Autoprovisioning cisco 8865 with broadsoft
jorge.silva
Iwant to autoprovisioning a cisco 8865 with broadsoft but need the 3pcc firmware when will it be available the firmware to upgrade?
7 Replies 7
I definitely could not upload the firmware to this device
R0g22
ok to install the firmware as I must do it because the web does not give me anything option
this is the web interface screen and I can not do anything or update it and on the tftp
server it asks me for these files
Feb 13 17:51:50 tftpserver in.tftpd[29165]: sending NAK (1, File not found) to 172.16.6.200
Feb 13 17:51:52 tftpserver in.tftpd[29166]: RRQ from 172.16.6.200 filename ITLSEPF8A5C5EB1FB5.tlv
Feb 13 17:51:52 tftpserver in.tftpd[29166]: sending NAK (1, File not found) to 172.16.6.200
Feb 13 17:51:53 tftpserver in.tftpd[29167]: RRQ from 172.16.6.200 filename ITLFile.tlv
Feb 13 17:51:53 tftpserver in.tftpd[29167]: sending NAK (1, File not found) to 172.16.6.200
Feb 13 17:51:54 tftpserver in.tftpd[29168]: RRQ from 172.16.6.200 filename SEPF8A5C5EB1FB5.cnf.xml
Feb 13 17:51:54 tftpserver in.tftpd[29168]: sending NAK (1, File not found) to 172.16.6.200
Feb 13 17:51:55 tftpserver in.tftpd[29169]: RRQ from 172.16.6.200 filename XMLDefault.cnf.xml
Feb 13 17:51:57 tftpserver in.tftpd[29170]: sending NAK (1, File not found) to 172.16.6.200
Feb 13 17:51:57 tftpserver in.tftpd[29170]: RRQ from 172.16.6.200 filename AppDialRules.xml
in broadsoft there are still no autoprovisioning
files of this model, where I can download the templates
of the files that you request??
In the tftp put the file in the cisco 8865 but send me a this error in the web log of the phone
mising file sip8845_65.certmfg
from where can i download it?
=CTL_Signature=Not InstalledCTL_TFTP_Server=N/AITL_Signature=Not InstalledITL_TFTP_Server=N/AStatusCode=6
    [3:29:00pm 02/14/18] DeviceImageDownloadStart DeviceName=SEPF8A5C5EB1FB5 IPv4Address=172.16.6.62 IPv6Address= Active=sip8845_65.11-0-1SR1-2 RequestedLoadId=sip8845_65.11-1-1MPP-897
    [3:29:05pm 02/14/18] DeviceImageDownloadFailure DeviceName=SEPF8A5C5EB1FB5 IPv4Address=172.16.6.62 IPv6Address= Method=2 FailureReason=3 Active=sip8845_65.11-0-1SR1-2 Inactive=sip8845_65.certmfg-20141103 FailedLoadId=sip8845_65.11-1-1MPP-897 Server=10.255.241.177
Hi , i solve this whit the cisco multiplatform new firmware
Regards an Thank you very much for the help
