Autoanswer with headset
Paulo Ferreira
it's possible to enable/disable the beep when we have the phone with autoanswer with headset?
Paulo Ferreira
Deepak Rawat
Did you check the Ring Setting option on the DN level and see if that helps.
Deepak
Hello Deepak,
thanks for you answer.
I check that option without success, the only options available are: disable, flash only, ring once, ring.
Paulo Ferreira
Hi Paulo,
What is the make and model of headset you're using?
-Drew Merritt
