213
Highlighted
Beginner
Autoanswer with headset
it's possible to enable/disable the beep when we have the phone with autoanswer with headset?
Paulo Ferreira
3 REPLIES 3
Highlighted
Did you check the Ring
Did you check the Ring Setting option on the DN level and see if that helps.
Deepak
Highlighted
Beginner
Hello Deepak,
Hello Deepak,
thanks for you answer.
I check that option without success, the only options available are: disable, flash only, ring once, ring.
Paulo Ferreira
Highlighted
Hi Paulo,
Hi Paulo,
What is the make and model of headset you're using?
-Drew Merritt
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
