01-31-2011 06:44 AM - edited 03-16-2019 03:10 AM
Hi all,
I do not have enough experience in B-ACD and I need to know if I can implement the following:
1- allow dial-by-extension directly
2- Integrate with CUCM rather than CME where the huntgoup number will be extension to an IP phone
Solved! Go to Solution.
01-31-2011 03:43 PM
Here you go...
Sample
telephony-service
no auto-reg-ephone
max-ephones 1
max-dn 1 no-reg both
ip source-address 14.160.126.77 port 2000
moh flash:/BACD/BACD/en_bacd_music_on_hold.au
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 21 2010 15:30:45
01-31-2011 10:46 AM
One more question:
Is there any difference between: app-b-acd-aa-3.0.0.2.tcl and app-b-acd-aa-2.1.2.2.tcl. I found this in running project but I did not understand why?
service aa flash:app-b-acd-aa-2.1.2.2.tcl
service fr flash:app-b-acd-aa-3.0.0.2.tcl
service en flash:app-b-acd-aa-3.0.0.2.tcl
it is for two languages one french and another English.
But why 3 aa not 2 and why to use 2.1.2.2 and 3.0.0.2 ????
01-31-2011 01:22 PM
Sample Conig ######################## voice service voip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip no supplementary-service h225-notify cid-update application service queue flash:BACD/BACD/app-b-acd-3.0.0.2.tcl param queue-len 15 param aa-hunt10 3002 param aa-hunt1 3333 param number-of-hunt-grps 2 param queue-manager-debugs 1 ! service aa flash:BACD/BACD/app-b-acd-aa-3.0.0.2.tcl paramspace english index 1 param number-of-hunt-grps 2 param dial-by-extension-option 3 param handoff-string aa paramspace english language en param max-time-vm-retry 2 param aa-pilot 3500 paramspace english location flash:BACD/BACD/ param second-greeting-time 60 param welcome-prompt _bacd_welcome.au param call-retry-timer 15 param voice-mail 5003 param max-time-call-retry 90 param service-name queue ! service CCM http://14.160.122.102:8080/ccmivr/pages/IVRMainpage.vxml ! service aadropthru1 flash:BACD/BACD/app-b-acd-aa-3.0.0.2.tcl paramspace english index 1 param aa-pilot 3501 param number-of-hunt-grps 1 param handoff-string aadropthru1 paramspace english language en ====> sets language param welcome-prompt _bacd_welcome.au param call-retry-timer 15 param service-name queue paramspace english location flash:BACD/BACD/ param drop-through-option 2 param second-greeting-time 60 param max-time-vm-retry 2 param voice-mail 5003 param max-time-call-retry 90 ! ! dial-peer voice 222 voip service aa =====> Defined Above as service aa flash:BACD/BACD/app-b-acd-aa-3.0.0.2.tcl
destination-pattern 3500 session target ipv4:5.5.5.5 incoming called-number 3500 dtmf-relay h245-alphanumeric codec g711ulaw no vad ! dial-peer voice 223 voip service aadropthru1 destination-pattern 3501 session target ipv4:5.5.5.5 incoming called-number 3501 dtmf-relay h245-alphanumeric codec g711ulaw no vad ! telephony-service no auto-reg-ephone max-ephones 20 max-dn 10 no-reg both ip source-address 14.160.126.77 port 2000 auto assign 1 to 10 network-locale ES network-locale 1 ES network-locale 2 ES network-locale 3 ES network-locale 4 ES time-zone 28 time-format 24 date-format dd-mm-yy max-conferences 8 gain -6 moh flash:/BACD/BACD/en_bacd_music_on_hold.au web admin system name cisco secret 5 $1$V2ln$Dl/cZL3x.UODkfm2k62kc/ dn-webedit time-webedit transfer-system full-consult create cnf-files version-stamp 7960 Nov 21 2010 15:30:45 voice hunt-group 1 peer list 3001,3002 timeout 5 hops 2 pilot 3333
I am sure you can integrate this with CUCM :-)
2.1.2.2 and 3.0.0.2 are version numbers.
PS: Rate only useful posts :-)
01-31-2011 02:37 PM
Thank you too much for your help,
but what I mean is there any technical point to use two version in the same project?
2.1.2.2 and 3.0.0.2
01-31-2011 02:39 PM
Don't think so. I would just use the latest
01-31-2011 03:11 PM
Hi I have the following configuration but it is not working with me:
voice service voip
sip
registrar server expires max 1200 min 300
application
service queue flash:app-b-acd-2.1.2.3.tcl
param aa-hunt3 1004
param queue-len 10
param aa-hunt4 2222
service aa flash:app-b-acd-aa-2.1.2.3.tcl
param menu-timeout 6
param dial-by-extension-option 6
param max-extension-length 4
param aa-pilot 4500
param voice-mail 5000
param max-time-call-retry 600
dial-peer voice 2000 voip
service aa
destination-pattern 4500
session target ipv4:10.30.20.254
incoming called-number 4500
codec g711ulaw
no vad
dial-peer voice 2001 voip
destination-pattern 100.
session target ipv4:10.10.10.10
codec g711ulaw
no vad
When I am pressing 3 What I understand I should be forwarded to 1004 because I used this command:
param aa-hunt3 1004
but once I am pressing 3 the call disconnect
if I presed 6 >> param dial-by-extension-option 6 then press 1004 the call complete
any advise?
01-31-2011 03:25 PM
Do a
debug voip capi inout
debug voip dial-peer
Get it when the call fails
show ver
show run
of the gateway...
01-31-2011 03:27 PM
I tried this but ccapi disconnect cause 16= Normal disconnect
show version:
c2800nm-adventerprisek9-mz.124-20.T2.bin
01-31-2011 03:30 PM
Do you have MOH configured under telephony-service. Experience tells me
its mandatory. plus under the debugs do you see the right outbound
dial-peer being matched?
01-31-2011 03:34 PM
Regarding the output dial-peer yes it is matching the proper dial-peer.
I did not configure the moh because I am using B-ACD with CUCM not with CUCME
01-31-2011 03:37 PM
Just try configuring the MOH :-)... I have a gut feeling thats the
missing part of the puzzle ...
01-31-2011 03:39 PM
how I can configure the moh and no CME?
do you mean configure MOH as Multicast or just add the MOH in flash memory and in the service
01-31-2011 03:43 PM
Here you go...
Sample
telephony-service
no auto-reg-ephone
max-ephones 1
01-31-2011 03:54 PM
thank you man
nice end with nice music
thank you too much
but I have some questions if you do not mind
what is the aim of this command ( in the configuration you posted before)
and if you can give more information about drop through
01-31-2011 03:58 PM
Haha :-)... I went thru pain figuring this out the first time :-)...
Forget about this. service CCM
http://14.160.122.102:8080/ccmivr/pages/IVRMainpage.vxml. its for MVA
PS: Its time to like all useful posts
