02-04-2015 08:33 AM - edited 03-17-2019 01:50 AM
Has anybody figured out if the Avaya 1200E sip phone can operate behind a CUCM as a regular desk phone??
02-05-2015 05:33 AM
as a concept you can add it as third party sip phone (basic or advanced)
it is better to test it before purchasing.
Anas
don't forget to rate the helpful posts
06-05-2015 08:20 AM
Right now I have a 1608 I'm testing with, but I can't get it to register. It hangs at "Discover x.x.x.x" where x.x.x.x is the CUCM ip address.
It seems like I should have to set some information in the device related to sip domains, etc. but I don't see documentation for that. The other possibility is it may need a file on the CUCM tftp that it can pull for more settings, but I'm not sure what format that file would be in.
