B-ACD AA not working
J_Vansen_S
Level 3
Level 3
Hi All,
I am currently using the CCME10 on ISR2911
Ive been trying to configure and figure out the B-ACD and AA. But i still couldnt get it to work.
Tried incoming call from the FXO, nothing happens, it just keeps ringing and not pass to any auto attendant
By dialing 6000 from my local IP Phone, nothing happens either.
Below is my sample config
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
  paramspace english index 1
  param number-of-hunt-grps 2
  param handoff-string aa
  param dial-by-extension-option 1
  paramspace english language en
  param aa-pilot 6000
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 700
  param service-name queue
service queue flash:app-b-acd-3.0.0.2.tcl
  param queue-len 15
  param aa-hunt3 1112
  param queue-manager-debugs 1
  param aa-hunt2 1111
interface GigabitEthernet0/1.100
description VOIP-LAN
encapsulation dot1Q 100
ip address 192.168.100.254 255.255.255.0
voice-port 0/0/0
voice-port 0/0/1
sccp ccm 192.168.100.254 identifier 1 version 7.0
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 1000 voip
destination-pattern 1..
session target ipv4:192.168.100.254
dial-peer voice 6000 voip
service aa
destination-pattern 6000
incoming called-number 6000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 100 pots
service aa
port 0/0/0
forward-digits all
telephony-service
protocol mode ipv4
no auto-reg-ephone
max-ephones 25
max-dn 50
ip source-address 192.168.100.254 port 2000
max-conferences 22 gain -6
moh "en_bacd_music_on_hold.au"
multicast moh 239.1.1.1 port 2000
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 6000 blind
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  octo-line
number 111
ephone-dn  2  octo-line
number 112
ephone-dn  3 octo-line
number 113
ephone-dn  4 octo-line
number 114
ephone-hunt 1 sequential
pilot 1111
list 112, 113, 114
ephone-hunt 2 sequential
pilot 1112
list 111
I ran a debug application script: below is my results
*Mar  3 09:42:16.167: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Warning: Mandatory parameter aa-pilot2 does not exist --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Warning: If you are using 2nd pilot number call will fail --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- ERROR: Mandatory parameter voice-mail does not exist --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- max-extension-length is set to default value of 5 --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Valid mandatory parameter second-greeting-time = 60 --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Valid mandatory parameter call-retry-timer = 15  --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Valid mandatory parameter max-time-call-retry = 700  --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Mandatory parameter max-time-vm-retry does not exist --
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Setting default to 1
*Mar  3 09:42:16.171: //98//TCL :/tcl_PutsObjCmd: TCL AA: -- Valid Mandatory parameter number-of-hunt-grps = 2 --
any slightly of help/pointers appreciated. Not too sure if i actually missed anything out
Please advise
chrisinternet
this line sounds bad:
try :
param voice-mail 1000 (or a free DN)
even if you don't have voice-mail...
and this line in your configuration
don't you have a folder named "bacdprompts" ? in this case
try
paramspace english location flash:/bacdprompts/
Christophe.
chrisinternet
try :
try
Christophe.
Oh my! u saved my DAY!
Geez! just that one command WORKS! im hearing audio prompts now
alright, never did doc mentioned a must to input voice-mail param, even if i dont have voice-mail
anyway Thanks!
