Automatically get enduser.csv from CallManager
wizzard344
Greetings!
I have created directory xml service, which using enduser.csv as data source created through the "Bulk administration > Export" feature on my call manager. Everything works well, but I don't like this complicated way  of getting enduser.csv. Maybe I can get this file using some script or built-in feature I never knew about? Or even access callmanager database directly, but which credentials can be used for this?
Directory in my comany is updated often and I don't want to waste 5 minutes on this every day.
Call manager - 10.5.1.100000-7 unrestricted
​Thanks.
Jaime Valencia
You could possibly look into AXL for this, or running SQL queries from a separate server on which you process the information.
java
if this helps, please rate
I was thinking about running SQL queries, but how? Which account should be used to access database? I will check tomorrow if default admin can do this, but I'm not sure about this.
The OS admin account created during install, or any other OS accounts you have created can do that.
java
