plan on testing it as you may need to play around with the following service parameters (I always set to FALSE):
Stop routing on unallocated number flag |
Stop routing on user busy flag |
03-18-2016 03:01 PM
03-19-2016 11:26 AM
we done the testing ...& its working as per requirement ...when we shutdown the port from primary VGW of priority PRI...auto failover happen
11-28-2018 01:28 AM
Hi Vijay,
You are using SIP line or PSTN??
