B-ACD CUE front end and SIP trunk
gcrisenbery
I am having trouble getting b-acd to work with unity express. When I dial the pilot number for B-ACD from an internal phone it works fine, however when dialing the CUE AA from internal or over our SIP trunk the call disconects when selecting the option that transfers to B-ACD, any pointers? Here is the relevant config.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
application
service app-b-acd-aa
  paramspace english index 1
  param voice-mail 4044
  param queue-exit-extension1 4061
  param service-name app-b-acd
  param number-of-hunt-grps 1
  param drop-through-option 1
  paramspace english language en
  param handoff-string app-b-acd-aa
  paramspace english location flash:
  param aa-pilot 4081
  param queue-overflow-extension 4061
  param queue-exit-option1 0
service app-b-acd
  param aa-hunt1 4080
dial-peer voice 51 voip
description cue autoattendant
destination-pattern 5743060212
session protocol sipv2
session target ipv4:192.168.3.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 4081 voip
destination-pattern 4081
session target ipv4:192.168.1.5
incoming called-number 4081
dtmf-relay h245-alphanumeric
codec g711ulaw
I know I am probably missing a step or two here so let me know. Thanks.
10 Replies 10
gcrisenbery
Interestingly enough if I create a ephone-dn witht the
number 4082 that forwards all to 4081 (B-ACD pilot) and have CUE transfer to that dn it works, however I cannot get CUE to transfer directly to B-ACD it rings the hunt group but as soon as the call is picked up it drops, I am thinking transfer issue between CUE and B-ACD but am unsure how to fix it. Thanks for your help.
The call from CUE to BACD is technically a SIP to H323 call, so you need to have:
voice service voip
If the call still fails, get:
debug voip ccapi inout
debug ccsip all
-Steve
Incorrect, CUE can call B-ACD over pure SIP, no H.323 involved.
Contrary to some believing, "internal" call handling in IOS is NOT h323, but a protocol indipendandt set of API.
Want proof? Enable "debg cch323" and check yourself - no ouptut.
gcrisenbery
Here is the debug when testing this internally, didn't get the entire call in here (missd out on the beginning) but the part where is disconnects is inluded.
Content-Length: 0
Allow-Events: refer
Allow-Events: telephone-event
Allow-Events: message-summary
046464: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
046465: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
046466: Aug  6 08:37:13.777 EDT: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x4A456DFC) on SCB(0x4E73840C)
046467: Aug  6 08:37:13.777 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
046468: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 2
046469: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A456DFC) from EDB(0x4E409BBC)
046470: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A456DFC) for reuse
046471: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
046472: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Info/sipSPISendBye: Associated container=0x4D90716C to Bye
046473: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
046474: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
046475: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPITransportSendMessage: msg=0x4E8286C4, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x4193AD70
046476: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
046477: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
046478: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E8286C4
046479: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E8286C4, addr=192.168.3.2, port=5060, connId=3 for UDP
046480: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
046481: Aug  6 08:37:13.777 EDT: //4394/26E4DF80A0C3/SIP/State/sipSPIChangeState: 0x4A446E28 : State change from (STATE_RECD_XFER, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
046482: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
046483: Aug  6 08:37:13.777 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
046484: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
046485: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
046486: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:4025@192.168.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~2590
Max-Forwards: 70
To: <4025>;tag=F765824-1037
Call-ID: 282DDB5B-A08E11DF-A0C8A2EC-4EA10D61@192.168.3.1
CSeq: 4 BYE
Content-Length: 0
Contact: <5743060212>
046487: Aug  6 08:37:13.777 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
046488: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4A446E28
046489: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
046490: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 34288, Transport 1, SentBy Port 5060
046491: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
046492: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 34288, Transport 1, SentBy Port 5060
046493: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
046494: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPITransportSendMessage: msg=0x4E4556AC, addr=192.168.3.2, port=34288, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x0
046495: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
046496: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
046497: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E4556AC, addr=192.168.3.2, port=5060, connId=0 for UDP
046498: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
046499: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
046500: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~2591
Max-Forwards: 70
CSeq: 5 SUBSCRIBE
Content-Length: 0
Expires: 0
Event: refer
046501: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
046502: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 282DDB5B-A08E11DF-A0C8A2EC-4EA10D61@192.168.3.1F765824-1037
046503: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 282DDB5B-A08E11DF-A0C8A2EC-4EA10D61@192.168.3.1F765824-1037
046504: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
046505: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
046506: Aug  6 08:37:13.781 EDT: //4394/26E4DF80A0C3/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 1
046507: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A4575E0
046508: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBServerMarker: Server TCB's Marker Updated to: 5SUBSCRIBEz9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~2591
046509: Aug  6 08:37:13.781 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBResponseInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Transport 1, SentBy Port 5060
046510: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: TCB 0x4A4575E0's parent is 0x4E73840C
046511: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBLastRequest: TCB(0x4A4575E0) has claimed possesion of lastReq (0x4DA19E70)
046512: Aug  6 08:37:13.785 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
046513: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A4575E0) on EDB(0x4E409BBC)
046514: Aug  6 08:37:13.785 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 2 TCB's on tcbQ
046515: Aug  6 08:37:13.785 EDT: //0/000000000000/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: ccsip_api_resubscribe_ind returned: SIP_FAILURE
046516: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
046517: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: TCB 0x4A4575E0's method is 112
046518: Aug  6 08:37:13.785 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A4575E0) has claimed possesion of package (0x4E5DE1EC)
046574: Aug  6 08:37:13.817 EDT: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting Client EDB flag
046575: Aug  6 08:37:13.817 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 2 EDBs on edbQ
046576: Aug  6 08:37:13.817 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x4E883228)
046577: Aug  6 08:37:13.817 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x4E883228) for reuse
046578: Aug  6 08:37:13.817 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
046579: Aug  6 08:37:19.962 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_call_connected:
   Interface=0x4AB7B9E8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
046580: Aug  6 08:37:19.962 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
046581: Aug  6 08:37:19.966 EDT: //4396/2C6A77A0A0C9/CCAPI/ccDisassociateStream:
   Record Context=0x0, Stream Call Id=4399, Call Id=4396
046582: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/CCAPI/ccDisassociateStream:
   Call Entry(Stream Status=1, Digit Enable=FALSE)
046583: Aug  6 08:37:19.970 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISASSOCIATE
046584: Aug  6 08:37:19.970 EDT: //4396/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x481F790C, callID1=0x112C, callID2=0x112E, tag=0x0)
046585: Aug  6 08:37:19.970 EDT: //4396/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x481F790C, callID1=0x112C, gcid=4767B6AF-12A1000-40000011-25C, tag=0x0)
046586: Aug  6 08:37:19.970 EDT: //4398/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x481F790C, callID2=0x112E, gcid=4767B6AF-12A1000-40000011-25C, tag=0x0)
046587: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/CCAPI/ccConferenceCreate:
   Conference Id=0x481F790C, Call Id1=4396, Call Id2=4398, Tag=0x0
046588: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_bridge: confID = 1016, srcCallID = 4396, dstCallID = 4398
046589: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 4396/4398
046590: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=4396
046591: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
046592: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1087774392, ccb xmitFunc = 1087774392
046593: Aug  6 08:37:19.970 EDT: //4396/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
046594: Aug  6 08:37:19.970 EDT: cc_api_get_xcode_stream : 4548
046595: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
046596: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPIProcessRtpSessions: No active streams.
046597: Aug  6 08:37:19.970 EDT: //4396/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x3F8, Source Interface=0x49851458, Source Call Id=4396,
   Destination Call Id=4398, Disposition=0x0, Tag=0x0
046598: Aug  6 08:37:19.970 EDT: //4398/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x3F8, Source Interface=0x4AB7B9E8, Source Call Id=4398,
   Destination Call Id=4396, Disposition=0x0, Tag=0xFFFFFFFF
046599: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_generic_bridge_done:
046600: Aug  6 08:37:19.970 EDT: //4396/2C6A77A0A0C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x3F8, Destination Call Id=4398)
046601: Aug  6 08:37:19.970 EDT: //4398/2C6A77A0A0C9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x3F8, Destination Call Id=4396)
046602: Aug  6 08:37:19.970 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49851458, Destination Call Id=4396, Source Call Id=4398,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=3)
046603: Aug  6 08:37:19.974 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
046604: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: Entry
046605: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: Negotiation not done yet:: Load DSP with preferred codec : g711ulaw, Bytes=160, payload: 0
046606: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
046607: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
046608: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=4398
046609: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
046610: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
046611: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_set_modem_caps: Negotiation NOT yet Done. Set the configured values and generate SDP Xcap list
046612: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
046613: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sip_set_modem_caps: nse payload = 100, ptru mode = 0, ptru-codec=0, redundancy=0, xid=1, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
046614: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
046615: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
046616: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
046617: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
046618: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
046619: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
046620: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x203
046621: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
046622: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4AB7B9E8, Destination Call Id=4398, Source Call Id=4396,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
046623: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_api_caps_ind:
046624: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ind: Calling cc_api_caps_ack()
046625: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=7581)
046626: Aug  6 08:37:19.974 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_caps_ack:
046627: Aug  6 08:37:19.974 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
046628: Aug  6 08:37:19.978 EDT: //4398/2C6A77A0A0C9/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=4398
046629: Aug  6 08:37:19.978 EDT: //4396/2C6A77A0A0C9/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=4396
046630: Aug  6 08:37:19.978 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
046631: Aug  6 08:37:19.978 EDT: //4396/2C6A77A0A0C9/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=20069
046632: Aug  6 08:37:19.978 EDT: //4398/2C6A77A0A0C9/CCAPI/ccSaveDialpeerTag:
   Incoming Dial-peer=4081
046633: Aug  6 08:37:19.982 EDT: //4396//TCL :/tcl_PutsObjCmd:
proc act_CallSetupDone
046634: Aug  6 08:37:19.982 EDT:
046635: Aug  6 08:37:19.982 EDT: //4396//TCL :/tcl_PutsObjCmd:
IP IVR Leg Setup Status = ls_000
046636: Aug  6 08:37:19.982 EDT:
046637: Aug  6 08:37:19.982 EDT: //4396//TCL :/tcl_PutsObjCmd: TCL AA: >> Call answered by the agent; Call Connected <<
046638: Aug  6 08:37:19.982 EDT: //4396//TCL :/tcl_PutsObjCmd: TCL AA: >>> Incoming LEG ID = 4396 4393; Outgoing LEG ID = 4398 <<<
046639: Aug  6 08:37:19.982 EDT: //4396/2C6A77A0A0C9/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
046640: Aug  6 08:37:19.982 EDT: //4396/2C6A77A0A0C9/CCAPI/ccCallHandoff:
   Silent=FALSE, Application=0x492633E8, Conference Id=0xFFFFFFFF
046641: Aug  6 08:37:19.982 EDT: //4398/2C6A77A0A0C9/CCAPI/ccCallHandoff:
   Silent=TRUE, Application=0x4EAB219C, Conference Id=0xFFFFFFFF
046642: Aug  6 08:37:19.982 EDT: //4393/26E4DF80A0C3/CCAPI/ccCallHandoff:
046643: Aug  6 08:37:19.986 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 15
046644: Aug  6 08:37:19.986 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
046645: Aug  6 08:37:19.986 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPreProcessCallerIDMediaEvent: Updated Connected Party Name: Zak Wolfinger Updated Connected Party Number: 4026 Updated Connected Party Oct3a: 0x00
046646: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '4081' with callid: 4396
046647: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/SIP/Info/act_handle_app_media_event: method = 109 state = 7
046648: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/SIP/Info/act_handle_app_media_event: Received media sip event SIP_REQUEST_OFFER
046649: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPICacheEvent: Clear UPDATE flags
046650: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/SIP/Error/sact_app_media_event_send_request: Cannot send UPDATE without calling ccsip_api_update_allowed
046651: Aug  6 08:37:19.986 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x3F8, Call Id1=4396, Call Id2=4398
046652: Aug  6 08:37:19.990 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_voice_mode_event:
   Call Id=4398
046653: Aug  6 08:37:19.990 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x480564E4)
046654: Aug  6 08:37:19.990 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Time to Answer = 6 Seconds<<<
046655: Aug  6 08:37:19.994 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_4926FFFC_0_259421180 {CALL_HANDOFF} {1281098239}} <<<
046656: Aug  6 08:37:19.994 EDT: //4396/2C6A77A0A0C9/CCAPI/ccConferenceDestroy:
   Conference Id=0x3F8, Tag=0x0
046657: Aug  6 08:37:19.994 EDT: //4396/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
046658: Aug  6 08:37:19.994 EDT: //4398/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=4396, Disposition=0x0, Tag=0x0
046659: Aug  6 08:37:19.994 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_generic_bridge_done:
046660: Aug  6 08:37:19.994 EDT: //4393/26E4DF80A0C3/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
046661: Aug  6 08:37:19.994 EDT: //4393/26E4DF80A0C3/CCAPI/ccCallDisconnect:
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
046662: Aug  6 08:37:19.994 EDT: //4393/26E4DF80A0C3/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
046663: Aug  6 08:37:20.002 EDT: //4393/26E4DF80A0C3/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x4AB7489C, Call Id=4393
046664: Aug  6 08:37:20.026 EDT: //4393/26E4DF80A0C3/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4AB7489C, Tag=0x0, Call Id=4393,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
046665: Aug  6 08:37:20.026 EDT: //4393/26E4DF80A0C3/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
046666: Aug  6 08:37:20.026 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046667: Aug  6 08:37:20.026 EDT: :cc_free_feature_vsa freeing 4E9C77E0
046668: Aug  6 08:37:20.026 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046669: Aug  6 08:37:20.026 EDT:  vsacount in free is 6
046670: Aug  6 08:37:20.026 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046671: Aug  6 08:37:20.026 EDT:  vsacount in free is 5
046672: Aug  6 08:37:20.030 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD ++ Service Counter = 36 ++
046673: Aug  6 08:37:20.034 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ 4080 Queue Length = 0 +++
046674: Aug  6 08:37:20.034 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> 4080 Queue Length = 0 <<<
046675: Aug  6 08:37:20.034 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Queue 4080 is Empty <<<
046676: Aug  6 08:37:20.034 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
046677: Aug  6 08:37:20.034 EDT: //4396/2C6A77A0A0C9/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
046678: Aug  6 08:37:20.034 EDT: //4396/2C6A77A0A0C9/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
046679: Aug  6 08:37:20.034 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
046680: Aug  6 08:37:20.034 EDT: //4398/2C6A77A0A0C9/CCAPI/ccCallDisconnect:
046681: Aug  6 08:37:20.034 EDT: //4398/2C6A77A0A0C9/CCAPI/ccCallDisconnect:
046682: Aug  6 08:37:20.034 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_get_transfer_info:
046683: Aug  6 08:37:20.038 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x4AB7B9E8, Call Id=4398
046684: Aug  6 08:37:20.054 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
046685: Aug  6 08:37:20.054 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
046686: Aug  6 08:37:20.054 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
046687: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPISendBye: Associated container=0x4D907C14 to Bye
046688: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
046689: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
046690: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipSPITransportSendMessage: msg=0x4E2F3328, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x4193AD70
046691: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
046692: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
046693: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E2F3328
046694: Aug  6 08:37:20.058 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E2F3328, addr=192.168.3.2, port=5060, connId=3 for UDP
046695: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
046696: Aug  6 08:37:20.058 EDT: //4396/2C6A77A0A0C9/SIP/State/sipSPIChangeState: 0x4A41CB68 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
046697: Aug  6 08:37:20.062 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:5743060212@192.168.3.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK12B910B8
To: <5743060212>;tag=cuefae5ff43
Date: Fri, 06 Aug 2010 12:37:13 GMT
Call-ID: 1281098233519835@192.168.3.2
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1281098240
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
046698: Aug  6 08:37:20.062 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4AB7B9E8, Tag=0x0, Call Id=4398,
046699: Aug  6 08:37:20.062 EDT: //4398/2C6A77A0A0C9/CCAPI/cc_api_call_disconnect_done:
046700: Aug  6 08:37:20.066 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046701: Aug  6 08:37:20.066 EDT: :cc_free_feature_vsa freeing 4E9C7A80
046702: Aug  6 08:37:20.066 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046703: Aug  6 08:37:20.066 EDT:  vsacount in free is 4
046704: Aug  6 08:37:20.066 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046705: Aug  6 08:37:20.066 EDT:  vsacount in free is 3
046706: Aug  6 08:37:20.070 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:34288
046707: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
046708: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
046709: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
046710: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
046711: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
046712: Aug  6 08:37:20.074 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4A41CB68
046713: Aug  6 08:37:20.074 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
046714: Aug  6 08:37:20.074 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
046715: Aug  6 08:37:20.074 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:25942769 ConnTime 25942119
046716: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49851458, Tag=0x0, Call Id=4396,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
046717: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/CCAPI/cc_api_call_disconnect_done:
046718: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046719: Aug  6 08:37:20.078 EDT: :cc_free_feature_vsa freeing 4E9C7B60
046720: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046721: Aug  6 08:37:20.078 EDT:  vsacount in free is 2
046722: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046723: Aug  6 08:37:20.078 EDT:  vsacount in free is 1
046724: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
046725: Aug  6 08:37:20.078 EDT:  vsacount in free is 0
046726: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
046727: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
046728: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/State/sipSPIChangeState: 0x4A41CB68 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
046729: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4A41CB68
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 5743060212
Called Number            : 4081
Source IP Address (Sig  ): 192.168.3.1
Destn SIP Req Addr:Port  : 192.168.3.2:5060
Destn SIP Resp Addr:Port : 192.168.3.2:34288
Destination Name         : 192.168.3.2
046730: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.3.1
Source IP Port    (Media): 16384
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
046731: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
046732: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 112C
046733: Aug  6 08:37:20.078 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[1988] removed.
046734: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
046735: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4A41CB68 key=1281098233519835@192.168.3.24081
046736: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
046737: Aug  6 08:37:20.078 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4A41CB68 key=1281098233519835@192.168.3.2F767408-218C
046738: Aug  6 08:37:20.082 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
046739: Aug  6 08:37:20.082 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIStopRequestPendingTimer: Stopping Request Pending Timer
046740: Aug  6 08:37:20.082 EDT: //4396/2C6A77A0A0C9/SIP/Info/ccsip_qos_cleanup: Entry
046741: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
046742: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_api_initiate_subscription_termination: Server subscription terminate event was already posted.
046743: Aug  6 08:37:20.082 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
046744: Aug  6 08:37:20.082 EDT: //4396/2C6A77A0A0C9/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4A41CB68
046745: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[1988]
046746: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
046747: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
046748: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457124
046749: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457124's parent is 0x4D9D8238
046750: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Port Present: TRUE, Transport 1, FQDN 1154642800
046751: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
046752: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457124's method is 111
046753: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A457124) has claimed possesion of package (0x4EA8161C)
046754: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK12BA1701
046755: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
046756: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457124) on EDB(0x4EAA173C)
046757: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 2 TCB's on tcbQ
046758: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
046759: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A457124 and parent: 0x4D9D8238
046760: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4EA8161C, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41847784
046761: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
046762: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
046763: Aug  6 08:37:20.082 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4EA8161C
046764: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4EA8161C, addr=192.168.3.2, port=5060, connId=3 for UDP
046765: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
046766: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x4A457124) with 10 retries and 500 milliseconds initial retx
046767: Aug  6 08:37:20.082 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x4D909FD4)
046768: Aug  6 08:37:20.086 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
046769: Aug  6 08:37:20.086 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
046770: Aug  6 08:37:20.086 EDT: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting server EDB flag
046771: Aug  6 08:37:20.086 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 2 Transactions still active on Event:telephone-event ID:
046772: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:5743060212@192.168.3.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK12BA1701
CSeq: 103 NOTIFY
Max-Forwards: 70
Date: Fri, 06 Aug 2010 12:37:20 GMT
Event: telephone-event
Subscription-State: terminated
Contact: <4081>
Content-Length: 0
046773: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:34288
046774: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
046775: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
046776: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:4081@192.168.3.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~2587
Max-Forwards: 70
To: <4081>;tag=F767408-218C
CSeq: 3 SUBSCRIBE
Content-Length: 0
Expires: 0
046777: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
046778: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 1281098233519835@192.168.3.2F767408-218C
046779: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 1281098233519835@192.168.3.2F767408-218C
046780: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 1281098233519835@192.168.3.2cuefae5ff43
046781: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromServerTable: Searching for SCB in server table with key 1281098233519835@192.168.3.2cuefae5ff43
046782: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
046783: Aug  6 08:37:20.090 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
046784: Aug  6 08:37:20.090 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 1
046785: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457908
046786: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBServerMarker: Server TCB's Marker Updated to: 3SUBSCRIBEz9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~2587
046787: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBResponseInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Transport 1, SentBy Port 5060
046788: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: TCB 0x4A457908's parent is 0x4D9D8238
046789: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBLastRequest: TCB(0x4A457908) has claimed possesion of lastReq (0x4E9E038C)
046790: Aug  6 08:37:20.094 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
046791: Aug  6 08:37:20.094 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457908) on EDB(0x4EAA173C)
046822: Aug  6 08:37:20.110 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 2 Transactions still active on Event:telephone-event ID:
Too much dialog is missing, it can only be seen the CUE closes with normal cause.
Received:
Max-Forwards:  70
CSeq: 4 BYE
Content-Length:  0
in the future, only take debug ccsip message.
Here is the full debug of an incoming call over the sip line.
Aug 09 07:53:29 192.168.1.5 1: 067278: Aug  9 07:53:28.071 EDT: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (192.168.1.133)
Aug 09 07:53:30 192.168.1.5 2: 067279: Aug  9 07:53:29.071 EDT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 192.168.1.150 port 514 started - CLI initiated
Aug 09 07:53:41 192.168.1.5 3: 067280: Aug  9 07:53:40.359 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
Aug 09 07:53:42 192.168.1.5 4: 067281: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [64.255.123.18]:5060
Aug 09 07:53:42 192.168.1.5 5: 067282: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:42 192.168.1.5 6: 067283: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:42 192.168.1.5 7: 067284: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:42 192.168.1.5 8: Received:
Aug 09 07:53:42 192.168.1.5 9: INVITE sip:5743060212@white.u4voip.com SIP/2.0
Aug 09 07:53:42 192.168.1.5 10: Via: SIP/2.0/UDP 64.255.123.18:5060;branch=z9hG4bK791ba19f
Aug 09 07:53:43 192.168.1.5 11: From: "15744579485" <15744579485>;tag=as2792349d
Aug 09 07:53:43 192.168.1.5 12: To: <>5743060212@white.u4voip.com>
Aug 09 07:53:43 192.168.1.5 13: Contact: <15744579485>
Aug 09 07:53:43 192.168.1.5 14: Call-ID: 156444e465ee42093bddaeca168937b6@64.255.123.18
Aug 09 07:53:43 192.168.1.5 15: CSeq: 102 INVITE
Aug 09 07:53:43 192.168.1.5 16: User-Agent: Asterisk PBX
Aug 09 07:53:43 192.168.1.5 17: Max-Forwards: 70
Aug 09 07:53:43 192.168.1.5 18: Date: Mon, 09 Aug 2010 11:53:42 GMT
Aug 09 07:53:43 192.168.1.5 19: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Aug 09 07:53:43 192.168.1.5 20: Supported: replaces
Aug 09 07:53:43 192.168.1.5 21: Content-Ty
Aug 09 07:53:43 192.168.1.5 22: pe: application/sdp
Aug 09 07:53:43 192.168.1.5 23: Content-Length: 240
Aug 09 07:53:43 192.168.1.5 24:
Aug 09 07:53:43 192.168.1.5 25: v=0
Aug 09 07:53:43 192.168.1.5 26: o=root 2082 2082 IN IP4 64.255.123.18
Aug 09 07:53:43 192.168.1.5 27: s=session
Aug 09 07:53:43 192.168.1.5 28: c=IN IP4 64.255.123.18
Aug 09 07:53:43 192.168.1.5 29: t=0 0
Aug 09 07:53:43 192.168.1.5 30: m=audio 19398 RTP/AVP 0 101
Aug 09 07:53:43 192.168.1.5 31: a=rtpmap:0 PCMU/8000
Aug 09 07:53:43 192.168.1.5 32: a=rtpmap:101 telephone-event/8000
Aug 09 07:53:43 192.168.1.5 33: a=fmtp:101 0-16
Aug 09 07:53:43 192.168.1.5 34: a=silenceSupp:off - - - -
Aug 09 07:53:43 192.168.1.5 35: a=ptime:20
Aug 09 07:53:43 192.168.1.5 36: a=sendrecv
Aug 09 07:53:43 192.168.1.5 37: 067285: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 07:53:43 192.168.1.5 38: 067286: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4A44C280) with key=[2575] to table
Aug 09 07:53:43 192.168.1.5 39: 067287: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 64.255.123.18,Port 5060, Transport 1, SentBy Port 5060
Aug 09 07:53:43 192.168.1.5 40: 067288: Aug  9 07:53:42.927 EDT: //-1/979C2F62A96C/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Aug 09 07:53:43 192.168.1.5 41: 067289: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 64.255.123.18,Port 5060, Transport 1, SentBy Port 5060
Aug 09 07:53:43 192.168.1.5 42: 067290: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 07:53:43 192.168.1.5 43: 067291: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 64.255.123.18,Port 5060, Transport 1, SentBy Port 5060
Aug 09 07:53:43 192.168.1.5 44: 067292: Aug  9 07:53:42.927 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x4792438C) found for sip_user: 5743060212
Aug 09 07:53:43 192.168.1.5 45: 067293: Aug  9 07:53:42.931 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 07:53:43 192.168.1.5 46: 067294: Aug  9 07:53:42.931 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
Aug 09 07:53:43 192.168.1.5 47: 067295: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
Aug 09 07:53:43 192.168.1.5 48: 067296: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4A44C280 key=156444e465ee42093bddaeca168937b6@64.255.123.185743060212
Aug 09 07:53:43 192.168.1.5 49: 067297: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
Aug 09 07:53:43 192.168.1.5 50: 067298: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 5743060212
Aug 09 07:53:43 192.168.1.5 51: 067299: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 15744579485
Aug 09 07:53:43 192.168.1.5 52: 067300: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name 15744579485, number 15744579485, Calling oct3 0x00, oct_3a 0x80, Called number 5743060212
Aug 09 07:53:43 192.168.1.5 53: 067301: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 15744579485
Aug 09 07:53:43 192.168.1.5 54: 067302: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
Aug 09 07:53:43 192.168.1.5 55: 067303: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
Aug 09 07:53:43 192.168.1.5 56: 067304: Aug  9 07:53:42.931 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
Aug 09 07:53:43 192.168.1.5 57: 067305: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Peer tag 55 matched for incoming call
Aug 09 07:53:43 192.168.1.5 58: 067306: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
Aug 09 07:53:43 192.168.1.5 59: 067307: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
Aug 09 07:53:43 192.168.1.5 60: 067308: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Not using Voice Class Codec
Aug 09 07:53:43 192.168.1.5 61: 067309: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Aug 09 07:53:43 192.168.1.5 62: 067310: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Aug 09 07:53:43 192.168.1.5 63: 067311: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
Aug 09 07:53:43 192.168.1.5 64: 067312: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
Aug 09 07:53:43 192.168.1.5 65: 067313: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
Aug 09 07:53:43 192.168.1.5 66: 067314: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Aug 09 07:53:43 192.168.1.5 67: 067315: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIContinueNewMsgInvite: Calling name 15744579485, number 15744579485, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 5743060212, oct3 0x00
Aug 09 07:53:43 192.168.1.5 68: 067316: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
Aug 09 07:53:43 192.168.1.5 69: 067317: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIValidateRequestUri: Not Enabled
Aug 09 07:53:43 192.168.1.5 70: 067318: Aug  9 07:53:42.935 EDT: //-1/979C2F62A96C/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Aug 09 07:53:43 192.168.1.5 71: 067319: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
Aug 09 07:53:43 192.168.1.5 72: 067320: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Aug 09 07:53:43 192.168.1.5 73: 067321: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Aug 09 07:53:43 192.168.1.5 74: 067322: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
Aug 09 07:53:43 192.168.1.5 75: 067323: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
Aug 09 07:53:43 192.168.1.5 76: 067324: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Aug 09 07:53:43 192.168.1.5 77: SIP: (5589) Attribute mid, level 1 instance 1 not found.
Aug 09 07:53:43 192.168.1.5 78: 067325: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 74.84.117.204
Aug 09 07:53:43 192.168.1.5 79: 067326: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
Aug 09 07:53:43 192.168.1.5 80: 067327: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Aug 09 07:53:43 192.168.1.5 81: 067328: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
Aug 09 07:53:43 192.168.1.5 82:                           as its in use by other codec No Codec
Aug 09 07:53:43 192.168.1.5 83: 067329: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
Aug 09 07:53:43 192.168.1.5 84: 067330: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Aug 09 07:53:43 192.168.1.5 85: 067331: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
Aug 09 07:53:43 192.168.1.5 86: 067332: Aug  9 07:53:42.935 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
Aug 09 07:53:43 192.168.1.5 87: 067333: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Aug 09 07:53:43 192.168.1.5 88: 067334: Aug  9 07:53:42.935 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
Aug 09 07:53:43 192.168.1.5 89: 067335: Aug  9 07:53:42.939 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
Aug 09 07:53:43 192.168.1.5 90: 067336: Aug  9 07:53:42.939 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 07:53:43 192.168.1.5 91: 067337: Aug  9 07:53:42.939 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
Aug 09 07:53:43 192.168.1.5 92: 067338: Aug  9 07:53:42.939 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Aug 09 07:53:43 192.168.1.5 93: 067339: Aug  9 07:53:42.939 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Aug 09 07:53:43 192.168.1.5 127: Codec to be matched: 5
Aug 09 07:53:43 192.168.1.5 128: 067359: Aug  9 07:53:42.939 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
Aug 09 07:53:43 192.168.1.5 129: 067360: Aug  9 07:53:42.939 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 07:53:43 192.168.1.5 190: 067390: Aug  9 07:53:42.943 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Aug 09 07:53:43 192.168.1.5 191: 067391: Aug  9 07:53:42.943 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
Aug 09 07:53:43 192.168.1.5 192: 067392: Aug  9 07:53:42.943 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
Aug 09 07:53:43 192.168.1.5 218: CSeq: 102 INVITE
Aug 09 07:53:43 192.168.1.5 219: Allow-Events: telephone-event
Aug 09 07:53:43 192.168.1.5 220: Server: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:43 192.168.1.5 221: Content-Length: 0
Aug 09 07:53:43 192.168.1.5 222:
Aug 09 07:53:43 192.168.1.5 240: 067424: Aug  9 07:53:42.963 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
Aug 09 07:53:43 192.168.1.5 241: 067425: Aug  9 07:53:42.963 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
Aug 09 07:53:43 192.168.1.5 242: 067426: Aug  9 07:53:42.967 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
Aug 09 07:53:43 192.168.1.5 243: 067427: Aug  9 07:53:42.967 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Aug 09 07:53:43 192.168.1.5 258: 067441: Aug  9 07:53:42.971 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_call_setup: xcoder high-density disabled
Aug 09 07:53:43 192.168.1.5 259: 067442: Aug  9 07:53:42.971 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_call_setup: Flow Mode set to FLOW_THROUGH
Aug 09 07:53:43 192.168.1.5 260: 067443: Aug  9 07:53:42.971 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
Aug 09 07:53:43 192.168.1.5 261: callid 5590, channels 0x4E449B78 caps 0x4ED45BAC
Aug 09 07:53:43 192.168.1.5 262: 067444: Aug  9 07:53:42.971 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 5590, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 0
Aug 09 07:53:43 192.168.1.5 298: 067477: Aug  9 07:53:42.975 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
Aug 09 07:53:43 192.168.1.5 309: 067487: Aug  9 07:53:42.979 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4EA907B4, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 07:53:43 192.168.1.5 338: Cisco-Guid: 2543595362-2732790239-2842469100-1319177569
Aug 09 07:53:43 192.168.1.5 339: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:43 192.168.1.5 340: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK
Aug 09 07:53:43 192.168.1.5 341: , PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 07:53:43 192.168.1.5 342: CSeq: 101 INVITE
Aug 09 07:53:43 192.168.1.5 343: Timestamp: 1281354822
Aug 09 07:53:43 192.168.1.5 344: Contact: <15744579485>
Aug 09 07:53:43 192.168.1.5 384: 067515: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:43 192.168.1.5 385: Received:
Aug 09 07:53:43 192.168.1.5 386: SIP/2.0 180 Ringing
Aug 09 07:53:43 192.168.1.5 387: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17A89F0
Aug 09 07:53:43 192.168.1.5 388: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:43 192.168.1.5 389: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:43 192.168.1.5 390: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:43 192.168.1.5 391: CSeq: 101 INVITE
Aug 09 07:53:43 192.168.1.5 392: Content-Length: 0
Aug 09 07:53:43 192.168.1.5 393: Contact: <5743060212>
Aug 09 07:53:43 192.168.1.5 394:
Aug 09 07:53:43 192.168.1.5 395: 067516: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Aug 09 07:53:43 192.168.1.5 396: 067517: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 07:53:43 192.168.1.5 397: 067518: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
Aug 09 07:53:43 192.168.1.5 398: 067519: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
Aug 09 07:53:43 192.168.1.5 399: 067520: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Aug 09 07:53:43 192.168.1.5 400: 067521: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Aug 09 07:53:43 192.168.1.5 401: 067522: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Aug 09 07:53:43 192.168.1.5 402: 067523: Aug  9 07:53:43.059 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Aug 09 07:53:43 192.168.1.5 403: 067524: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Aug 09 07:53:43 192.168.1.5 404: 067525: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
Aug 09 07:53:43 192.168.1.5 405: 067526: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
Aug 09 07:53:43 192.168.1.5 406: 067527: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
Aug 09 07:53:43 192.168.1.5 407: 067528: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/State/sipSPIChangeState: 0x4A431CC8 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Aug 09 07:53:43 192.168.1.5 408: 067529: Aug  9 07:53:43.059 EDT: //5590/979C2F62A96C/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
Aug 09 07:53:43 192.168.1.5 442: 067549: Aug  9 07:53:43.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:43 192.168.1.5 443: 067550: Aug  9 07:53:43.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:43 192.168.1.5 468: 067554: Aug  9 07:53:43.127 EDT: //5590/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Aug 09 07:53:43 192.168.1.5 469: 067555: Aug  9 07:53:43.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 07:53:43 192.168.1.5 470: 067556: Aug  9 07:53:43.127 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
Aug 09 07:53:43 192.168.1.5 471: 067557: Aug  9 07:53:43.131 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
Aug 09 07:53:43 192.168.1.5 472: 067558: Aug  9 07:53:43.131 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 5589/5590
Aug 09 07:53:43 192.168.1.5 510:     Preferred NTE payload  : 101
Aug 09 07:53:43 192.168.1.5 511:     Early Media            : No
Aug 09 07:53:43 192.168.1.5 512:     Delayed Media          : No
Aug 09 07:53:43 192.168.1.5 513:     Bridge Done            : No
Aug 09 07:53:43 192.168.1.5 514:     New Media              : No
Aug 09 07:53:43 192.168.1.5 515:     DSP DNLD Reqd          : No
Aug 09 07:53:43 192.168.1.5 516: 067591: Aug  9 07:53:43.135 EDT: //5590/979C2F62A96C/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Aug 09 07:53:43 192.168.1.5 524: 067596: Aug  9 07:53:43.135 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Aug 09 07:53:43 192.168.1.5 525: Hndl ptype 0 mline 1
Aug 09 07:53:43 192.168.1.5 526: 067597: Aug  9 07:53:43.135 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
Aug 09 07:53:43 192.168.1.5 560: 067622: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Aug 09 07:53:43 192.168.1.5 561: 067623: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Aug 09 07:53:43 192.168.1.5 562: 067624: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
Aug 09 07:53:43 192.168.1.5 563: 067625: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
Aug 09 07:53:43 192.168.1.5 564: 067626: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetStreamInfo:
Aug 09 07:53:43 192.168.1.5 565: caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
Aug 09 07:53:43 192.168.1.5 566: 067627: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
Aug 09 07:53:43 192.168.1.5 567: 067628: Aug  9 07:53:43.135 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
Aug 09 07:53:43 192.168.1.5 568: 067629: Aug  9 07:53:43.139 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
Aug 09 07:53:43 192.168.1.5 604: 067648: Aug  9 07:53:43.139 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
Aug 09 07:53:43 192.168.1.5 605: 067649: Aug  9 07:53:43.139 EDT: //5590/979C2F62A96C/SIP/State/sipSPIChangeState: 0x4A431CC8 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
Aug 09 07:53:43 192.168.1.5 606: 067650: Aug  9 07:53:43.139 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIQoSRevertBW: Entry
Aug 09 07:53:43 192.168.1.5 607: 067651: Aug  9 07:53:43.139 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Aug 09 07:53:43 192.168.1.5 608: 067652: Aug  9 07:53:43.139 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Aug 09 07:53:43 192.168.1.5 609: 067653: Aug  9 07:53:43.139 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
Aug 09 07:53:43 192.168.1.5 668: 067685: Aug  9 07:53:43.143 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x403403
Aug 09 07:53:43 192.168.1.5 669: 067686: Aug  9 07:53:43.143 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
Aug 09 07:53:43 192.168.1.5 670: 067687: Aug  9 07:53:43.143 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 07:53:43 192.168.1.5 671: 067688: Aug  9 07:53:43.143 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
Aug 09 07:53:43 192.168.1.5 783: 067769: Aug  9 07:53:43.159 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E327024, addr=64.255.123.18, port=5060, connId=0 for UDP
Aug 09 07:53:43 192.168.1.5 784: 067770: Aug  9 07:53:43.159 EDT: //5589/979C2F62A96C/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
Aug 09 07:53:43 192.168.1.5 785: 067771: Aug  9 07:53:43.159 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
Aug 09 07:53:43 192.168.1.5 786: 067772: Aug  9 07:53:43.159 EDT: //5589/979C2F62A96C/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE)  to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
Aug 09 07:53:43 192.168.1.5 796: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 07:53:43 192.168.1.5 797: Allow-Events: telephone-event
Aug 09 07:53:43 192.168.1.5 798: Contact: <5743060212>
Aug 09 07:53:43 192.168.1.5 799: Supported: replaces
Aug 09 07:53:43 192.168.1.5 800: Su
Aug 09 07:53:43 192.168.1.5 860: Source IP Address (Media): 74.84.117.204
Aug 09 07:53:43 192.168.1.5 861: Source IP Port    (Media): 19492
Aug 09 07:53:43 192.168.1.5 862: Destn  IP Address (Media): 64.255.123.18
Aug 09 07:53:43 192.168.1.5 863: Destn  IP Port    (Media): 19398
Aug 09 07:53:43 192.168.1.5 864: Orig Destn IP Address:Port (Media): [ - ]:0
Aug 09 07:53:43 192.168.1.5 865: 067787: Aug  9 07:53:43.243 EDT: //5589/979C2F62A96C/SIP/Info/sipSPICreateAndStartRtpTimer:
Aug 09 07:53:44 192.168.1.5 866: 067788: Aug  9 07:53:43.243 EDT: //5589/979C2F62A96C/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
Aug 09 07:53:44 192.168.1.5 867: 067789: Aug  9 07:53:43.243 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 64.255.123.18, RTCP Type 3
Aug 09 07:53:44 192.168.1.5 868: 067790: Aug  9 07:53:43.243 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 07:53:52 192.168.1.5 869: 067791: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 16
Aug 09 07:53:52 192.168.1.5 870: 067792: Aug  9 07:53:52.747 EDT: //5590/979C2F62A96C/SIP/Info/sipSPISetUnsolicitedNotifySendDigitTimer: Starting unsolicited notify timer for: 1900
Aug 09 07:53:52 192.168.1.5 871: 067793: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Aug 09 07:53:52 192.168.1.5 872: 067794: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
Aug 09 07:53:52 192.168.1.5 873: 067795: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:52 192.168.1.5 874: 067796: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457908
Aug 09 07:53:52 192.168.1.5 875: 067797: Aug  9 07:53:52.747 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457908's parent is 0x4E849D80
Aug 09 07:53:52 192.168.1.5 876: 067798: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Port Present: FALSE, Transport 1, FQDN 1154642800
Aug 09 07:53:52 192.168.1.5 877: 067799: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 07:53:52 192.168.1.5 878: 067800: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Aug 09 07:53:52 192.168.1.5 879:  Sending: Binary Message Body
Aug 09 07:53:52 192.168.1.5 880: 067801: Aug  9 07:53:52.751 EDT: Content-Type: audio/telephone-event
Aug 09 07:53:52 192.168.1.5 881: 08 00 07 D0
Aug 09 07:53:52 192.168.1.5 882: 067802: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457908's method is 111
Aug 09 07:53:52 192.168.1.5 883: 067803: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A457908) has claimed possesion of package (0x4EB18DC4)
Aug 09 07:53:52 192.168.1.5 884: 067804: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK17AA2477
Aug 09 07:53:52 192.168.1.5 885: 067805: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 07:53:52 192.168.1.5 886: 067806: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457908) on EDB(0x4E953E50)
Aug 09 07:53:52 192.168.1.5 887: 067807: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
Aug 09 07:53:52 192.168.1.5 888: 067808: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
Aug 09 07:53:52 192.168.1.5 889: 067809: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A457908 and parent: 0x4E849D80
Aug 09 07:53:52 192.168.1.5 890: 067810: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4EB18DC4, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41847784
Aug 09 07:53:52 192.168.1.5 891: 067811: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 07:53:52 192.168.1.5 892: 067812: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 07:53:52 192.168.1.5 893: 067813: Aug  9 07:53:52.751 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4EB18DC4
Aug 09 07:53:52 192.168.1.5 894: 067814: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4EB18DC4, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 07:53:52 192.168.1.5 895: 067815: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
Aug 09 07:53:52 192.168.1.5 896: 067816: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x4A457908) with 10 retries and 500 milliseconds initial retx
Aug 09 07:53:52 192.168.1.5 897: 067817: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x4D906774)
Aug 09 07:53:52 192.168.1.5 898: 067818: Aug  9 07:53:52.751 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:52 192.168.1.5 899: Sent:
Aug 09 07:53:52 192.168.1.5 900: NOTIFY sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 07:53:52 192.168.1.5 901: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17AA2477
Aug 09 07:53:52 192.168.1.5 902: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:52 192.168.1.5 903: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:52 192.168.1.5 904: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:52 192.168.1.5 905: CSeq: 102 NOTIFY
Aug 09 07:53:52 192.168.1.5 906: Max-Forwards: 70
Aug 09 07:53:52 192.168.1.5 907: Date: Mon, 09 Aug 2010 11:53:52 GMT
Aug 09 07:53:52 192.168.1.5 908: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:52 192.168.1.5 909: Event: telephone-event
Aug 09 07:53:52 192.168.1.5 910: Subscription-State: active
Aug 09 07:53:52 192.168.1.5 911: Contact: <192.168.3.1:5060>
Aug 09 07:53:52 192.168.1.5 912: Content-Type: audio/telephone-event
Aug 09 07:53:52 192.168.1.5 913: Content-Length: 4
Aug 09 07:53:52 192.168.1.5 914:
Aug 09 07:53:52 192.168.1.5 915:  . \u00d0
Aug 09 07:53:52 192.168.1.5 916: 067819: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:52 192.168.1.5 917: 067820: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:52 192.168.1.5 918: 067821: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:52 192.168.1.5 919: 067822: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:53:52 192.168.1.5 920: 067823: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:52 192.168.1.5 921: 067824: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:52 192.168.1.5 922: 067825: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:52 192.168.1.5 923: Received:
Aug 09 07:53:52 192.168.1.5 924: SIP/2.0 200 OK
Aug 09 07:53:52 192.168.1.5 925: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17AA2477
Aug 09 07:53:52 192.168.1.5 926: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:52 192.168.1.5 927: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:52 192.168.1.5 928: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:52 192.168.1.5 929: CSeq: 102 NOTIFY
Aug 09 07:53:52 192.168.1.5 930: Content-Length: 0
Aug 09 07:53:52 192.168.1.5 931: Allow-Events: refer
Aug 09 07:53:52 192.168.1.5 932: Allow-Events: telephone-event
Aug 09 07:53:52 192.168.1.5 933: Allow-Events: message-summary
Aug 09 07:53:52 192.168.1.5 934:
Aug 09 07:53:52 192.168.1.5 935: 067826: Aug  9 07:53:52.767 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:52 192.168.1.5 936: 067827: Aug  9 07:53:52.771 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:52 192.168.1.5 937: 067828: Aug  9 07:53:52.771 EDT: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x4A457908) on SCB(0x4E849D80)
Aug 09 07:53:52 192.168.1.5 938: 067829: Aug  9 07:53:52.771 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
Aug 09 07:53:52 192.168.1.5 939: 067830: Aug  9 07:53:52.771 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
Aug 09 07:53:52 192.168.1.5 940: 067831: Aug  9 07:53:52.771 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A457908) from EDB(0x4E953E50)
Aug 09 07:53:52 192.168.1.5 941: 067832: Aug  9 07:53:52.771 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A457908) for reuse
Aug 09 07:53:52 192.168.1.5 942: 067833: Aug  9 07:53:52.771 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
Aug 09 07:53:52 192.168.1.5 943: 067834: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 16
Aug 09 07:53:52 192.168.1.5 944: 067835: Aug  9 07:53:52.947 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIStopUnsolicitedNotifySendDigitTimer: Stopping unsolicited notify timer
Aug 09 07:53:53 192.168.1.5 945: 067836: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Aug 09 07:53:53 192.168.1.5 946: 067837: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
Aug 09 07:53:53 192.168.1.5 947: 067838: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:53 192.168.1.5 948: 067839: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457A9C
Aug 09 07:53:53 192.168.1.5 949: 067840: Aug  9 07:53:52.947 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457A9C's parent is 0x4E849D80
Aug 09 07:53:53 192.168.1.5 950: 067841: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Port Present: FALSE, Transport 1, FQDN 1154642800
Aug 09 07:53:53 192.168.1.5 951: 067842: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 07:53:53 192.168.1.5 952: 067843: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Aug 09 07:53:53 192.168.1.5 953:  Sending: Binary Message Body
Aug 09 07:53:53 192.168.1.5 954: 067844: Aug  9 07:53:52.951 EDT: Content-Type: audio/telephone-event
Aug 09 07:53:53 192.168.1.5 955: 08 80 00 C3
Aug 09 07:53:53 192.168.1.5 956: 067845: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457A9C's method is 111
Aug 09 07:53:53 192.168.1.5 957: 067846: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A457A9C) has claimed possesion of package (0x4EC4E9C8)
Aug 09 07:53:53 192.168.1.5 958: 067847: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK17AB19FC
Aug 09 07:53:53 192.168.1.5 959: 067848: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 07:53:53 192.168.1.5 960: 067849: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457A9C) on EDB(0x4E953E50)
Aug 09 07:53:53 192.168.1.5 961: 067850: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
Aug 09 07:53:53 192.168.1.5 962: 067851: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
Aug 09 07:53:53 192.168.1.5 963: 067852: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A457A9C and parent: 0x4E849D80
Aug 09 07:53:53 192.168.1.5 964: 067853: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4EC4E9C8, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41847784
Aug 09 07:53:53 192.168.1.5 965: 067854: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 07:53:53 192.168.1.5 966: 067855: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 07:53:53 192.168.1.5 967: 067856: Aug  9 07:53:52.951 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4EC4E9C8
Aug 09 07:53:53 192.168.1.5 968: 067857: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4EC4E9C8, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 07:53:53 192.168.1.5 969: 067858: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
Aug 09 07:53:53 192.168.1.5 970: 067859: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x4A457A9C) with 10 retries and 500 milliseconds initial retx
Aug 09 07:53:53 192.168.1.5 971: 067860: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x4D90AC34)
Aug 09 07:53:53 192.168.1.5 972: 067861: Aug  9 07:53:52.951 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 973: Sent:
Aug 09 07:53:53 192.168.1.5 974: NOTIFY sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 07:53:53 192.168.1.5 975: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17AB19FC
Aug 09 07:53:53 192.168.1.5 976: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 977: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 978: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 979: CSeq: 103 NOTIFY
Aug 09 07:53:53 192.168.1.5 980: Max-Forwards: 70
Aug 09 07:53:53 192.168.1.5 981: Date: Mon, 09 Aug 2010 11:53:52 GMT
Aug 09 07:53:53 192.168.1.5 982: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:53 192.168.1.5 983: Event: telephone-event
Aug 09 07:53:53 192.168.1.5 984: Subscription-State: active
Aug 09 07:53:53 192.168.1.5 985: Contact: <192.168.3.1:5060>
Aug 09 07:53:53 192.168.1.5 986: Content-Type: audio/telephone-event
Aug 09 07:53:53 192.168.1.5 987: Content-Length: 4
Aug 09 07:53:53 192.168.1.5 988:
Aug 09 07:53:53 192.168.1.5 989:  \u20ac.\u00c3
Aug 09 07:53:53 192.168.1.5 990: 067862: Aug  9 07:53:52.967 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:53 192.168.1.5 991: 067863: Aug  9 07:53:52.967 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:53 192.168.1.5 992: 067864: Aug  9 07:53:52.967 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:53 192.168.1.5 993: 067865: Aug  9 07:53:52.967 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:53:53 192.168.1.5 994: 067866: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 995: 067867: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 996: 067868: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 997: Received:
Aug 09 07:53:53 192.168.1.5 998: SIP/2.0 200 OK
Aug 09 07:53:53 192.168.1.5 999: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17AB19FC
Aug 09 07:53:53 192.168.1.5 1000: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 1001: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 1002: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 1003: CSeq: 103 NOTIFY
Aug 09 07:53:53 192.168.1.5 1004: Content-Length: 0
Aug 09 07:53:53 192.168.1.5 1005: Allow-Events: refer
Aug 09 07:53:53 192.168.1.5 1006: Allow-Events: telephone-event
Aug 09 07:53:53 192.168.1.5 1007: Allow-Events: message-summary
Aug 09 07:53:53 192.168.1.5 1008:
Aug 09 07:53:53 192.168.1.5 1009: 067869: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:53 192.168.1.5 1010: 067870: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:53 192.168.1.5 1011: 067871: Aug  9 07:53:52.971 EDT: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x4A457A9C) on SCB(0x4E849D80)
Aug 09 07:53:53 192.168.1.5 1012: 067872: Aug  9 07:53:52.971 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
Aug 09 07:53:53 192.168.1.5 1013: 067873: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
Aug 09 07:53:53 192.168.1.5 1014: 067874: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A457A9C) from EDB(0x4E953E50)
Aug 09 07:53:53 192.168.1.5 1015: 067875: Aug  9 07:53:52.971 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A457A9C) for reuse
Aug 09 07:53:53 192.168.1.5 1016: 067876: Aug  9 07:53:52.971 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
Aug 09 07:53:53 192.168.1.5 1017: 067877: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:53 192.168.1.5 1018: 067878: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:53 192.168.1.5 1019: 067879: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:53 192.168.1.5 1020: 067880: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 1021: Received:
Aug 09 07:53:53 192.168.1.5 1022: INVITE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:53:53 192.168.1.5 1023: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3319
Aug 09 07:53:53 192.168.1.5 1024: Max-Forwards: 70
Aug 09 07:53:53 192.168.1.5 1025: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 1026: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 1027: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 1028: CSeq: 1 INVITE
Aug 09 07:53:53 192.168.1.5 1029: Content-Length: 168
Aug 09 07:53:53 192.168.1.5 1030: Contact: <5743060212>
Aug 09 07:53:53 192.168.1.5 1031: Content-Type: application/sdp
Aug 09 07:53:53 192.168.1.5 1032: Call-Info: <192.168.3.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Aug 09 07:53:53 192.168.1.5 1033: Allow-Ev
Aug 09 07:53:53 192.168.1.5 1034: ents: telephone-event
Aug 09 07:53:53 192.168.1.5 1035:
Aug 09 07:53:53 192.168.1.5 1036: v=0
Aug 09 07:53:53 192.168.1.5 1037: o=CiscoSystemsSIP-Workflow-App-UserAgent 3200 3200 IN IP4 0.0.0.0
Aug 09 07:53:53 192.168.1.5 1038: s=SIP Call
Aug 09 07:53:53 192.168.1.5 1039: c=IN IP4 0.0.0.0
Aug 09 07:53:53 192.168.1.5 1040: t=0 0
Aug 09 07:53:53 192.168.1.5 1041: m=audio 16906 RTP/AVP 0
Aug 09 07:53:53 192.168.1.5 1042: a=rtpmap:0 pcmu/8000
Aug 09 07:53:53 192.168.1.5 1043: a=ptime:20
Aug 09 07:53:53 192.168.1.5 1044: 067881: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 07:53:53 192.168.1.5 1045: 067882: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4A431CC8
Aug 09 07:53:53 192.168.1.5 1046: 067883: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
Aug 09 07:53:53 192.168.1.5 1047: 067884: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 35366, Transport 1, SentBy Port 5060
Aug 09 07:53:53 192.168.1.5 1048: 067885: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 07:53:53 192.168.1.5 1049: 067886: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 35366, Transport 1, SentBy Port 5060
Aug 09 07:53:53 192.168.1.5 1050: 067887: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
Aug 09 07:53:53 192.168.1.5 1051: 067888: Aug  9 07:53:53.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 07:53:53 192.168.1.5 1052: 067889: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
Aug 09 07:53:53 192.168.1.5 1053: 067890: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Aug 09 07:53:53 192.168.1.5 1054: 067891: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
Aug 09 07:53:53 192.168.1.5 1055: 067892: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
Aug 09 07:53:53 192.168.1.5 1056: 067893: Aug  9 07:53:53.039 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
Aug 09 07:53:53 192.168.1.5 1057: 067894: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <192.168.3.2:5060>, duration = 2000
Aug 09 07:53:53 192.168.1.5 1058: 067895: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Aug 09 07:53:53 192.168.1.5 1059: SIP: Attribute mid, level 1 instance 1 not found.
Aug 09 07:53:53 192.168.1.5 1060: 067896: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Aug 09 07:53:53 192.168.1.5 1061: 067897: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.3.1
Aug 09 07:53:53 192.168.1.5 1062: 067898: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
Aug 09 07:53:53 192.168.1.5 1063: 067899: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
Aug 09 07:53:53 192.168.1.5 1064: 067900: Aug  9 07:53:53.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
Aug 09 07:53:53 192.168.1.5 1065: 067901: Aug  9 07:53:53.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 07:53:53 192.168.1.5 1066: 067902: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
Aug 09 07:53:53 192.168.1.5 1067: 067903: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Aug 09 07:53:53 192.168.1.5 1068: 067904: Aug  9 07:53:53.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Aug 09 07:53:53 192.168.1.5 1069: 067905: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Aug 09 07:53:53 192.168.1.5 1074: 067908: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
Aug 09 07:53:53 192.168.1.5 1075: 067909: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=16906 new=16906
Aug 09 07:53:53 192.168.1.5 1076: 067910: Aug  9 07:53:53.043 EDT: //5590/979C2F62A96C/SIP/Media/sipSPIGetNewLocalMediaDirection:
Aug 09 07:53:53 192.168.1.5 1138: 067948: Aug  9 07:53:53.047 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind:
Aug 09 07:53:53 192.168.1.5 1139:  destCallID=5589, srcCallID=5590,
Aug 09 07:53:53 192.168.1.5 1140:                          peer_ccb->call_info.currentLocalName=15744579485,
Aug 09 07:53:53 192.168.1.5 1141:                          peer_ccb->call_info.currentRemoteName=,
Aug 09 07:53:53 192.168.1.5 1142:                          ccb->call_info.currentLocalName=,
Aug 09 07:53:53 192.168.1.5 1143:                          ccb->call_info.currentRemoteName=
Aug 09 07:53:53 192.168.1.5 1144: 067949: Aug  9 07:53:53.047 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=5589, current_seq_num=0x0
Aug 09 07:53:53 192.168.1.5 1202: 068002: Aug  9 07:53:53.055 EDT: //5590/979C2F62A96C/SIP/Media/sipSPIUpdCallWithSdpInfo:
Aug 09 07:53:53 192.168.1.5 1203:       Stream type            : voice-only
Aug 09 07:53:53 192.168.1.5 1204:       Media line             : 1
Aug 09 07:53:53 192.168.1.5 1205:       State                  : STREAM_ACTIVE (5)
Aug 09 07:53:53 192.168.1.5 1206:       Stream address type    : 1
Aug 09 07:53:53 192.168.1.5 1207:       Callid                 : 5590
Aug 09 07:53:53 192.168.1.5 1208:       Negotiated Codec       : g711ulaw, bytes :160
Aug 09 07:53:53 192.168.1.5 1209:       Nego. Codec payload    : 0 (tx), 0 (rx)
Aug 09 07:53:53 192.168.1.5 1210:       Negotiated DTMF relay  : sip-notify
Aug 09 07:53:53 192.168.1.5 1251: Allow: INV
Aug 09 07:53:53 192.168.1.5 1252: ITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 07:53:53 192.168.1.5 1272: a=ptime:20
Aug 09 07:53:53 192.168.1.5 1273: 068026: Aug  9 07:53:53.063 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 1274: Sent:
Aug 09 07:53:53 192.168.1.5 1275: SIP/2.0 100 Trying
Aug 09 07:53:53 192.168.1.5 1276: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3319
Aug 09 07:53:53 192.168.1.5 1277: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 1278: To: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 1279: Date: Mon, 09 Aug 2010 11:53:53 GMT
Aug 09 07:53:53 192.168.1.5 1280: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 1281: CSeq: 1 INVITE
Aug 09 07:53:53 192.168.1.5 1282: Allow-Events: telephone-event
Aug 09 07:53:53 192.168.1.5 1283: Server: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:53 192.168.1.5 1284: Content-Length: 0
Aug 09 07:53:53 192.168.1.5 1285:
Aug 09 07:53:53 192.168.1.5 1286: 068027: Aug  9 07:53:53.159 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [64.255.123.18]:5060
Aug 09 07:53:53 192.168.1.5 1287: 068028: Aug  9 07:53:53.159 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [64.255.123.18]:5060
Aug 09 07:53:53 192.168.1.5 1288: 068029: Aug  9 07:53:53.163 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:53 192.168.1.5 1289: 068030: Aug  9 07:53:53.163 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:53 192.168.1.5 1292: 068033: Aug  9 07:53:53.163 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 1302: Supported: replaces
Aug 09 07:53:53 192.168.1.5 1303: Contact: <15744579485>
Aug 09 07:53:53 192.168.1.5 1304: Content-Length: 0
Aug 09 07:53:53 192.168.1.5 1305:
Aug 09 07:53:53 192.168.1.5 1306: 068034: Aug  9 07:53:53.163 EDT: //5589/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Aug 09 07:53:53 192.168.1.5 1307: 068035: Aug  9 07:53:53.163 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:53 192.168.1.5 1308: 068036: Aug  9 07:53:53.163 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:53 192.168.1.5 1326: v=
Aug 09 07:53:53 192.168.1.5 1327: 0
Aug 09 07:53:53 192.168.1.5 1328: o=root 2082 2083 IN IP4 64.255.123.18
Aug 09 07:53:53 192.168.1.5 1329: s=session
Aug 09 07:53:53 192.168.1.5 1351: 068050: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Aug 09 07:53:53 192.168.1.5 1355:                           as its in use by other codec No Codec
Aug 09 07:53:53 192.168.1.5 1356: 068054: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is  reserved by another application
Aug 09 07:53:53 192.168.1.5 1357: 068055: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Aug 09 07:53:53 192.168.1.5 1362: 068060: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
Aug 09 07:53:53 192.168.1.5 1363: 068061: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 07:53:53 192.168.1.5 1364: 068062: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
Aug 09 07:53:53 192.168.1.5 1365: 068063: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Aug 09 07:53:53 192.168.1.5 1366: 068064: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Aug 09 07:53:53 192.168.1.5 1367: 068065: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Aug 09 07:53:53 192.168.1.5 1368: 068066: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Aug 09 07:53:53 192.168.1.5 1369: 068067: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Aug 09 07:53:53 192.168.1.5 1370: 068068: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
Aug 09 07:53:53 192.168.1.5 1371: 068069: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
Aug 09 07:53:53 192.168.1.5 1372: 068070: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
Aug 09 07:53:53 192.168.1.5 1373: 068071: Aug  9 07:53:53.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
Aug 09 07:53:53 192.168.1.5 1374: 068072: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
Aug 09 07:53:53 192.168.1.5 1382:     New Remote Media Direction = SENDRECV
Aug 09 07:53:53 192.168.1.5 1383:     Present Local Media Direction = SENDRECV
Aug 09 07:53:53 192.168.1.5 1384:     New Local Media Direction = SENDRECV
Aug 09 07:53:53 192.168.1.5 1385:     retVal = 0
Aug 09 07:53:53 192.168.1.5 1386: 068078: Aug  9 07:53:53.167 EDT: //5589/979C2F62A96C/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=Yes CAPS_CHANGE=Yes RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
Aug 09 07:53:53 192.168.1.5 1398:     Delayed Media          : No
Aug 09 07:53:53 192.168.1.5 1399:     Bridge Done            : Yes
Aug 09 07:53:53 192.168.1.5 1400:     New Media              : Yes
Aug 09 07:53:53 192.168.1.5 1401:     DSP DNLD Reqd          : Yes
Aug 09 07:53:53 192.168.1.5 1402: 068086: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_report_media_to_peer:
Aug 09 07:53:53 192.168.1.5 1403:  callId 5589 peer 5590 flags 0x407407 state STATE_SENT_MIDCALL_INVITE
Aug 09 07:53:53 192.168.1.5 1404: 068087: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Aug 09 07:53:53 192.168.1.5 1405: CallID 5589, Peer CallID 5590, sdp 0x4E86B37C channels 0x4A44D528
Aug 09 07:53:53 192.168.1.5 1422: 068098: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 5589, dtmf = 6
Aug 09 07:53:53 192.168.1.5 1423: 068099: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
Aug 09 07:53:53 192.168.1.5 1424: 068100: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
Aug 09 07:53:53 192.168.1.5 1425: 068101: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_report_media_to_peer:
Aug 09 07:53:53 192.168.1.5 1426:  callId 5589 flags 0x4100 state STATE_SENT_MIDCALL_INVITE
Aug 09 07:53:53 192.168.1.5 1427: 068102: Aug  9 07:53:53.171 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC0401C, ccb->pld.flags_ipip 0x407407
Aug 09 07:53:53 192.168.1.5 1451:                          ccb->call_info.currentRemoteName=
Aug 09 07:53:53 192.168.1.5 1452: 068116: Aug  9 07:53:53.171 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=5590, current_seq_num=0x2330
Aug 09 07:53:53 192.168.1.5 1453: 068117: Aug  9 07:53:53.171 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=5590, current_seq_num=0x20A4
Aug 09 07:53:53 192.168.1.5 1454: 068118: Aug  9 07:53:53.175 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
Aug 09 07:53:53 192.168.1.5 1481:       Stream address type    : 1
Aug 09 07:53:53 192.168.1.5 1482:       Callid                 : -1
Aug 09 07:53:53 192.168.1.5 1483:       Negotiated Codec       : g711ulaw, bytes :160
Aug 09 07:53:53 192.168.1.5 1484:       Nego. Codec payload    : 0 (tx), 0 (rx)
Aug 09 07:53:53 192.168.1.5 1496: 068145: Aug  9 07:53:53.175 EDT: //5589/979C2F62A96C/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 74.84.117.204
Aug 09 07:53:53 192.168.1.5 1497: 068146: Aug  9 07:53:53.175 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Aug 09 07:53:53 192.168.1.5 1498: 068147: Aug  9 07:53:53.175 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
Aug 09 07:53:53 192.168.1.5 1499:     laddr = 74.84.117.204, lport = 19492, raddr = 64.255.123.18, rport=19398, do_rtcp=TRUE
Aug 09 07:53:53 192.168.1.5 1500:     src_callid = 5589, dest_callid = 5590, stream type = voice+dtmf, stream direction = SENDRECV
Aug 09 07:53:53 192.168.1.5 1501:     media_ip_addr = 0.0.0.0, vrf tableid = 0 media_addr_type = 1
Aug 09 07:53:53 192.168.1.5 1502: 068148: Aug  9 07:53:53.175 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Aug 09 07:53:53 192.168.1.5 1530: 068171: Aug  9 07:53:53.179 EDT: //5589/979C2F62A96C/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
Aug 09 07:53:53 192.168.1.5 1531:     laddr = 0.0.0.0, lport = 19492, raddr = 64.255.123.18, rport=19398, do_rtcp=TRUE
Aug 09 07:53:53 192.168.1.5 1532:     src_callid = 5589, dest_callid = 5590, stream type = voice+dtmf, stream direction = SENDRECV
Aug 09 07:53:53 192.168.1.5 1571: 068202: Aug  9 07:53:53.179 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind:
Aug 09 07:53:53 192.168.1.5 1598:  Checking if transcoder is needed for SRTP-RTP
Aug 09 07:53:53 192.168.1.5 1599: 068222: Aug  9 07:53:53.183 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_caps_ind: No video caps detected in the caps posted by peer leg
Aug 09 07:53:53 192.168.1.5 1600: 068223: Aug  9 07:53:53.183 EDT: //5590/979C2F62A96C/SIP/Info/ccsip_caps_ind: Calling cc_api_caps_ack()
Aug 09 07:53:53 192.168.1.5 1601: 068224: Aug  9 07:53:53.183 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
Aug 09 07:53:53 192.168.1.5 1641: Source IP Port    (Media): 19492
Aug 09 07:53:53 192.168.1.5 1642: Destn  IP Address (Media): 64.255.123.18
Aug 09 07:53:53 192.168.1.5 1643: Destn  IP Port    (Media): 19398
Aug 09 07:53:53 192.168.1.5 1644: Orig Destn IP Address:Port (Media): [ - ]:0
Aug 09 07:53:53 192.168.1.5 1645: 068246: Aug  9 07:53:53.183 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
Aug 09 07:53:53 192.168.1.5 1685: 068275: Aug  9 07:53:53.187 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 188, curr send SDP size =
Aug 09 07:53:53 192.168.1.5 1686:               188
Aug 09 07:53:53 192.168.1.5 1687: 068276: Aug  9 07:53:53.187 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP and curr send SDP are
Aug 09 07:53:53 192.168.1.5 1688:                   same
Aug 09 07:53:53 192.168.1.5 1689: 068277: Aug  9 07:53:53.187 EDT: //5590/979C2F62A96C/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID not incremented ..
Aug 09 07:53:53 192.168.1.5 1725: SIP/2.0 200 OK
Aug 09 07:53:53 192.168.1.5 1726: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3319
Aug 09 07:53:53 192.168.1.5 1727: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 1728: To: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 1729: Date: Mon, 09 Aug 2010 11:53:53 GMT
Aug 09 07:53:53 192.168.1.5 1730: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 1731: CSeq: 1 INVITE
Aug 09 07:53:53 192.168.1.5 1732: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 07:53:53 192.168.1.5 1759: Max-Forwards: 70
Aug 09 07:53:53 192.168.1.5 1760: To: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:53 192.168.1.5 1761: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:53 192.168.1.5 1762: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:53 192.168.1.5 1771: 068307: Aug  9 07:53:53.219 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 07:53:53 192.168.1.5 1772: 068308: Aug  9 07:53:53.219 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 35366, Transport 1, SentBy Port 5060
Aug 09 07:53:53 192.168.1.5 1835: 068346: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Aug 09 07:53:53 192.168.1.5 1836: 068347: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Aug 09 07:53:53 192.168.1.5 1837: 068348: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
Aug 09 07:53:53 192.168.1.5 1838: 068349: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
Aug 09 07:53:53 192.168.1.5 1839: 068350: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
Aug 09 07:53:53 192.168.1.5 1840: 068351: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Aug 09 07:53:53 192.168.1.5 1841: 068352: Aug  9 07:53:53.243 EDT: //-1/9DC11658A973/SIP/Info/sipSPIContinueNewMsgInvite: Calling name , number 5743060212, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 4081, oct3 0x00
Aug 09 07:53:53 192.168.1.5 1899: 068402: Aug  9 07:53:53.251 EDT: //5592/9DC11658A973/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 07:53:53 192.168.1.5 1900: 068403: Aug  9 07:53:53.251 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E4A5680, addr=192.168.3.2, port=5060, connId=0 for UDP
Aug 09 07:53:53 192.168.1.5 1901: 068404: Aug  9 07:53:53.251 EDT: //5592/9DC11658A973/SIP/State/sipSPIChangeState: 0x4A41CB68 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
Aug 09 07:53:53 192.168.1.5 1902: 068405: Aug  9 07:53:53.251 EDT: //5592/9DC11658A973/SIP/Info/sipSPIProcessContactInfo: Previous Hop 192.168.3.2:5060
Aug 09 07:53:53 192.168.1.5 1903: 068406: Aug  9 07:53:53.259 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:53 192.168.1.5 1904: Sent:
Aug 09 07:53:53 192.168.1.5 1905: SIP/2.0 100 Trying
Aug 09 07:53:53 192.168.1.5 1906: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3321
Aug 09 07:53:53 192.168.1.5 1907: From: <5743060212>;tag=cue9078751f
Aug 09 07:53:53 192.168.1.5 1908: To: <4081>
Aug 09 07:53:53 192.168.1.5 1909: Date: Mon, 09 Aug 2010 11:53:53 GMT
Aug 09 07:53:53 192.168.1.5 1910: Call-ID: 12813548332151079@192.168.3.2
Aug 09 07:53:53 192.168.1.5 1963: Sent:
Aug 09 07:53:53 192.168.1.5 1964: SIP/2.0 200 OK
Aug 09 07:53:53 192.168.1.5 1965: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3321
Aug 09 07:53:53 192.168.1.5 1966: From: <5743060212>;tag=cue9078751f
Aug 09 07:53:53 192.168.1.5 1967: To: <4081>;tag=1EC1CCEC-F53
Aug 09 07:53:53 192.168.1.5 1968: Date: Mon, 09 Aug 2010 11:53:53 GMT
Aug 09 07:53:53 192.168.1.5 1969: Call-ID: 12813548332151079@192.168.3.2
Aug 09 07:53:53 192.168.1.5 1970: CSeq: 1 INVITE
Aug 09 07:53:53 192.168.1.5 1971: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 07:53:53 192.168.1.5 1972: Allow-Events: telephone-event
Aug 09 07:53:53 192.168.1.5 2027: 068714: Aug  9 07:53:53.351 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A456F90) from EDB(0x4E6C1FA8)
Aug 09 07:53:53 192.168.1.5 2028: 068715: Aug  9 07:53:53.351 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A456F90) for reuse
Aug 09 07:53:53 192.168.1.5 2029: 068716: Aug  9 07:53:53.351 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
Aug 09 07:53:53 192.168.1.5 2030: 068717: Aug  9 07:53:53.359 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:54 192.168.1.5 2091: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Aug 09 07:53:54 192.168.1.5 2092: Supported: replaces
Aug 09 07:53:54 192.168.1.5 2093: Contact: <15744579485>
Aug 09 07:53:54 192.168.1.5 2094: Content-Length: 0
Aug 09 07:53:54 192.168.1.5 2095:
Aug 09 07:53:54 192.168.1.5 2096: 068831: Aug  9 07:53:53.415 EDT: //5589/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Aug 09 07:53:54 192.168.1.5 2097: 068832: Aug  9 07:53:53.415 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:54 192.168.1.5 2098: 068833: Aug  9 07:53:53.415 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:54 192.168.1.5 2099: 068834: Aug  9 07:53:53.415 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 07:53:54 192.168.1.5 2100: 068835: Aug  9 07:53:53.415 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4A44C280
Aug 09 07:53:54 192.168.1.5 2155: 068860: Aug  9 07:53:53.419 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
Aug 09 07:53:54 192.168.1.5 2156: 068861: Aug  9 07:53:53.419 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Aug 09 07:53:54 192.168.1.5 2157: 068862: Aug  9 07:53:53.419 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
Aug 09 07:53:54 192.168.1.5 2158: 068863: Aug  9 07:53:53.419 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
Aug 09 07:53:54 192.168.1.5 2159: 068864: Aug  9 07:53:53.419 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
Aug 09 07:53:54 192.168.1.5 2219: 068935: Aug  9 07:53:53.479 EDT: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
Aug 09 07:53:54 192.168.1.5 2220: 068936: Aug  9 07:53:53.479 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:54 192.168.1.5 2221: Received:
Aug 09 07:53:54 192.168.1.5 2222: SIP/2.0 200 OK
Aug 09 07:53:54 192.168.1.5 2223: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17B21DEB
Aug 09 07:53:54 192.168.1.5 2224: To: <5743060212>;tag=cuecb484d32
Aug 09 07:53:54 192.168.1.5 2225: From: "15744579485" <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:54 192.168.1.5 2226: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:54 192.168.1.5 2227: CSeq: 106 BYE
Aug 09 07:53:54 192.168.1.5 2228: Content-Length: 0
Aug 09 07:53:54 192.168.1.5 2229:
Aug 09 07:53:54 192.168.1.5 2230: 068937: Aug  9 07:53:53.479 EDT: //5590/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Aug 09 07:53:54 192.168.1.5 2283: 068966: Aug  9 07:53:53.483 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 07:53:54 192.168.1.5 2284: 068967: Aug  9 07:53:53.483 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A45744C) on EDB(0x4E58CAB8)
Aug 09 07:53:54 192.168.1.5 2285: 068968: Aug  9 07:53:53.483 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 2 TCB's on tcbQ
Aug 09 07:53:54 192.168.1.5 2286: 068969: Aug  9 07:53:53.483 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
Aug 09 07:53:54 192.168.1.5 2347: 069002: Aug  9 07:53:53.539 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:54 192.168.1.5 2366: 069009: Aug  9 07:53:53.539 EDT: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x4A45744C) on SCB(0x4E849D80)
Aug 09 07:53:54 192.168.1.5 2367: 069010: Aug  9 07:53:53.539 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
Aug 09 07:53:54 192.168.1.5 2368: 069011: Aug  9 07:53:53.539 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 2
Aug 09 07:53:54 192.168.1.5 2369: 069012: Aug  9 07:53:53.539 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A45744C) from EDB(0x4E58CAB8)
Aug 09 07:53:54 192.168.1.5 2370: 069013: Aug  9 07:53:53.539 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A45744C) for reuse
Aug 09 07:53:54 192.168.1.5 2371: 069014: Aug  9 07:53:53.539 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Transactions still active on Event:refer ID:
Aug 09 07:53:54 192.168.1.5 2372: 069015: Aug  9 07:53:54.031 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:54 192.168.1.5 2373: 069016: Aug  9 07:53:54.031 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:54 192.168.1.5 2374: 069017: Aug  9 07:53:54.031 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:54 192.168.1.5 2375: 069018: Aug  9 07:53:54.031 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:54 192.168.1.5 2376: Received:
Aug 09 07:53:54 192.168.1.5 2377: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:53:54 192.168.1.5 2378: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:53:54 192.168.1.5 2379: Max-Forwards: 70
Aug 09 07:53:54 192.168.1.5 2380: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:54 192.168.1.5 2381: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:54 192.168.1.5 2382: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:54 192.168.1.5 2383: CSeq: 6 SUBSCRIBE
Aug 09 07:53:54 192.168.1.5 2384: Content-Length: 0
Aug 09 07:53:54 192.168.1.5 2385: Contact: <5743060212>
Aug 09 07:53:54 192.168.1.5 2386: Expires: 0
Aug 09 07:53:54 192.168.1.5 2387: Event: refer;id=2
Aug 09 07:53:54 192.168.1.5 2388:
Aug 09 07:53:54 192.168.1.5 2389: 069019: Aug  9 07:53:54.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:53:54 192.168.1.5 2390: 069020: Aug  9 07:53:54.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:54 192.168.1.5 2391: 069021: Aug  9 07:53:54.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:54 192.168.1.5 2392: 069022: Aug  9 07:53:54.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:54 192.168.1.5 2393: 069023: Aug  9 07:53:54.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:55 192.168.1.5 2394: 069024: Aug  9 07:53:54.035 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:53:55 192.168.1.5 2395: 069025: Aug  9 07:53:54.035 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:53:55 192.168.1.5 2396: 069026: Aug  9 07:53:54.035 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:53:55 192.168.1.5 2397: 069027: Aug  9 07:53:55.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:55 192.168.1.5 2398: 069028: Aug  9 07:53:55.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:55 192.168.1.5 2399: 069029: Aug  9 07:53:55.035 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:55 192.168.1.5 2400: 069030: Aug  9 07:53:55.035 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:55 192.168.1.5 2401: Received:
Aug 09 07:53:55 192.168.1.5 2402: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:53:55 192.168.1.5 2403: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:53:55 192.168.1.5 2404: Max-Forwards: 70
Aug 09 07:53:55 192.168.1.5 2405: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:55 192.168.1.5 2406: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:55 192.168.1.5 2407: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:55 192.168.1.5 2408: CSeq: 6 SUBSCRIBE
Aug 09 07:53:55 192.168.1.5 2409: Content-Length: 0
Aug 09 07:53:55 192.168.1.5 2410: Contact: <5743060212>
Aug 09 07:53:55 192.168.1.5 2411: Expires: 0
Aug 09 07:53:55 192.168.1.5 2412: Event: refer;id=2
Aug 09 07:53:55 192.168.1.5 2413:
Aug 09 07:53:55 192.168.1.5 2414: 069031: Aug  9 07:53:55.035 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:53:55 192.168.1.5 2415: 069032: Aug  9 07:53:55.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:55 192.168.1.5 2416: 069033: Aug  9 07:53:55.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:55 192.168.1.5 2417: 069034: Aug  9 07:53:55.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:55 192.168.1.5 2418: 069035: Aug  9 07:53:55.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:55 192.168.1.5 2419: 069036: Aug  9 07:53:55.039 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:53:55 192.168.1.5 2420: 069037: Aug  9 07:53:55.039 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:53:55 192.168.1.5 2421: 069038: Aug  9 07:53:55.039 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:53:55 192.168.1.5 2422: 069039: Aug  9 07:53:55.447 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISASSOCIATE
Aug 09 07:53:55 192.168.1.5 2423: 069040: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_bridge: confID = 1320, srcCallID = 5592, dstCallID = 5593
Aug 09 07:53:55 192.168.1.5 2424: 069041: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 5592/5593
Aug 09 07:53:55 192.168.1.5 2425: 069042: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=5592
Aug 09 07:53:55 192.168.1.5 2426: 069043: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
Aug 09 07:53:55 192.168.1.5 2427: 069044: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1087774392, ccb xmitFunc = 1087774392
Aug 09 07:53:55 192.168.1.5 2428: 069045: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Aug 09 07:53:55 192.168.1.5 2429: 069046: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Aug 09 07:53:55 192.168.1.5 2430: 069047: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: Entry
Aug 09 07:53:55 192.168.1.5 2431: 069048: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: Negotiation not done yet:: Load DSP with preferred codec : g711ulaw, Bytes=160, payload: 0
Aug 09 07:53:55 192.168.1.5 2432: 069049: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
Aug 09 07:53:55 192.168.1.5 2433: 069050: Aug  9 07:53:55.447 EDT: //5592/9DC11658A973/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
Aug 09 07:53:55 192.168.1.5 2434: 069051: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=5593
Aug 09 07:53:55 192.168.1.5 2435: 069052: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
Aug 09 07:53:55 192.168.1.5 2436: 069053: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Aug 09 07:53:55 192.168.1.5 2437: 069054: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sip_set_modem_caps: Negotiation NOT yet Done. Set the configured values and generate SDP Xcap list
Aug 09 07:53:55 192.168.1.5 2438: 069055: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Aug 09 07:53:55 192.168.1.5 2439: 069056: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sip_set_modem_caps: nse payload = 100, ptru mode = 0, ptru-codec=0, redundancy=0, xid=1, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Aug 09 07:53:55 192.168.1.5 2440: 069057: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
Aug 09 07:53:55 192.168.1.5 2441: 069058: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
Aug 09 07:53:55 192.168.1.5 2442: 069059: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Media/sipSPISetStreamInfo:
Aug 09 07:53:55 192.168.1.5 2443: caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
Aug 09 07:53:55 192.168.1.5 2444: 069060: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
Aug 09 07:53:55 192.168.1.5 2445: 069061: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
Aug 09 07:53:55 192.168.1.5 2446: 069062: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
Aug 09 07:53:55 192.168.1.5 2447: 069063: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x203
Aug 09 07:53:55 192.168.1.5 2448: 069064: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/sipSPISrtpTranscoder:
Aug 09 07:53:55 192.168.1.5 2449:  Checking if transcoder is needed for SRTP-RTP
Aug 09 07:53:55 192.168.1.5 2450: 069065: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ind: Calling cc_api_caps_ack()
Aug 09 07:53:55 192.168.1.5 2451: 069066: Aug  9 07:53:55.451 EDT: //5592/9DC11658A973/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
Aug 09 07:53:55 192.168.1.5 2452: 069067: Aug  9 07:53:55.455 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
Aug 09 07:53:55 192.168.1.5 2453: 069068: Aug  9 07:53:55.455 EDT: //5592//TCL :/tcl_PutsObjCmd:
Aug 09 07:53:55 192.168.1.5 2454:  proc act_CallSetupDone
Aug 09 07:53:55 192.168.1.5 2455: 069069: Aug  9 07:53:55.455 EDT:
Aug 09 07:53:55 192.168.1.5 2456: 069070: Aug  9 07:53:55.455 EDT: //5592//TCL :/tcl_PutsObjCmd:
Aug 09 07:53:55 192.168.1.5 2457:  IP IVR Leg Setup Status = ls_000
Aug 09 07:53:55 192.168.1.5 2458: 069071: Aug  9 07:53:55.455 EDT:
Aug 09 07:53:55 192.168.1.5 2459: 069072: Aug  9 07:53:55.455 EDT: //5592//TCL :/tcl_PutsObjCmd: TCL AA: >> Call answered by the agent; Call Connected <<
Aug 09 07:53:55 192.168.1.5 2460: 069073: Aug  9 07:53:55.459 EDT: //5592//TCL :/tcl_PutsObjCmd: TCL AA: >>> Incoming LEG ID = 5592 5589; Outgoing LEG ID = 5593 <<<
Aug 09 07:53:55 192.168.1.5 2461: 069074: Aug  9 07:53:55.459 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 15
Aug 09 07:53:55 192.168.1.5 2462: 069075: Aug  9 07:53:55.459 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
Aug 09 07:53:55 192.168.1.5 2463: 069076: Aug  9 07:53:55.463 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Time to Answer = 2 Seconds<<<
Aug 09 07:53:55 192.168.1.5 2464: 069077: Aug  9 07:53:55.467 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_4927072C_0_516017376 {CALL_HANDOFF} {1281354835}} <<<
Aug 09 07:53:55 192.168.1.5 2465: 069078: Aug  9 07:53:55.467 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Aug 09 07:53:55 192.168.1.5 2466: 069079: Aug  9 07:53:55.467 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug 09 07:53:55 192.168.1.5 2467: 069080: Aug  9 07:53:55.471 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Aug 09 07:53:55 192.168.1.5 2468: 069081: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 07:53:55 192.168.1.5 2469: 069082: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
Aug 09 07:53:55 192.168.1.5 2470: 069083: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
Aug 09 07:53:55 192.168.1.5 2471: 069084: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_GetPassthruDataFromTdContainer:  Could not get any elements from TD Container
Aug 09 07:53:55 192.168.1.5 2472: 069085: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIPushOrigRequestContainerIntoHolder: Request Container Holder is above threshold...trimming
Aug 09 07:53:55 192.168.1.5 2473: 069086: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 07:53:55 192.168.1.5 2474: 069087: Aug  9 07:53:55.471 EDT: //5589/979C2F62A96C/SIP/Info/sipSPISendBye: Associated container=0x4D906BEC to Bye
Aug 09 07:53:55 192.168.1.5 2475: 069088: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
Aug 09 07:53:55 192.168.1.5 2476: 069089: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
Aug 09 07:53:55 192.168.1.5 2477: 069090: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipSPITransportSendMessage: msg=0x4E49946C, addr=64.255.123.18, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x4193AD70
Aug 09 07:53:55 192.168.1.5 2478: 069091: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 07:53:55 192.168.1.5 2479: 069092: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 07:53:55 192.168.1.5 2480: 069093: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E49946C
Aug 09 07:53:55 192.168.1.5 2481: 069094: Aug  9 07:53:55.475 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E49946C, addr=64.255.123.18, port=5060, connId=3 for UDP
Aug 09 07:53:55 192.168.1.5 2482: 069095: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
Aug 09 07:53:55 192.168.1.5 2483: 069096: Aug  9 07:53:55.475 EDT: //5589/979C2F62A96C/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Aug 09 07:53:55 192.168.1.5 2484: 069097: Aug  9 07:53:55.475 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:55 192.168.1.5 2485: Sent:
Aug 09 07:53:55 192.168.1.5 2486: BYE sip:15744579485@64.255.123.18:5060 SIP/2.0
Aug 09 07:53:55 192.168.1.5 2487: Via: SIP/2.0/UDP 74.84.117.204:5060;branch=z9hG4bK17B5982
Aug 09 07:53:55 192.168.1.5 2488: From: <>5743060212@white.u4voip.com>;tag=1EC1A514-118E
Aug 09 07:53:55 192.168.1.5 2489: To: "15744579485" <15744579485>;tag=as2792349d
Aug 09 07:53:55 192.168.1.5 2490: Date: Mon, 09 Aug 2010 11:53:53 GMT
Aug 09 07:53:55 192.168.1.5 2491: Call-ID: 156444e465ee42093bddaeca168937b6@64.255.123.18
Aug 09 07:53:55 192.168.1.5 2492: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 07:53:55 192.168.1.5 2493: Max-Forwards: 70
Aug 09 07:53:55 192.168.1.5 2494: Timestamp: 1281354835
Aug 09 07:53:55 192.168.1.5 2495: CSeq: 103 BYE
Aug 09 07:53:55 192.168.1.5 2496: Reason: Q.850;cause=47
Aug 09 07:53:55 192.168.1.5 2497: Content-Length: 0
Aug 09 07:53:55 192.168.1.5 2498:
Aug 09 07:53:55 192.168.1.5 2499: 069098: Aug  9 07:53:55.479 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD ++ Service Counter = 41 ++
Aug 09 07:53:55 192.168.1.5 2500: 069099: Aug  9 07:53:55.479 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ 4080 Queue Length = 0 +++
Aug 09 07:53:55 192.168.1.5 2501: 069100: Aug  9 07:53:55.479 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> 4080 Queue Length = 0 <<<
Aug 09 07:53:55 192.168.1.5 2502: 069101: Aug  9 07:53:55.479 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Queue 4080 is Empty <<<
Aug 09 07:53:55 192.168.1.5 2503: 069102: Aug  9 07:53:55.479 EDT: //5592/9DC11658A973/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Aug 09 07:53:55 192.168.1.5 2504: 069103: Aug  9 07:53:55.479 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug 09 07:53:55 192.168.1.5 2505: 069104: Aug  9 07:53:55.483 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Aug 09 07:53:55 192.168.1.5 2506: 069105: Aug  9 07:53:55.483 EDT: //5592/9DC11658A973/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 07:53:55 192.168.1.5 2522: From: <4081>;tag=1EC1CCEC-F53
Aug 09 07:53:55 192.168.1.5 2523: To: <5743060212>;tag=cue9078751f
Aug 09 07:53:55 192.168.1.5 2560: Calling Number           : 5743060212
Aug 09 07:53:55 192.168.1.5 2561: Called Number            : 4081
Aug 09 07:53:55 192.168.1.5 2578: Orig Destn IP Address:Port (Media): [ - ]:0
Aug 09 07:53:55 192.168.1.5 2579: 069133: Aug  9 07:53:55.511 EDT: //5592/9DC11658A973/SIP/Call/sipSPICallInfo:
Aug 09 07:53:55 192.168.1.5 2580: Disconnect Cause (CC)    : 16
Aug 09 07:53:55 192.168.1.5 2581: Disconnect Cause (SIP)   : 200
Aug 09 07:53:55 192.168.1.5 2582: 069134: Aug  9 07:53:55.511 EDT: //5592/9DC11658A973/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 15D8
Aug 09 07:53:55 192.168.1.5 2583: 069135: Aug  9 07:53:55.511 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[2578] removed.
Aug 09 07:53:55 192.168.1.5 2612: 069164: Aug  9 07:53:55.515 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 07:53:55 192.168.1.5 2613: 069165: Aug  9 07:53:55.515 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E66FBE8
Aug 09 07:53:55 192.168.1.5 2614: 069166: Aug  9 07:53:55.515 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E66FBE8, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 07:53:55 192.168.1.5 2626: From: <4081>;tag=1EC1CCEC-F53
Aug 09 07:53:55 192.168.1.5 2627: To: <5743060212>;tag=cue9078751f
Aug 09 07:53:55 192.168.1.5 2660: 069184: Aug  9 07:53:55.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:55 192.168.1.5 2661: 069185: Aug  9 07:53:55.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:55 192.168.1.5 2662: 069186: Aug  9 07:53:55.523 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 1
Aug 09 07:53:55 192.168.1.5 2663: 069187: Aug  9 07:53:55.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457124
Aug 09 07:53:55 192.168.1.5 2664: 069188: Aug  9 07:53:55.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBServerMarker: Server TCB's Marker Updated to: 3SUBSCRIBEz9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3323
Aug 09 07:53:55 192.168.1.5 2708: Call-ID: 12813548332151079@192.168.3.2
Aug 09 07:53:55 192.168.1.5 2709: CSeq: 103 NOTIFY
Aug 09 07:53:56 192.168.1.5 2710: Content-Length: 0
Aug 09 07:53:56 192.168.1.5 2743:
Aug 09 07:53:56 192.168.1.5 2744: 069233: Aug  9 07:53:55.563 EDT: //5589/979C2F62A96C/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
Aug 09 07:53:56 192.168.1.5 2765: Negotiated Dtmf-relay    : 6
Aug 09 07:53:56 192.168.1.5 2766: Dtmf-relay Payload       : 101 (tx), 101 (rx)
Aug 09 07:53:56 192.168.1.5 2783: 069248: Aug  9 07:53:55.567 EDT: //5589/979C2F62A96C/SIP/Info/ccsip_qos_cleanup: Entry
Aug 09 07:53:56 192.168.1.5 2784: 069249: Aug  9 07:53:55.567 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
Aug 09 07:53:56 192.168.1.5 2785: 069250: Aug  9 07:53:55.567 EDT: //5589/979C2F62A96C/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Aug 09 07:53:56 192.168.1.5 2786: 069251: Aug  9 07:53:55.567 EDT: //5589/979C2F62A96C/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4A44C280
Aug 09 07:53:56 192.168.1.5 2787: 069252: Aug  9 07:53:55.567 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[2575]
Aug 09 07:53:57 192.168.1.5 2788: 069253: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:53:57 192.168.1.5 2789: 069254: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:53:57 192.168.1.5 2790: 069255: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:53:57 192.168.1.5 2791: 069256: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:53:57 192.168.1.5 2792: Received:
Aug 09 07:53:57 192.168.1.5 2793: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:53:57 192.168.1.5 2794: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:53:57 192.168.1.5 2795: Max-Forwards: 70
Aug 09 07:53:57 192.168.1.5 2796: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:53:57 192.168.1.5 2797: From: <5743060212>;tag=cuecb484d32
Aug 09 07:53:57 192.168.1.5 2798: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:53:57 192.168.1.5 2799: CSeq: 6 SUBSCRIBE
Aug 09 07:53:57 192.168.1.5 2800: Content-Length: 0
Aug 09 07:53:57 192.168.1.5 2801: Contact: <5743060212>
Aug 09 07:53:57 192.168.1.5 2802: Expires: 0
Aug 09 07:53:57 192.168.1.5 2803: Event: refer;id=2
Aug 09 07:53:57 192.168.1.5 2804:
Aug 09 07:53:57 192.168.1.5 2805: 069257: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:53:57 192.168.1.5 2806: 069258: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:57 192.168.1.5 2807: 069259: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:53:57 192.168.1.5 2808: 069260: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:53:57 192.168.1.5 2809: 069261: Aug  9 07:53:57.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:53:58 192.168.1.5 2810: 069262: Aug  9 07:53:57.039 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:53:58 192.168.1.5 2811: 069263: Aug  9 07:53:57.039 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:53:58 192.168.1.5 2812: 069264: Aug  9 07:53:57.039 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:53:58 192.168.1.5 2813: 069265: Aug  9 07:53:57.923 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x4E7AFCBC Connection=0x49A645DC, addr=192.168.3.2, port=5060, connid=2 has been REFRESHED
Aug 09 07:53:58 192.168.1.5 2814: 069266: Aug  9 07:53:57.923 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4E7AFCBC,addr=192.168.3.2
Aug 09 07:54:01 192.168.1.5 2815: 069267: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:54:01 192.168.1.5 2816: 069268: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:54:01 192.168.1.5 2817: 069269: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:54:01 192.168.1.5 2818: 069270: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:54:01 192.168.1.5 2819: Received:
Aug 09 07:54:01 192.168.1.5 2820: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:54:01 192.168.1.5 2821: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:54:01 192.168.1.5 2822: Max-Forwards: 70
Aug 09 07:54:01 192.168.1.5 2823: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:54:01 192.168.1.5 2824: From: <5743060212>;tag=cuecb484d32
Aug 09 07:54:01 192.168.1.5 2825: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:54:01 192.168.1.5 2826: CSeq: 6 SUBSCRIBE
Aug 09 07:54:01 192.168.1.5 2827: Content-Length: 0
Aug 09 07:54:01 192.168.1.5 2828: Contact: <5743060212>
Aug 09 07:54:01 192.168.1.5 2829: Expires: 0
Aug 09 07:54:01 192.168.1.5 2830: Event: refer;id=2
Aug 09 07:54:01 192.168.1.5 2831:
Aug 09 07:54:01 192.168.1.5 2832: 069271: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:54:01 192.168.1.5 2833: 069272: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:01 192.168.1.5 2834: 069273: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:01 192.168.1.5 2835: 069274: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:54:01 192.168.1.5 2836: 069275: Aug  9 07:54:01.043 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:54:02 192.168.1.5 2837: 069276: Aug  9 07:54:01.047 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:54:02 192.168.1.5 2838: 069277: Aug  9 07:54:01.047 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:54:02 192.168.1.5 2839: 069278: Aug  9 07:54:01.047 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:54:03 192.168.1.5 2840: 069279: Aug  9 07:54:02.763 EDT: %SEC-6-IPACCESSLOGP: list 104 denied udp 74.84.119.150(53) -> 74.84.117.204(12386), 1 packet
Aug 09 07:54:05 192.168.1.5 2841: 069280: Aug  9 07:54:03.995 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x4E421750 Connection=0x49094E1C, addr=64.255.123.18, port=5060, connid=3 has been REFRESHED
Aug 09 07:54:05 192.168.1.5 2842: 069281: Aug  9 07:54:03.995 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4E421750,addr=64.255.123.18
Aug 09 07:54:05 192.168.1.5 2843: 069282: Aug  9 07:54:05.047 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:54:05 192.168.1.5 2844: 069283: Aug  9 07:54:05.047 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:54:05 192.168.1.5 2845: 069284: Aug  9 07:54:05.047 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:54:05 192.168.1.5 2846: 069285: Aug  9 07:54:05.047 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:54:05 192.168.1.5 2847: Received:
Aug 09 07:54:05 192.168.1.5 2848: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:54:05 192.168.1.5 2849: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:54:05 192.168.1.5 2850: Max-Forwards: 70
Aug 09 07:54:05 192.168.1.5 2851: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:54:05 192.168.1.5 2852: From: <5743060212>;tag=cuecb484d32
Aug 09 07:54:05 192.168.1.5 2853: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:54:05 192.168.1.5 2854: CSeq: 6 SUBSCRIBE
Aug 09 07:54:05 192.168.1.5 2855: Content-Length: 0
Aug 09 07:54:05 192.168.1.5 2856: Contact: <5743060212>
Aug 09 07:54:05 192.168.1.5 2857: Expires: 0
Aug 09 07:54:05 192.168.1.5 2858: Event: refer;id=2
Aug 09 07:54:05 192.168.1.5 2859:
Aug 09 07:54:05 192.168.1.5 2860: 069286: Aug  9 07:54:05.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:54:05 192.168.1.5 2861: 069287: Aug  9 07:54:05.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:05 192.168.1.5 2862: 069288: Aug  9 07:54:05.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:05 192.168.1.5 2863: 069289: Aug  9 07:54:05.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:54:05 192.168.1.5 2864: 069290: Aug  9 07:54:05.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:54:06 192.168.1.5 2865: 069291: Aug  9 07:54:05.051 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:54:06 192.168.1.5 2866: 069292: Aug  9 07:54:05.051 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:54:06 192.168.1.5 2867: 069293: Aug  9 07:54:05.051 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:54:09 192.168.1.5 2868: 069294: Aug  9 07:54:09.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:54:09 192.168.1.5 2869: 069295: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:54:09 192.168.1.5 2870: 069296: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:54:09 192.168.1.5 2871: 069297: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:54:09 192.168.1.5 2872: Received:
Aug 09 07:54:09 192.168.1.5 2873: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:54:09 192.168.1.5 2874: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:54:09 192.168.1.5 2875: Max-Forwards: 70
Aug 09 07:54:09 192.168.1.5 2876: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:54:09 192.168.1.5 2877: From: <5743060212>;tag=cuecb484d32
Aug 09 07:54:09 192.168.1.5 2878: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:54:09 192.168.1.5 2879: CSeq: 6 SUBSCRIBE
Aug 09 07:54:09 192.168.1.5 2880: Content-Length: 0
Aug 09 07:54:09 192.168.1.5 2881: Contact: <5743060212>
Aug 09 07:54:09 192.168.1.5 2882: Expires: 0
Aug 09 07:54:09 192.168.1.5 2883: Event: refer;id=2
Aug 09 07:54:09 192.168.1.5 2884:
Aug 09 07:54:09 192.168.1.5 2885: 069298: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:54:09 192.168.1.5 2886: 069299: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:09 192.168.1.5 2887: 069300: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:09 192.168.1.5 2888: 069301: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:54:09 192.168.1.5 2889: 069302: Aug  9 07:54:09.055 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:54:09 192.168.1.5 2890: 069303: Aug  9 07:54:09.055 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:54:09 192.168.1.5 2891: 069304: Aug  9 07:54:09.055 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:54:09 192.168.1.5 2892: 069305: Aug  9 07:54:09.055 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 07:54:10 192.168.1.5 2893: 069306: Aug  9 07:54:09.803 EDT: %SEC-6-IPACCESSLOGP: list 104 denied udp 66.170.44.10(53) -> 74.84.117.204(12386), 1 packet
Aug 09 07:54:13 192.168.1.5 2894: 069307: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35366
Aug 09 07:54:13 192.168.1.5 2895: 069308: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 07:54:13 192.168.1.5 2896: 069309: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 07:54:13 192.168.1.5 2897: 069310: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 07:54:13 192.168.1.5 2898: Received:
Aug 09 07:54:13 192.168.1.5 2899: SUBSCRIBE sip:15744579485@192.168.3.1:5060 SIP/2.0
Aug 09 07:54:13 192.168.1.5 2900: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3327
Aug 09 07:54:13 192.168.1.5 2901: Max-Forwards: 70
Aug 09 07:54:13 192.168.1.5 2902: To: <15744579485>;tag=1EC1A4BC-0
Aug 09 07:54:13 192.168.1.5 2903: From: <5743060212>;tag=cuecb484d32
Aug 09 07:54:13 192.168.1.5 2904: Call-ID: 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.1
Aug 09 07:54:13 192.168.1.5 2905: CSeq: 6 SUBSCRIBE
Aug 09 07:54:13 192.168.1.5 2906: Content-Length: 0
Aug 09 07:54:13 192.168.1.5 2907: Contact: <5743060212>
Aug 09 07:54:13 192.168.1.5 2908: Expires: 0
Aug 09 07:54:13 192.168.1.5 2909: Event: refer;id=2
Aug 09 07:54:13 192.168.1.5 2910:
Aug 09 07:54:13 192.168.1.5 2911: 069311: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 07:54:13 192.168.1.5 2912: 069312: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:13 192.168.1.5 2913: 069313: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 97A38273-A2E311DF-A972A2EC-4EA10D61@192.168.3.11EC1A4BC-0
Aug 09 07:54:13 192.168.1.5 2914: 069314: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 07:54:13 192.168.1.5 2915: 069315: Aug  9 07:54:13.060 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 07:54:14 192.168.1.5 2916: 069316: Aug  9 07:54:13.060 EDT: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 07:54:14 192.168.1.5 2917: 069317: Aug  9 07:54:13.060 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 07:54:14 192.168.1.5 2918: 069318: Aug  9 07:54:13.060 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
And here is an internal call to the auto attendant.
Aug 09 08:02:41 192.168.1.5 3019: 069393: Aug  9 08:02:40.366 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
Aug 09 08:02:54 192.168.1.5 3020: 069394: Aug  9 08:02:54.515 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4A44C280) with key=[2580] to table
Aug 09 08:02:54 192.168.1.5 3021: 069395: Aug  9 08:02:54.519 EDT: //5599/000000000000/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Aug 09 08:02:54 192.168.1.5 3022: 069396: Aug  9 08:02:54.519 EDT: //5599/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Aug 09 08:02:54 192.168.1.5 3023: 069397: Aug  9 08:02:54.519 EDT: //5599/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 5599, peer_callID = 5598
Aug 09 08:02:54 192.168.1.5 3024: 069398: Aug  9 08:02:54.519 EDT: //5599/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 5599, peer_callID = 5598
Aug 09 08:02:54 192.168.1.5 3025: 069399: Aug  9 08:02:54.519 EDT: //5599/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Aug 09 08:02:54 192.168.1.5 3026: 069400: Aug  9 08:02:54.519 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.3.2 target_port : 5060
Aug 09 08:02:54 192.168.1.5 3027: 069401: Aug  9 08:02:54.519 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Aug 09 08:02:54 192.168.1.5 3028: 069402: Aug  9 08:02:54.519 EDT: //5599/DF196693A97A/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [51]
Aug 09 08:02:54 192.168.1.5 3029: 069403: Aug  9 08:02:54.519 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Aug 09 08:02:54 192.168.1.5 3030: 069404: Aug  9 08:02:54.519 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 15DF to table
Aug 09 08:02:54 192.168.1.5 3031: 069405: Aug  9 08:02:54.519 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Aug 09 08:02:54 192.168.1.5 3032: 069406: Aug  9 08:02:54.519 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Aug 09 08:02:54 192.168.1.5 3033: 069407: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Aug 09 08:02:54 192.168.1.5 3034: 069408: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: Not using Voice Class Codec
Aug 09 08:02:54 192.168.1.5 3035: 069409: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Aug 09 08:02:54 192.168.1.5 3036: 069410: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Aug 09 08:02:54 192.168.1.5 3037: 069411: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=5598
Aug 09 08:02:54 192.168.1.5 3038: 069412: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
Aug 09 08:02:54 192.168.1.5 3039: 069413: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
Aug 09 08:02:54 192.168.1.5 3040: 069414: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Aug 09 08:02:54 192.168.1.5 3041: 069415: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/preprocessSetup:
Aug 09 08:02:54 192.168.1.5 3042:  This is a not a SIGO Call -, could be DM call
Aug 09 08:02:54 192.168.1.5 3043: 069416: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Aug 09 08:02:54 192.168.1.5 3044: 069417: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.3.1
Aug 09 08:02:54 192.168.1.5 3045: 069418: Aug  9 08:02:54.523 EDT: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19422 for stream 1
Aug 09 08:02:54 192.168.1.5 3046: 069419: Aug  9 08:02:54.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Aug 09 08:02:54 192.168.1.5 3047: 069420: Aug  9 08:02:54.523 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Aug 09 08:02:54 192.168.1.5 3048: 069421: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Aug 09 08:02:54 192.168.1.5 3049: 069422: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Aug 09 08:02:54 192.168.1.5 3050: 069423: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Aug 09 08:02:54 192.168.1.5 3051: 069424: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Aug 09 08:02:54 192.168.1.5 3052: 069425: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Aug 09 08:02:54 192.168.1.5 3053: 069426: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Aug 09 08:02:54 192.168.1.5 3054: 069427: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Aug 09 08:02:54 192.168.1.5 3055: 069428: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Aug 09 08:02:54 192.168.1.5 3056: 069429: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Aug 09 08:02:54 192.168.1.5 3057: 069430: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '5743060212' with callid: 5599
Aug 09 08:02:54 192.168.1.5 3058: 069431: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Aug 09 08:02:54 192.168.1.5 3059: 069432: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Aug 09 08:02:54 192.168.1.5 3060: 069433: Aug  9 08:02:54.523 EDT: //5599/DF196693A97A/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
Aug 09 08:02:54 192.168.1.5 3061: 069434: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/act_idle_continue_call_setup:
Aug 09 08:02:54 192.168.1.5 3062: 069435: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Aug 09 08:02:54 192.168.1.5 3063: 069436: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Aug 09 08:02:54 192.168.1.5 3064: 069437: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4A44C280 key=E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:54 192.168.1.5 3065: 069438: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:54 192.168.1.5 3066: 069439: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Transport 1, SentBy Port 5060
Aug 09 08:02:54 192.168.1.5 3067: 069440: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 08:02:54 192.168.1.5 3068: 069441: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
Aug 09 08:02:54 192.168.1.5 3069: SIP: (5599) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug 09 08:02:54 192.168.1.5 3070: 069442: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Aug 09 08:02:54 192.168.1.5 3071: 069443: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Info/sipSPISendInvite: Associated container=0x4D90905C to Invite
Aug 09 08:02:54 192.168.1.5 3072: 069444: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Aug 09 08:02:54 192.168.1.5 3073: 069445: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Aug 09 08:02:54 192.168.1.5 3074: 069446: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: msg=0x4E49946C, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41939F7C
Aug 09 08:02:54 192.168.1.5 3075: 069447: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:02:54 192.168.1.5 3076: 069448: Aug  9 08:02:54.527 EDT: //5599/DF196693A97A/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 08:02:54 192.168.1.5 3077: 069449: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4E3AA678,addr=192.168.3.2
Aug 09 08:02:54 192.168.1.5 3078: 069450: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnHolder: Created new holder=0x4E3AA678, addr=192.168.3.2; nailed=FALSE
Aug 09 08:02:54 192.168.1.5 3079: 069451: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting UDP conn create request for addr=192.168.3.2, port=5060, context=0x498B580C
Aug 09 08:02:54 192.168.1.5 3080: 069452: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer: Wait timer set for connection=0x49B088DC,addr=192.168.3.2, port=5060
Aug 09 08:02:54 192.168.1.5 3081: 069453: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetConnWaitTimer:
Aug 09 08:02:54 192.168.1.5 3082: Wait Conn Timer started for 5000 msec
Aug 09 08:02:54 192.168.1.5 3083: 069454: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnInstance: Created new initiated conn=0x49B088DC, connid=-1, addr=192.168.3.2, port=5060, transport=UDP
Aug 09 08:02:54 192.168.1.5 3084: 069455: Aug  9 08:02:54.527 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceGetConnectionId: Registering gcb=0x4A44C280 with connection=0x49B088DC
Aug 09 08:02:54 192.168.1.5 3085: 069456: Aug  9 08:02:54.531 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: Deferred sending msg=0x4E49946C
Aug 09 08:02:54 192.168.1.5 3086: 069457: Aug  9 08:02:54.535 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 58
Aug 09 08:02:54 192.168.1.5 3112: INVITE sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 08:02:54 192.168.1.5 3113: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17B82399
Aug 09 08:02:54 192.168.1.5 3114: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:02:54 192.168.1.5 3115: To: <5743060212>
Aug 09 08:02:54 192.168.1.5 3116: Date: Mon, 09 Aug 2010 12:02:54 GMT
Aug 09 08:02:54 192.168.1.5 3117: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:54 192.168.1.5 3118: Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Aug 09 08:02:54 192.168.1.5 3153: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:02:54 192.168.1.5 3154: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:54 192.168.1.5 3161: 069485: Aug  9 08:02:54.563 EDT: //5599/DF196693A97A/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Aug 09 08:02:54 192.168.1.5 3162: 069486: Aug  9 08:02:54.607 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:02:54 192.168.1.5 3163: 069487: Aug  9 08:02:54.607 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:02:54 192.168.1.5 3164: 069488: Aug  9 08:02:54.607 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:02:54 192.168.1.5 3167: Received:
Aug 09 08:02:54 192.168.1.5 3168: SIP/2.0 180 Ringing
Aug 09 08:02:54 192.168.1.5 3169: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17B82399
Aug 09 08:02:54 192.168.1.5 3178: 069492: Aug  9 08:02:54.611 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 08:02:54 192.168.1.5 3179: 069493: Aug  9 08:02:54.611 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
Aug 09 08:02:54 192.168.1.5 3187: 069501: Aug  9 08:02:54.611 EDT: //5599/DF196693A97A/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
Aug 09 08:02:54 192.168.1.5 3188: 069502: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:02:54 192.168.1.5 3189: 069503: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:02:54 192.168.1.5 3190: 069504: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:02:54 192.168.1.5 3191: 069505: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 08:02:54 192.168.1.5 3192: 069506: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:02:54 192.168.1.5 3193: Received:
Aug 09 08:02:54 192.168.1.5 3194: SIP/2.0 200 OK
Aug 09 08:02:54 192.168.1.5 3195: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17B82399
Aug 09 08:02:54 192.168.1.5 3196: To: <5743060212>;tag=cueefb1b7bf
Aug 09 08:02:54 192.168.1.5 3197: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:02:54 192.168.1.5 3198: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:54 192.168.1.5 3199: CSeq: 101 INVITE
Aug 09 08:02:54 192.168.1.5 3200: Content-Length: 172
Aug 09 08:02:54 192.168.1.5 3201: Contact: <5743060212>
Aug 09 08:02:54 192.168.1.5 3202: Content-Type: application/sdp
Aug 09 08:02:54 192.168.1.5 3203: Call-Info: <192.168.3.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Aug 09 08:02:54 192.168.1.5 3204: Allow-Events: telephone-event
Aug 09 08:02:54 192.168.1.5 3205:
Aug 09 08:02:54 192.168.1.5 3206: v=0
Aug 09 08:02:54 192.168.1.5 3207: o=CiscoSystemsSIP-Workflow-A
Aug 09 08:02:54 192.168.1.5 3208: pp-UserAgent 74 74 IN IP4 192.168.3.2
Aug 09 08:02:54 192.168.1.5 3209: s=SIP Call
Aug 09 08:02:54 192.168.1.5 3210: c=IN IP4 192.168.3.2
Aug 09 08:02:54 192.168.1.5 3211: t=0 0
Aug 09 08:02:54 192.168.1.5 3212: m=audio 16904 RTP/AVP 0
Aug 09 08:02:54 192.168.1.5 3213: a=rtpmap:0 pcmu/8000
Aug 09 08:02:54 192.168.1.5 3214: a=ptime:20
Aug 09 08:02:54 192.168.1.5 3215: 069507: Aug  9 08:02:54.675 EDT: //5599/DF196693A97A/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Aug 09 08:02:55 192.168.1.5 3216: 069508: Aug  9 08:02:54.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Aug 09 08:02:55 192.168.1.5 3217: 069509: Aug  9 08:02:54.675 EDT: //5599/DF196693A97A/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
Aug 09 08:02:55 192.168.1.5 3218: 069510: Aug  9 08:02:54.675 EDT: //5599/DF196693A97A/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
Aug 09 08:02:55 192.168.1.5 3219: 069511: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Callinfo parsed - Destination url = <192.168.3.2:5060>, duration = 2000
Aug 09 08:02:55 192.168.1.5 3220: 069512: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
Aug 09 08:02:55 192.168.1.5 3221: 069513: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPICompareRespMediaInfo: No Comparsion needed as 18x response SDP is either absent or ignored
Aug 09 08:02:55 192.168.1.5 3222: 069514: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
Aug 09 08:02:55 192.168.1.5 3223: SIP: Attribute mid, level 1 instance 1 not found.
Aug 09 08:02:55 192.168.1.5 3237: 069528: Aug  9 08:02:54.679 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:02:55 192.168.1.5 3238: 069529: Aug  9 08:02:54.679 EDT: //0/000000000000/SIP/Info/sipSPIPutSCBInClientTable: Inserting SCB with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0 into ClientTable
Aug 09 08:02:55 192.168.1.5 3253:     Early Media            : No
Aug 09 08:02:55 192.168.1.5 3254:     Delayed Media          : No
Aug 09 08:02:55 192.168.1.5 3255:     Bridge Done            : No
Aug 09 08:02:55 192.168.1.5 3273: 069542: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
Aug 09 08:02:55 192.168.1.5 3274: 069543: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
Aug 09 08:02:55 192.168.1.5 3275: 069544: Aug  9 08:02:54.679 EDT: //5599/DF196693A97A/SIP/State/sipSPIChangeState: 0x4A44C280 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
Aug 09 08:02:55 192.168.1.5 3302: Destn SIP Resp Addr:Port : 192.168.3.2:5060
Aug 09 08:02:55 192.168.1.5 3314: Destn  IP Address (Media): 192.168.3.2
Aug 09 08:02:55 192.168.1.5 3315: Destn  IP Port    (Media): 16904
Aug 09 08:02:55 192.168.1.5 3334: 069578: Aug  9 08:02:54.687 EDT: //5599/DF196693A97A/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:4D9EF430
Aug 09 08:02:55 192.168.1.5 3343: 069583: Aug  9 08:02:54.687 EDT: //5599/DF196693A97A/SIP/Info/ccsip_caps_ind: Entry
Aug 09 08:02:55 192.168.1.5 3344: 069584: Aug  9 08:02:54.687 EDT: //5599/DF196693A97A/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=5599, current_seq_num=0x1E1C
Aug 09 08:02:55 192.168.1.5 3345: 069585: Aug  9 08:02:54.687 EDT: //5599/DF196693A97A/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=5599, current_seq_num=0x1C7
Aug 09 08:02:55 192.168.1.5 3370: ACK sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 08:02:55 192.168.1.5 3371: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17B980F
Aug 09 08:02:55 192.168.1.5 3372: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:02:55 192.168.1.5 3373: To: <5743060212>;tag=cueefb1b7bf
Aug 09 08:02:55 192.168.1.5 3374: Date: Mon, 09 Aug 2010 12:02:54 GMT
Aug 09 08:02:55 192.168.1.5 3375: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:02:55 192.168.1.5 3376: Max-Forwards: 70
Aug 09 08:02:55 192.168.1.5 3377: CSeq: 101 ACK
Aug 09 08:02:55 192.168.1.5 3378: Allow-Events: telephone-event
Aug 09 08:02:55 192.168.1.5 3379: Content-Length: 0
Aug 09 08:02:55 192.168.1.5 3380:
Aug 09 08:02:58 192.168.1.5 3381: 069606: Aug  9 08:02:57.863 EDT: //5599/DF196693A97A/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5599, proc_id=9
Aug 09 08:03:01 192.168.1.5 3382: 069607: Aug  9 08:03:00.619 EDT: //5599/DF196693A97A/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5599, proc_id=9
Aug 09 08:03:05 192.168.1.5 3383: 069608: Aug  9 08:03:04.031 EDT: //5599/DF196693A97A/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5599, proc_id=9
Aug 09 08:03:05 192.168.1.5 3384: 069609: Aug  9 08:03:05.843 EDT: //5599/DF196693A97A/SIP/Info/sipSPISetUnsolicitedNotifySendDigitTimer: Starting unsolicited notify timer for: 1900
Aug 09 08:03:05 192.168.1.5 3385: 069610: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Aug 09 08:03:05 192.168.1.5 3386: 069611: Aug  9 08:03:05.847 EDT: //5599/DF196693A97A/SIP/Info/sipSPIStopUnsolicitedNotifySendDigitTimer: Stopping unsolicited notify timer
Aug 09 08:03:05 192.168.1.5 3387: 069612: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
Aug 09 08:03:05 192.168.1.5 3388: 069613: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:05 192.168.1.5 3389: 069614: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457908
Aug 09 08:03:05 192.168.1.5 3390: 069615: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457908's parent is 0x4E2ED5F4
Aug 09 08:03:05 192.168.1.5 3391: 069616: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Port Present: FALSE, Transport 1, FQDN 1154642800
Aug 09 08:03:05 192.168.1.5 3392: 069617: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 08:03:05 192.168.1.5 3393: 069618: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Aug 09 08:03:05 192.168.1.5 3394:  Sending: Binary Message Body
Aug 09 08:03:05 192.168.1.5 3395: 069619: Aug  9 08:03:05.847 EDT: Content-Type: audio/telephone-event
Aug 09 08:03:05 192.168.1.5 3396: 08 00 07 D0
Aug 09 08:03:05 192.168.1.5 3397: 069620: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457908's method is 111
Aug 09 08:03:05 192.168.1.5 3398: 069621: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A457908) has claimed possesion of package (0x4E94425C)
Aug 09 08:03:05 192.168.1.5 3399: 069622: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK17BAFCA
Aug 09 08:03:05 192.168.1.5 3400: 069623: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 08:03:05 192.168.1.5 3401: 069624: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457908) on EDB(0x48210D64)
Aug 09 08:03:05 192.168.1.5 3402: 069625: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
Aug 09 08:03:05 192.168.1.5 3403: 069626: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
Aug 09 08:03:05 192.168.1.5 3404: 069627: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A457908 and parent: 0x4E2ED5F4
Aug 09 08:03:05 192.168.1.5 3405: 069628: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4E94425C, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41847784
Aug 09 08:03:05 192.168.1.5 3406: 069629: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:03:05 192.168.1.5 3407: 069630: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 08:03:05 192.168.1.5 3408: 069631: Aug  9 08:03:05.847 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E94425C
Aug 09 08:03:05 192.168.1.5 3409: 069632: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E94425C, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 08:03:05 192.168.1.5 3410: 069633: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
Aug 09 08:03:05 192.168.1.5 3411: 069634: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x4A457908) with 10 retries and 500 milliseconds initial retx
Aug 09 08:03:05 192.168.1.5 3412: 069635: Aug  9 08:03:05.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x4D90A4A4)
Aug 09 08:03:05 192.168.1.5 3413: 069636: Aug  9 08:03:05.851 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:05 192.168.1.5 3414: Sent:
Aug 09 08:03:05 192.168.1.5 3415: NOTIFY sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 08:03:06 192.168.1.5 3416: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17BAFCA
Aug 09 08:03:06 192.168.1.5 3417: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:03:06 192.168.1.5 3418: To: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:06 192.168.1.5 3419: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:06 192.168.1.5 3420: CSeq: 102 NOTIFY
Aug 09 08:03:06 192.168.1.5 3421: Max-Forwards: 70
Aug 09 08:03:06 192.168.1.5 3422: Date: Mon, 09 Aug 2010 12:03:05 GMT
Aug 09 08:03:06 192.168.1.5 3423: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 08:03:06 192.168.1.5 3424: Event: telephone-event
Aug 09 08:03:06 192.168.1.5 3425: Subscription-State: active
Aug 09 08:03:06 192.168.1.5 3426: Contact: <192.168.3.1:5060>
Aug 09 08:03:06 192.168.1.5 3427: Content-Type: audio/telephone-event
Aug 09 08:03:06 192.168.1.5 3428: Content-Length: 4
Aug 09 08:03:06 192.168.1.5 3429:
Aug 09 08:03:06 192.168.1.5 3430:  . Ð
Aug 09 08:03:06 192.168.1.5 3431: 069637: Aug  9 08:03:05.863 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 3432: 069638: Aug  9 08:03:05.863 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 3433: 069639: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:06 192.168.1.5 3434: 069640: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:06 192.168.1.5 3435: 069641: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:06 192.168.1.5 3436: 069642: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:06 192.168.1.5 3437: 069643: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:06 192.168.1.5 3438: Received:
Aug 09 08:03:06 192.168.1.5 3439: SIP/2.0 200 OK
Aug 09 08:03:06 192.168.1.5 3440: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17BAFCA
Aug 09 08:03:06 192.168.1.5 3441: To: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:06 192.168.1.5 3442: From: "Gary Crisenbery" <4025>;tag=1ECA0F34-0
Aug 09 08:03:06 192.168.1.5 3443: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:06 192.168.1.5 3444: CSeq: 102 NOTIFY
Aug 09 08:03:06 192.168.1.5 3445: Content-Length: 0
Aug 09 08:03:06 192.168.1.5 3446: Allow-Events: refer
Aug 09 08:03:06 192.168.1.5 3447: Allow-Events: telephone-event
Aug 09 08:03:06 192.168.1.5 3448: Allow-Events: message-summary
Aug 09 08:03:06 192.168.1.5 3449:
Aug 09 08:03:06 192.168.1.5 3450: 069644: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:06 192.168.1.5 3451: 069645: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:06 192.168.1.5 3452: 069646: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x4A457908) on SCB(0x4E2ED5F4)
Aug 09 08:03:06 192.168.1.5 3453: 069647: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
Aug 09 08:03:06 192.168.1.5 3454: 069648: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
Aug 09 08:03:06 192.168.1.5 3455: 069649: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A457908) from EDB(0x48210D64)
Aug 09 08:03:06 192.168.1.5 3456: 069650: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A457908) for reuse
Aug 09 08:03:06 192.168.1.5 3457: 069651: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
Aug 09 08:03:06 192.168.1.5 3458: 069652: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
Aug 09 08:03:06 192.168.1.5 3459: 069653: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
Aug 09 08:03:06 192.168.1.5 3460: 069654: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:06 192.168.1.5 3461: 069655: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A457A9C
Aug 09 08:03:06 192.168.1.5 3462: 069656: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457A9C's parent is 0x4E2ED5F4
Aug 09 08:03:06 192.168.1.5 3463: 069657: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 192.168.3.2,Port 5060, Port Present: FALSE, Transport 1, FQDN 1154642800
Aug 09 08:03:06 192.168.1.5 3464: 069658: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Aug 09 08:03:06 192.168.1.5 3465: 069659: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Aug 09 08:03:06 192.168.1.5 3466:  Sending: Binary Message Body
Aug 09 08:03:06 192.168.1.5 3467: 069660: Aug  9 08:03:05.867 EDT: Content-Type: audio/telephone-event
Aug 09 08:03:06 192.168.1.5 3468: 08 80 00 64
Aug 09 08:03:06 192.168.1.5 3469: 069661: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x4A457A9C's method is 111
Aug 09 08:03:06 192.168.1.5 3470: 069662: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A457A9C) has claimed possesion of package (0x4ECAEECC)
Aug 09 08:03:06 192.168.1.5 3471: 069663: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK17BB2687
Aug 09 08:03:06 192.168.1.5 3472: 069664: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 08:03:06 192.168.1.5 3473: 069665: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A457A9C) on EDB(0x48210D64)
Aug 09 08:03:06 192.168.1.5 3474: 069666: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
Aug 09 08:03:06 192.168.1.5 3475: 069667: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
Aug 09 08:03:06 192.168.1.5 3476: 069668: Aug  9 08:03:05.867 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A457A9C and parent: 0x4E2ED5F4
Aug 09 08:03:06 192.168.1.5 3477: 069669: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4ECAEECC, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x41847784
Aug 09 08:03:06 192.168.1.5 3478: 069670: Aug  9 08:03:05.867 EDT: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:03:06 192.168.1.5 3521:
Aug 09 08:03:06 192.168.1.5 3522: 069685: Aug  9 08:03:05.891 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:06 192.168.1.5 3523: 069686: Aug  9 08:03:05.891 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:06 192.168.1.5 3527: 069690: Aug  9 08:03:05.891 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A457A9C) from EDB(0x48210D64)
Aug 09 08:03:06 192.168.1.5 3528: 069691: Aug  9 08:03:05.891 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A457A9C) for reuse
Aug 09 08:03:06 192.168.1.5 3529: 069692: Aug  9 08:03:05.891 EDT: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
Aug 09 08:03:06 192.168.1.5 3530: 069693: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 3531: 069694: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 3532: 069695: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:06 192.168.1.5 3533: 069696: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:06 192.168.1.5 3534: Received:
Aug 09 08:03:06 192.168.1.5 3535: INVITE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:06 192.168.1.5 3536: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3328
Aug 09 08:03:06 192.168.1.5 3537: Max-Forwards: 70
Aug 09 08:03:06 192.168.1.5 3538: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:06 192.168.1.5 3539: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:06 192.168.1.5 3540: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:06 192.168.1.5 3541: CSeq: 1 INVITE
Aug 09 08:03:06 192.168.1.5 3542: Content-Length: 168
Aug 09 08:03:06 192.168.1.5 3543: Contact: <5743060212>
Aug 09 08:03:06 192.168.1.5 3544: Content-Type: application/sdp
Aug 09 08:03:06 192.168.1.5 3545: Call-Info: <192.168.3.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Aug 09 08:03:06 192.168.1.5 3546: Allow-Events: telephon
Aug 09 08:03:06 192.168.1.5 3547: e-event
Aug 09 08:03:06 192.168.1.5 3548:
Aug 09 08:03:06 192.168.1.5 3549: v=0
Aug 09 08:03:06 192.168.1.5 3550: o=CiscoSystemsSIP-Workflow-App-UserAgent 3177 3177 IN IP4 0.0.0.0
Aug 09 08:03:06 192.168.1.5 3551: s=SIP Call
Aug 09 08:03:06 192.168.1.5 3552: c=IN IP4 0.0.0.0
Aug 09 08:03:06 192.168.1.5 3553: t=0 0
Aug 09 08:03:06 192.168.1.5 3554: m=audio 16904 RTP/AVP 0
Aug 09 08:03:06 192.168.1.5 3555: a=rtpmap:0 pcmu/8000
Aug 09 08:03:06 192.168.1.5 3556: a=ptime:20
Aug 09 08:03:06 192.168.1.5 3557: 069697: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 08:03:06 192.168.1.5 3558: 069698: Aug  9 08:03:05.975 EDT: //5599/DF196693A97A/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4A44C280
Aug 09 08:03:06 192.168.1.5 3559: 069699: Aug  9 08:03:05.975 EDT: //5599/DF196693A97A/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
Aug 09 08:03:06 192.168.1.5 3560: 069700: Aug  9 08:03:05.975 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 35372, Transport 1, SentBy Port 5060
Aug 09 08:03:06 192.168.1.5 3586: 069723: Aug  9 08:03:05.979 EDT: //5599/DF196693A97A/SIP/Media/sipSPIGetNewLocalMediaDirection:
Aug 09 08:03:06 192.168.1.5 3587:     New Remote Media Direction = SENDRECV
Aug 09 08:03:06 192.168.1.5 3610: 069735: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.3.1
Aug 09 08:03:06 192.168.1.5 3626: 069739: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Error/ccsip_api_request_offer: Error Parsing Call-Info Header
Aug 09 08:03:06 192.168.1.5 3627: 069740: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Media/ccsip_api_request_offer: Call has been put on hold
Aug 09 08:03:06 192.168.1.5 3628: 069741: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
Aug 09 08:03:06 192.168.1.5 3629: 069742: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
Aug 09 08:03:06 192.168.1.5 3630: 069743: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=19422
Aug 09 08:03:06 192.168.1.5 3631: 069744: Aug  9 08:03:05.983 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Aug 09 08:03:06 192.168.1.5 3646: 069755: Aug  9 08:03:05.983 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
Aug 09 08:03:06 192.168.1.5 3647: sipSPIUpdateCallInfoforDelayReconnect: callID 5599
Aug 09 08:03:06 192.168.1.5 3651: 069759: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: msg=0x4E49946C, addr=192.168.3.2, port=35372, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x0
Aug 09 08:03:06 192.168.1.5 3652: 069760: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:03:06 192.168.1.5 3653: 069761: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 08:03:06 192.168.1.5 3654: 069762: Aug  9 08:03:05.987 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E49946C, addr=192.168.3.2, port=5060, connId=0 for UDP
Aug 09 08:03:06 192.168.1.5 3655: 069763: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessContactInfo: Previous Hop 192.168.3.2:5060
Aug 09 08:03:06 192.168.1.5 3656: 069764: Aug  9 08:03:05.987 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
Aug 09 08:03:06 192.168.1.5 3657: 069765: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/act_handle_app_media_event: method = 102 state = 16
Aug 09 08:03:06 192.168.1.5 3658: 069766: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
Aug 09 08:03:06 192.168.1.5 3659: 069767: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 0.0.0.0, RTCP Type 3
Aug 09 08:03:06 192.168.1.5 3660: 069768: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPISetHoldTimer: Starting hold timer at 2880 minutes
Aug 09 08:03:06 192.168.1.5 3661: 069769: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5599
Aug 09 08:03:06 192.168.1.5 3662: 069770: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5599
Aug 09 08:03:06 192.168.1.5 3663: SIP: (5599) Group (a= group line) attribute, level 65535 instance 1 not found.
Aug 09 08:03:06 192.168.1.5 3664: 069771: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
Aug 09 08:03:06 192.168.1.5 3665: 069772: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sipSPISendInviteResponse: Associated container=0x4D90947C to Invite Response 200
Aug 09 08:03:06 192.168.1.5 3666: 069773: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
Aug 09 08:03:06 192.168.1.5 3667: 069774: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: msg=0x4ECAEECC, addr=192.168.3.2, port=35372, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x4193B088
Aug 09 08:03:06 192.168.1.5 3668: 069775: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:03:06 192.168.1.5 3669: 069776: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 08:03:06 192.168.1.5 3671: 069778: Aug  9 08:03:05.987 EDT: //5599/DF196693A97A/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
Aug 09 08:03:06 192.168.1.5 3672: 069779: Aug  9 08:03:05.991 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:06 192.168.1.5 3673: Sent:
Aug 09 08:03:06 192.168.1.5 3694: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Aug 09 08:03:06 192.168.1.5 3695: Allow-Events: telephone-event
Aug 09 08:03:06 192.168.1.5 3706: o=CiscoSystemsSIP-GW-UserAgent 5854 1069 IN IP4 192.168.3.1
Aug 09 08:03:06 192.168.1.5 3707: s=SIP Call
Aug 09 08:03:06 192.168.1.5 3708: c=IN IP4 192.168.3.1
Aug 09 08:03:06 192.168.1.5 3709: t=0 0
Aug 09 08:03:06 192.168.1.5 3710: m=audio 19422 RTP/AVP 0
Aug 09 08:03:06 192.168.1.5 3711: c=IN IP4 192.168.3.1
Aug 09 08:03:06 192.168.1.5 3731: 069787: Aug  9 08:03:06.015 EDT: //5599/DF196693A97A/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
Aug 09 08:03:06 192.168.1.5 3732: 069788: Aug  9 08:03:06.015 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.3.2,Port 35372, Transport 1, SentBy Port 5060
Aug 09 08:03:06 192.168.1.5 3745: 069800: Aug  9 08:03:06.035 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:06 192.168.1.5 3759: Call-Info: <192.168.3.2:5060>;method="NOTIFY;Event=telep
Aug 09 08:03:06 192.168.1.5 3760: hone-event;Duration=2000"
Aug 09 08:03:06 192.168.1.5 3761: Allow-Events: telephone-event
Aug 09 08:03:06 192.168.1.5 3762:
Aug 09 08:03:06 192.168.1.5 3780: 069811: Aug  9 08:03:06.039 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
Aug 09 08:03:06 192.168.1.5 3781: 069812: Aug  9 08:03:06.039 EDT: //-1/E7403987A980/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
Aug 09 08:03:06 192.168.1.5 3797: 069828: Aug  9 08:03:06.043 EDT: //-1/E7403987A980/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Aug 09 08:03:06 192.168.1.5 3798: 069829: Aug  9 08:03:06.043 EDT: //-1/E7403987A980/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Aug 09 08:03:06 192.168.1.5 3817: 069848: Aug  9 08:03:06.047 EDT: //5601/E7403987A980/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Aug 09 08:03:06 192.168.1.5 3818: CallID 5601, Peer CallID 0, sdp 0x4E9348E8 channels 0x4A41DE10
Aug 09 08:03:06 192.168.1.5 3819: 069849: Aug  9 08:03:06.047 EDT: //5601/E7403987A980/SIP/Info/copy_channels:
Aug 09 08:03:06 192.168.1.5 3820:  callId 5601 size 0 ptr 0x4E4C405C)
Aug 09 08:03:06 192.168.1.5 3821: 069850: Aug  9 08:03:06.047 EDT: //5601/E7403987A980/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Aug 09 08:03:06 192.168.1.5 3822: Hndl ptype 0 mline 1
Aug 09 08:03:06 192.168.1.5 3823: 069851: Aug  9 08:03:06.047 EDT: //5601/E7403987A980/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
Aug 09 08:03:06 192.168.1.5 3824: 069852: Aug  9 08:03:06.047 EDT: //5601/E7403987A980/SIP/Info/codec_found:
Aug 09 08:03:06 192.168.1.5 3853: 069876: Aug  9 08:03:06.051 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Aug 09 08:03:06 192.168.1.5 3866: Sent:
Aug 09 08:03:06 192.168.1.5 3883: 069893: Aug  9 08:03:06.071 EDT: //5601/E7403987A980/SIP/Info/ccsip_event_handler:
Aug 09 08:03:06 192.168.1.5 3894: 069901: Aug  9 08:03:06.071 EDT: //5601/E7403987A980/SIP/Info/ccsip_event_handler:
Aug 09 08:03:06 192.168.1.5 3926: From: <5743060212>;tag=cue5955e486
Aug 09 08:03:06 192.168.1.5 3927: To: <4081>;tag=1ECA3C50-79A
Aug 09 08:03:06 192.168.1.5 3953: 069930: Aug  9 08:03:06.083 EDT: //5601//TCL :/tcl_PutsObjCmd:
Aug 09 08:03:06 192.168.1.5 3966: 069940: Aug  9 08:03:06.115 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 3972: Max-Forwards: 70
Aug 09 08:03:06 192.168.1.5 3973: To: <4081>;tag=1ECA3C50-79A
Aug 09 08:03:06 192.168.1.5 4032: Contact: <5743060212>
Aug 09 08:03:06 192.168.1.5 4055: 069983: Aug  9 08:03:06.123 EDT: //-1/xxxxxxxxxxxx/SIP/Info/act_subscribe_idle_new_message: TCB 0x4A456F90's parent is 0x4EB798A0
Aug 09 08:03:06 192.168.1.5 4101: 070029: Aug  9 08:03:06.127 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E43DD2C
Aug 09 08:03:06 192.168.1.5 4161: 070049: Aug  9 08:03:06.135 EDT: //0/000000000000/SIP/Info/sipSPICreateNewEDB: There are 2 EDB's on edbQ
Aug 09 08:03:06 192.168.1.5 4168: 070056: Aug  9 08:03:06.139 EDT: //5599/DF196693A97A/SIP/Info/sipSPI_ipip_build_referto: new replaces is 12813553860131081@192.168.3.2;to-tag=1ECA3C50-79A;from-tag=cue5955e486
Aug 09 08:03:06 192.168.1.5 4169: 070057: Aug  9 08:03:06.139 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_REFER_RESP
Aug 09 08:03:06 192.168.1.5 4187: 070075: Aug  9 08:03:06.143 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
Aug 09 08:03:06 192.168.1.5 4188: 070076: Aug  9 08:03:06.143 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A4572B8) on EDB(0x4E6C1FA8)
Aug 09 08:03:06 192.168.1.5 4230: Content-Length: 22
Aug 09 08:03:06 192.168.1.5 4231:
Aug 09 08:03:06 192.168.1.5 4232: SIP/2.0 100 Trying
Aug 09 08:03:06 192.168.1.5 4233:
Aug 09 08:03:06 192.168.1.5 4234: 070093: Aug  9 08:03:06.151 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 14
Aug 09 08:03:06 192.168.1.5 4249: 070108: Aug  9 08:03:06.163 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:06 192.168.1.5 4250: 070109: Aug  9 08:03:06.163 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x4A45744C
Aug 09 08:03:06 192.168.1.5 4289: 070130: Aug  9 08:03:06.167 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 4303: Call-ID: 12813553860131081@192.168.3.2
Aug 09 08:03:06 192.168.1.5 4304: CSeq: 101 NOTIFY
Aug 09 08:03:06 192.168.1.5 4305: Content-Length: 0
Aug 09 08:03:06 192.168.1.5 4306: Allow-Events: refer
Aug 09 08:03:06 192.168.1.5 4307: Allow-Events: telephone-event
Aug 09 08:03:06 192.168.1.5 4308: Allow-Events: message-summary
Aug 09 08:03:06 192.168.1.5 4309:
Aug 09 08:03:06 192.168.1.5 4310: 070139: Aug  9 08:03:06.171 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:06 192.168.1.5 4321: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:06 192.168.1.5 4347: 070183: Aug  9 08:03:06.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x4A456DFC) has claimed possesion of package (0x4E4A5680)
Aug 09 08:03:06 192.168.1.5 4348: 070184: Aug  9 08:03:06.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x4A456DFC and parent: 0x4E2ED5F4
Aug 09 08:03:06 192.168.1.5 4373: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3335
Aug 09 08:03:06 192.168.1.5 4374: Max-Forwards: 70
Aug 09 08:03:06 192.168.1.5 4383: 070198: Aug  9 08:03:06.199 EDT: //5599/DF196693A97A/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4A44C280
Aug 09 08:03:06 192.168.1.5 4384: 070209: Aug  9 08:03:06.247 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 4385: 070210: Aug  9 08:03:06.247 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 4386: 070211: Aug  9 08:03:06.251 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:06 192.168.1.5 4387: 070212: Aug  9 08:03:06.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:06 192.168.1.5 4435: Destn  IP Port    (Media): 16904
Aug 09 08:03:06 192.168.1.5 4447: 070236: Aug  9 08:03:06.275 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 4448: 070237: Aug  9 08:03:06.275 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 4469: 070245: Aug  9 08:03:06.279 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:06 192.168.1.5 4470: 070246: Aug  9 08:03:06.279 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:06 192.168.1.5 4471: 070247: Aug  9 08:03:06.279 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:06 192.168.1.5 4472: 070248: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:06 192.168.1.5 4473: 070249: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:06 192.168.1.5 4474: 070250: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:06 192.168.1.5 4475: 070251: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:06 192.168.1.5 4476: Received:
Aug 09 08:03:06 192.168.1.5 4477: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:06 192.168.1.5 4478: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:06 192.168.1.5 4479: Max-Forwards: 70
Aug 09 08:03:06 192.168.1.5 4480: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:06 192.168.1.5 4481: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:06 192.168.1.5 4482: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:06 192.168.1.5 4483: CSeq: 6 SUBSCRIBE
Aug 09 08:03:06 192.168.1.5 4484: Content-Length: 0
Aug 09 08:03:06 192.168.1.5 4485: Contact: <5743060212>
Aug 09 08:03:06 192.168.1.5 4486: Expires: 0
Aug 09 08:03:06 192.168.1.5 4487: Event: refer;id=2
Aug 09 08:03:06 192.168.1.5 4488:
Aug 09 08:03:06 192.168.1.5 4489: 070252: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:06 192.168.1.5 4490: 070253: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:06 192.168.1.5 4491: 070254: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:06 192.168.1.5 4492: 070255: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:07 192.168.1.5 4493: 070256: Aug  9 08:03:06.823 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:07 192.168.1.5 4494: 070257: Aug  9 08:03:06.823 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:07 192.168.1.5 4495: 070258: Aug  9 08:03:06.823 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:07 192.168.1.5 4496: 070259: Aug  9 08:03:06.823 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:07 192.168.1.5 4497: 070260: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:07 192.168.1.5 4498: 070261: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:07 192.168.1.5 4499: 070262: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:07 192.168.1.5 4500: 070263: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:07 192.168.1.5 4501: Received:
Aug 09 08:03:07 192.168.1.5 4502: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:07 192.168.1.5 4503: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:07 192.168.1.5 4504: Max-Forwards: 70
Aug 09 08:03:07 192.168.1.5 4505: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:07 192.168.1.5 4506: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:07 192.168.1.5 4507: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:07 192.168.1.5 4508: CSeq: 6 SUBSCRIBE
Aug 09 08:03:07 192.168.1.5 4509: Content-Length: 0
Aug 09 08:03:07 192.168.1.5 4510: Contact: <5743060212>
Aug 09 08:03:07 192.168.1.5 4511: Expires: 0
Aug 09 08:03:07 192.168.1.5 4512: Event: refer;id=2
Aug 09 08:03:07 192.168.1.5 4513:
Aug 09 08:03:07 192.168.1.5 4514: 070264: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:07 192.168.1.5 4515: 070265: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:07 192.168.1.5 4516: 070266: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:07 192.168.1.5 4517: 070267: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:07 192.168.1.5 4518: 070268: Aug  9 08:03:07.827 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:08 192.168.1.5 4519: 070269: Aug  9 08:03:07.827 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:08 192.168.1.5 4520: 070270: Aug  9 08:03:07.827 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:08 192.168.1.5 4521: 070271: Aug  9 08:03:07.827 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:09 192.168.1.5 4522: 070272: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:09 192.168.1.5 4523: 070273: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:09 192.168.1.5 4524: 070274: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:09 192.168.1.5 4525: 070275: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:09 192.168.1.5 4526: Received:
Aug 09 08:03:09 192.168.1.5 4527: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:09 192.168.1.5 4528: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:09 192.168.1.5 4529: Max-Forwards: 70
Aug 09 08:03:09 192.168.1.5 4530: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:09 192.168.1.5 4531: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:09 192.168.1.5 4532: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:09 192.168.1.5 4533: CSeq: 6 SUBSCRIBE
Aug 09 08:03:09 192.168.1.5 4534: Content-Length: 0
Aug 09 08:03:09 192.168.1.5 4535: Contact: <5743060212>
Aug 09 08:03:09 192.168.1.5 4536: Expires: 0
Aug 09 08:03:09 192.168.1.5 4537: Event: refer;id=2
Aug 09 08:03:09 192.168.1.5 4538:
Aug 09 08:03:09 192.168.1.5 4539: 070276: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:09 192.168.1.5 4540: 070277: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:09 192.168.1.5 4541: 070278: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:09 192.168.1.5 4542: 070279: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:09 192.168.1.5 4543: 070280: Aug  9 08:03:09.831 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:10 192.168.1.5 4544: 070281: Aug  9 08:03:09.831 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:10 192.168.1.5 4545: 070282: Aug  9 08:03:09.831 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:10 192.168.1.5 4546: 070283: Aug  9 08:03:09.831 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:13 192.168.1.5 4547: 070284: Aug  9 08:03:13.583 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISASSOCIATE
Aug 09 08:03:13 192.168.1.5 4548: 070285: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Info/ccsip_bridge: confID = 1322, srcCallID = 5601, dstCallID = 5603
Aug 09 08:03:13 192.168.1.5 4549: 070286: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 5601/5603
Aug 09 08:03:13 192.168.1.5 4550: 070287: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=-1, new streamcallid=5601
Aug 09 08:03:13 192.168.1.5 4551: 070288: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
Aug 09 08:03:13 192.168.1.5 4552: 070289: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1087774392, ccb xmitFunc = 1087774392
Aug 09 08:03:13 192.168.1.5 4553: 070290: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
Aug 09 08:03:13 192.168.1.5 4554: 070291: Aug  9 08:03:13.583 EDT: //5601/E7403987A980/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Aug 09 08:03:13 192.168.1.5 4555: 070292: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: Entry
Aug 09 08:03:13 192.168.1.5 4556: 070293: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: Negotiation not done yet:: Load DSP with preferred codec : g711ulaw, Bytes=160, payload: 0
Aug 09 08:03:13 192.168.1.5 4557: 070294: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
Aug 09 08:03:13 192.168.1.5 4558: 070295: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
Aug 09 08:03:13 192.168.1.5 4559: 070296: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=5603
Aug 09 08:03:13 192.168.1.5 4560: 070297: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
Aug 09 08:03:13 192.168.1.5 4561: 070298: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Aug 09 08:03:13 192.168.1.5 4562: 070299: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_set_modem_caps: Negotiation NOT yet Done. Set the configured values and generate SDP Xcap list
Aug 09 08:03:13 192.168.1.5 4563: 070300: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
Aug 09 08:03:13 192.168.1.5 4564: 070301: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sip_set_modem_caps: nse payload = 100, ptru mode = 0, ptru-codec=0, redundancy=0, xid=1, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
Aug 09 08:03:13 192.168.1.5 4565: 070302: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
Aug 09 08:03:13 192.168.1.5 4566: 070303: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
Aug 09 08:03:13 192.168.1.5 4567: 070304: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Media/sipSPISetStreamInfo:
Aug 09 08:03:13 192.168.1.5 4568: caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
Aug 09 08:03:13 192.168.1.5 4569: 070305: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
Aug 09 08:03:13 192.168.1.5 4570: 070306: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
Aug 09 08:03:13 192.168.1.5 4571: 070307: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
Aug 09 08:03:13 192.168.1.5 4572: 070308: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x203
Aug 09 08:03:13 192.168.1.5 4573: 070309: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/sipSPISrtpTranscoder:
Aug 09 08:03:13 192.168.1.5 4574:  Checking if transcoder is needed for SRTP-RTP
Aug 09 08:03:13 192.168.1.5 4575: 070310: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ind: Calling cc_api_caps_ack()
Aug 09 08:03:13 192.168.1.5 4576: 070311: Aug  9 08:03:13.587 EDT: //5601/E7403987A980/SIP/Info/ccsip_caps_ack: Set forking flag to 0x0
Aug 09 08:03:13 192.168.1.5 4577: 070312: Aug  9 08:03:13.591 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
Aug 09 08:03:13 192.168.1.5 4578: 070313: Aug  9 08:03:13.591 EDT: //5601//TCL :/tcl_PutsObjCmd:
Aug 09 08:03:13 192.168.1.5 4579:  proc act_CallSetupDone
Aug 09 08:03:13 192.168.1.5 4580: 070314: Aug  9 08:03:13.595 EDT:
Aug 09 08:03:13 192.168.1.5 4581: 070315: Aug  9 08:03:13.595 EDT: //5601//TCL :/tcl_PutsObjCmd:
Aug 09 08:03:13 192.168.1.5 4582:  IP IVR Leg Setup Status = ls_000
Aug 09 08:03:13 192.168.1.5 4583: 070316: Aug  9 08:03:13.595 EDT:
Aug 09 08:03:13 192.168.1.5 4584: 070317: Aug  9 08:03:13.595 EDT: //5601//TCL :/tcl_PutsObjCmd: TCL AA: >> Call answered by the agent; Call Connected <<
Aug 09 08:03:13 192.168.1.5 4585: 070318: Aug  9 08:03:13.595 EDT: //5601//TCL :/tcl_PutsObjCmd: TCL AA: >>> Incoming LEG ID = 5598 5601; Outgoing LEG ID = 5603 <<<
Aug 09 08:03:13 192.168.1.5 4586: 070319: Aug  9 08:03:13.599 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 15
Aug 09 08:03:13 192.168.1.5 4587: 070320: Aug  9 08:03:13.599 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 30
Aug 09 08:03:13 192.168.1.5 4588: 070321: Aug  9 08:03:13.603 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Time to Answer = 7 Seconds<<<
Aug 09 08:03:13 192.168.1.5 4589: 070322: Aug  9 08:03:13.603 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> THE QUEUE IS {TclModule_4927089C_0_516570172 {CALL_HANDOFF} {1281355393}} <<<
Aug 09 08:03:13 192.168.1.5 4590: 070323: Aug  9 08:03:13.631 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD ++ Service Counter = 42 ++
Aug 09 08:03:13 192.168.1.5 4591: 070324: Aug  9 08:03:13.631 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD: +++ 4080 Queue Length = 0 +++
Aug 09 08:03:13 192.168.1.5 4592: 070325: Aug  9 08:03:13.631 EDT: //1400//TCL :/tcl_PutsObjCmd:
Aug 09 08:03:13 192.168.1.5 4593: TCL B-ACD:  >>> 4080 Queue Length = 0 <<<
Aug 09 08:03:13 192.168.1.5 4594: 070326: Aug  9 08:03:13.631 EDT: //1400//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> Queue 4080 is Empty <<<
Aug 09 08:03:13 192.168.1.5 4595: 070327: Aug  9 08:03:13.631 EDT: //5601/E7403987A980/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
Aug 09 08:03:13 192.168.1.5 4596: 070328: Aug  9 08:03:13.635 EDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug 09 08:03:13 192.168.1.5 4597: 070329: Aug  9 08:03:13.643 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Aug 09 08:03:13 192.168.1.5 4598: 070330: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 08:03:13 192.168.1.5 4599: 070331: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
Aug 09 08:03:13 192.168.1.5 4600: 070332: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Info/sipSPISendBye: Associated container=0x4D90B684 to Bye
Aug 09 08:03:13 192.168.1.5 4601: 070333: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
Aug 09 08:03:13 192.168.1.5 4602: 070334: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Aug 09 08:03:13 192.168.1.5 4603: 070335: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipSPITransportSendMessage: msg=0x4E94425C, addr=192.168.3.2, port=5060, sentBy_port=0, is_req=1, transport=1, switch=0, callBack=0x4193AD70
Aug 09 08:03:13 192.168.1.5 4604: 070336: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Aug 09 08:03:13 192.168.1.5 4605: 070337: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Aug 09 08:03:13 192.168.1.5 4606: 070338: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E94425C
Aug 09 08:03:13 192.168.1.5 4607: 070339: Aug  9 08:03:13.643 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E94425C, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 08:03:13 192.168.1.5 4608: 070340: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
Aug 09 08:03:13 192.168.1.5 4609: 070341: Aug  9 08:03:13.643 EDT: //5601/E7403987A980/SIP/State/sipSPIChangeState: 0x4A41CB68 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Aug 09 08:03:13 192.168.1.5 4610: 070342: Aug  9 08:03:13.655 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:13 192.168.1.5 4611: Sent:
Aug 09 08:03:13 192.168.1.5 4612: BYE sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 08:03:14 192.168.1.5 4613: Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK17BF404
Aug 09 08:03:14 192.168.1.5 4614: From: <4081>;tag=1ECA3C50-79A
Aug 09 08:03:14 192.168.1.5 4615: To: <5743060212>;tag=cue5955e486
Aug 09 08:03:14 192.168.1.5 4616: Date: Mon, 09 Aug 2010 12:03:06 GMT
Aug 09 08:03:14 192.168.1.5 4617: Call-ID: 12813553860131081@192.168.3.2
Aug 09 08:03:14 192.168.1.5 4618: User-Agent: Cisco-SIPGateway/IOS-12.x
Aug 09 08:03:14 192.168.1.5 4619: Max-Forwards: 70
Aug 09 08:03:14 192.168.1.5 4620: Timestamp: 1281355393
Aug 09 08:03:14 192.168.1.5 4621: CSeq: 102 BYE
Aug 09 08:03:14 192.168.1.5 4622: Reason: Q.850;cause=16
Aug 09 08:03:14 192.168.1.5 4623: Content-Length: 0
Aug 09 08:03:14 192.168.1.5 4624:
Aug 09 08:03:14 192.168.1.5 4625: 070343: Aug  9 08:03:13.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:14 192.168.1.5 4626: 070344: Aug  9 08:03:13.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:14 192.168.1.5 4627: 070345: Aug  9 08:03:13.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:14 192.168.1.5 4628: 070346: Aug  9 08:03:13.675 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:14 192.168.1.5 4629: 070347: Aug  9 08:03:13.675 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Aug 09 08:03:14 192.168.1.5 4630: 070348: Aug  9 08:03:13.679 EDT: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
Aug 09 08:03:14 192.168.1.5 4631: 070349: Aug  9 08:03:13.679 EDT: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
Aug 09 08:03:14 192.168.1.5 4632: 070350: Aug  9 08:03:13.679 EDT: //5601/E7403987A980/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4A41CB68
Aug 09 08:03:14 192.168.1.5 4659: 070358: Aug  9 08:03:13.679 EDT: //5601/E7403987A980/SIP/Call/sipSPIMediaCallInfo:
Aug 09 08:03:14 192.168.1.5 4660: Number of Media Streams: 1
Aug 09 08:03:14 192.168.1.5 4661: Media Stream             : 1
Aug 09 08:03:14 192.168.1.5 4662: Negotiated Codec         : No Codec
Aug 09 08:03:14 192.168.1.5 4663: Negotiated Codec Bytes   : 0
Aug 09 08:03:14 192.168.1.5 4669: Destn  IP Address (Media):  -
Aug 09 08:03:14 192.168.1.5 4670: Destn  IP Port    (Media): 0
Aug 09 08:03:14 192.168.1.5 4671: Orig Destn IP Address:Port (Media): [ - ]:0
Aug 09 08:03:14 192.168.1.5 4672: 070359: Aug  9 08:03:13.679 EDT: //5601/E7403987A980/SIP/Call/sipSPICallInfo:
Aug 09 08:03:14 192.168.1.5 4692: Received:
Aug 09 08:03:14 192.168.1.5 4693: SUBSCRIBE sip:4081@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:14 192.168.1.5 4694: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3332
Aug 09 08:03:14 192.168.1.5 4695: Max-Forwards: 70
Aug 09 08:03:14 192.168.1.5 4696: To: <4081>;tag=1ECA3C50-79A
Aug 09 08:03:14 192.168.1.5 4697: From: <5743060212>;tag=cue5955e486
Aug 09 08:03:14 192.168.1.5 4719: 070391: Aug  9 08:03:13.687 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x4A456C68) on EDB(0x4E58CAB8)
Aug 09 08:03:14 192.168.1.5 4720: 070392: Aug  9 08:03:13.687 EDT: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 2 TCB's on tcbQ
Aug 09 08:03:14 192.168.1.5 4721: 070393: Aug  9 08:03:13.687 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
Aug 09 08:03:14 192.168.1.5 4741: 070413: Aug  9 08:03:13.687 EDT: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4EB135AC
Aug 09 08:03:14 192.168.1.5 4742: 070414: Aug  9 08:03:13.687 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4EB135AC, addr=192.168.3.2, port=5060, connId=2 for UDP
Aug 09 08:03:14 192.168.1.5 4787: NOTIFY sip:5743060212@192.168.3.2:5060 SIP/2.0
Aug 09 08:03:14 192.168.1.5 4825: Event: telephone-event
Aug 09 08:03:14 192.168.1.5 4826: Subscription-State: terminated
Aug 09 08:03:14 192.168.1.5 4827: Contact: <4081>
Aug 09 08:03:14 192.168.1.5 4828: Content-Length: 0
Aug 09 08:03:14 192.168.1.5 4829:
Aug 09 08:03:14 192.168.1.5 4830: 070460: Aug  9 08:03:13.723 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:14 192.168.1.5 4847: Allow-Events: refer
Aug 09 08:03:14 192.168.1.5 4848: Allow-Events: telephone-event
Aug 09 08:03:14 192.168.1.5 4855: 070473: Aug  9 08:03:13.723 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 4
Aug 09 08:03:14 192.168.1.5 4856: 070474: Aug  9 08:03:13.723 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A457774) from EDB(0x4E58CAB8)
Aug 09 08:03:14 192.168.1.5 4877: 070486: Aug  9 08:03:13.739 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:14 192.168.1.5 4878: 070487: Aug  9 08:03:13.739 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:14 192.168.1.5 4884: 070493: Aug  9 08:03:13.739 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 2 Transactions still active on Event:telephone-event ID:
Aug 09 08:03:14 192.168.1.5 4885: 070494: Aug  9 08:03:13.835 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:14 192.168.1.5 4907: 070503: Aug  9 08:03:13.839 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:14 192.168.1.5 4908: 070504: Aug  9 08:03:13.839 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:14 192.168.1.5 4909: 070505: Aug  9 08:03:13.839 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:17 192.168.1.5 4910: 070506: Aug  9 08:03:17.839 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:17 192.168.1.5 4911: 070507: Aug  9 08:03:17.839 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:17 192.168.1.5 4912: 070508: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:17 192.168.1.5 4913: 070509: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:17 192.168.1.5 4914: Received:
Aug 09 08:03:17 192.168.1.5 4915: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:17 192.168.1.5 4916: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:17 192.168.1.5 4917: Max-Forwards: 70
Aug 09 08:03:17 192.168.1.5 4918: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:17 192.168.1.5 4919: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:17 192.168.1.5 4920: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:17 192.168.1.5 4921: CSeq: 6 SUBSCRIBE
Aug 09 08:03:17 192.168.1.5 4922: Content-Length: 0
Aug 09 08:03:17 192.168.1.5 4923: Contact: <5743060212>
Aug 09 08:03:17 192.168.1.5 4924: Expires: 0
Aug 09 08:03:17 192.168.1.5 4925: Event: refer;id=2
Aug 09 08:03:17 192.168.1.5 4926:
Aug 09 08:03:17 192.168.1.5 4927: 070510: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:17 192.168.1.5 4928: 070511: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:17 192.168.1.5 4929: 070512: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:17 192.168.1.5 4930: 070513: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:17 192.168.1.5 4931: 070514: Aug  9 08:03:17.843 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:18 192.168.1.5 4932: 070515: Aug  9 08:03:17.843 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:18 192.168.1.5 4933: 070516: Aug  9 08:03:17.843 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:18 192.168.1.5 4934: 070517: Aug  9 08:03:17.843 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:21 192.168.1.5 4935: 070518: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:21 192.168.1.5 4936: 070519: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:21 192.168.1.5 4937: 070520: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:21 192.168.1.5 4938: 070521: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:21 192.168.1.5 4939: Received:
Aug 09 08:03:21 192.168.1.5 4940: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:21 192.168.1.5 4941: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:21 192.168.1.5 4942: Max-Forwards: 70
Aug 09 08:03:21 192.168.1.5 4943: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:21 192.168.1.5 4944: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:21 192.168.1.5 4945: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:21 192.168.1.5 4946: CSeq: 6 SUBSCRIBE
Aug 09 08:03:21 192.168.1.5 4947: Content-Length: 0
Aug 09 08:03:21 192.168.1.5 4948: Contact: <5743060212>
Aug 09 08:03:21 192.168.1.5 4949: Expires: 0
Aug 09 08:03:21 192.168.1.5 4950: Event: refer;id=2
Aug 09 08:03:21 192.168.1.5 4951:
Aug 09 08:03:21 192.168.1.5 4952: 070522: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:21 192.168.1.5 4953: 070523: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:21 192.168.1.5 4954: 070524: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:21 192.168.1.5 4955: 070525: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:21 192.168.1.5 4956: 070526: Aug  9 08:03:21.847 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:22 192.168.1.5 4957: 070527: Aug  9 08:03:21.847 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:22 192.168.1.5 4958: 070528: Aug  9 08:03:21.847 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:22 192.168.1.5 4959: 070529: Aug  9 08:03:21.847 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:25 192.168.1.5 4960: 070530: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:25 192.168.1.5 4961: 070531: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:25 192.168.1.5 4962: 070532: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:25 192.168.1.5 4963: 070533: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:25 192.168.1.5 4964: Received:
Aug 09 08:03:25 192.168.1.5 4965: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:25 192.168.1.5 4966: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:25 192.168.1.5 4967: Max-Forwards: 70
Aug 09 08:03:25 192.168.1.5 4968: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:25 192.168.1.5 4969: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:25 192.168.1.5 4970: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:25 192.168.1.5 4971: CSeq: 6 SUBSCRIBE
Aug 09 08:03:25 192.168.1.5 4972: Content-Length: 0
Aug 09 08:03:25 192.168.1.5 4973: Contact: <5743060212>
Aug 09 08:03:25 192.168.1.5 4974: Expires: 0
Aug 09 08:03:25 192.168.1.5 4975: Event: refer;id=2
Aug 09 08:03:25 192.168.1.5 4976:
Aug 09 08:03:25 192.168.1.5 4977: 070534: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:25 192.168.1.5 4978: 070535: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:25 192.168.1.5 4979: 070536: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:25 192.168.1.5 4980: 070537: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:25 192.168.1.5 4981: 070538: Aug  9 08:03:25.851 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:26 192.168.1.5 4982: 070539: Aug  9 08:03:25.851 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:26 192.168.1.5 4983: 070540: Aug  9 08:03:25.851 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:26 192.168.1.5 4984: 070541: Aug  9 08:03:25.851 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:29 192.168.1.5 4985: 070542: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:29 192.168.1.5 4986: 070543: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:29 192.168.1.5 4987: 070544: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:29 192.168.1.5 4988: 070545: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:29 192.168.1.5 4989: Received:
Aug 09 08:03:29 192.168.1.5 4990: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:29 192.168.1.5 4991: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:29 192.168.1.5 4992: Max-Forwards: 70
Aug 09 08:03:29 192.168.1.5 4993: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:29 192.168.1.5 4994: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:29 192.168.1.5 4995: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:29 192.168.1.5 4996: CSeq: 6 SUBSCRIBE
Aug 09 08:03:29 192.168.1.5 4997: Content-Length: 0
Aug 09 08:03:29 192.168.1.5 4998: Contact: <5743060212>
Aug 09 08:03:29 192.168.1.5 4999: Expires: 0
Aug 09 08:03:29 192.168.1.5 5000: Event: refer;id=2
Aug 09 08:03:29 192.168.1.5 5001:
Aug 09 08:03:29 192.168.1.5 5002: 070546: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:29 192.168.1.5 5003: 070547: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:29 192.168.1.5 5004: 070548: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:29 192.168.1.5 5005: 070549: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:29 192.168.1.5 5006: 070550: Aug  9 08:03:29.855 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:30 192.168.1.5 5007: 070551: Aug  9 08:03:29.855 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:30 192.168.1.5 5008: 070552: Aug  9 08:03:29.855 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:30 192.168.1.5 5009: 070553: Aug  9 08:03:29.855 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:33 192.168.1.5 5010: 070554: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.3.2]:35372
Aug 09 08:03:33 192.168.1.5 5011: 070555: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Aug 09 08:03:33 192.168.1.5 5012: 070556: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Aug 09 08:03:33 192.168.1.5 5013: 070557: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Aug 09 08:03:33 192.168.1.5 5014: Received:
Aug 09 08:03:33 192.168.1.5 5015: SUBSCRIBE sip:4025@192.168.3.1:5060 SIP/2.0
Aug 09 08:03:33 192.168.1.5 5016: Via: SIP/2.0/UDP 192.168.3.2:5060;branch=z9hG4bKw.qcDnWVDTYOy7AlmCoT6A~~3336
Aug 09 08:03:33 192.168.1.5 5017: Max-Forwards: 70
Aug 09 08:03:33 192.168.1.5 5018: To: <4025>;tag=1ECA0F34-0
Aug 09 08:03:33 192.168.1.5 5019: From: <5743060212>;tag=cueefb1b7bf
Aug 09 08:03:33 192.168.1.5 5020: Call-ID: E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:33 192.168.1.5 5021: CSeq: 6 SUBSCRIBE
Aug 09 08:03:33 192.168.1.5 5022: Content-Length: 0
Aug 09 08:03:33 192.168.1.5 5023: Contact: <5743060212>
Aug 09 08:03:33 192.168.1.5 5024: Expires: 0
Aug 09 08:03:33 192.168.1.5 5025: Event: refer;id=2
Aug 09 08:03:33 192.168.1.5 5026:
Aug 09 08:03:33 192.168.1.5 5027: 070558: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
Aug 09 08:03:34 192.168.1.5 5028: 070559: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:34 192.168.1.5 5029: 070560: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0
Aug 09 08:03:34 192.168.1.5 5030: 070561: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
Aug 09 08:03:34 192.168.1.5 5031: 070562: Aug  9 08:03:33.859 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:34 192.168.1.5 5032: 070563: Aug  9 08:03:33.859 EDT: //5599/DF196693A97A/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 2
Aug 09 08:03:34 192.168.1.5 5033: 070564: Aug  9 08:03:33.859 EDT: //0/000000000000/SIP/Error/sipGenCheckRequest: Rejecting request. Status(1000)
Aug 09 08:03:34 192.168.1.5 5034: 070565: Aug  9 08:03:33.859 EDT: //0/000000000000/SIP/Info/act_dialog_active_new_msg_request: Dropping Request.
Aug 09 08:03:38 192.168.1.5 5035: 070566: Aug  9 08:03:38.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleServerTCBTimerPop: Die timer Popped on TCB(0x4A456F90)
Aug 09 08:03:38 192.168.1.5 5036: 070567: Aug  9 08:03:38.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 2
Aug 09 08:03:38 192.168.1.5 5037: 070568: Aug  9 08:03:38.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A456F90) from EDB(0x4E58CAB8)
Aug 09 08:03:38 192.168.1.5 5038: 070569: Aug  9 08:03:38.127 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A456F90) for reuse
Aug 09 08:03:38 192.168.1.5 5039: 070570: Aug  9 08:03:38.127 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Transactions still active on Event:telephone-event ID:
Aug 09 08:03:38 192.168.1.5 5040: 070571: Aug  9 08:03:38.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleServerTCBTimerPop: Die timer Popped on TCB(0x4A456DFC)
Aug 09 08:03:38 192.168.1.5 5041: 070572: Aug  9 08:03:38.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
Aug 09 08:03:38 192.168.1.5 5042: 070573: Aug  9 08:03:38.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x4A456DFC) from EDB(0x4E6C1FA8)
Aug 09 08:03:38 192.168.1.5 5043: 070574: Aug  9 08:03:38.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x4A456DFC) for reuse
Aug 09 08:03:38 192.168.1.5 5044: 070575: Aug  9 08:03:38.191 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 2 EDBs on edbQ
Aug 09 08:03:38 192.168.1.5 5045: 070576: Aug  9 08:03:38.191 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x4E6C1FA8)
Aug 09 08:03:38 192.168.1.5 5046: 070577: Aug  9 08:03:38.191 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x4E6C1FA8) for reuse
Aug 09 08:03:38 192.168.1.5 5047: 070578: Aug  9 08:03:38.191 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
Aug 09 08:03:38 192.168.1.5 5048: 070579: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[2580] removed.
Aug 09 08:03:38 192.168.1.5 5049: 070580: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Aug 09 08:03:38 192.168.1.5 5050: 070581: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4A44C280 key=E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.1
Aug 09 08:03:38 192.168.1.5 5051: 070582: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Aug 09 08:03:38 192.168.1.5 5052: 070583: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/ccsip_qos_cleanup: Entry
Aug 09 08:03:38 192.168.1.5 5053: 070584: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
Aug 09 08:03:38 192.168.1.5 5054: 070585: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Aug 09 08:03:38 192.168.1.5 5055: 070586: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
Aug 09 08:03:38 192.168.1.5 5056: 070587: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Aug 09 08:03:38 192.168.1.5 5057: 070588: Aug  9 08:03:38.251 EDT: //5599/DF196693A97A/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4A44C280
Aug 09 08:03:38 192.168.1.5 5058: 070589: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
Aug 09 08:03:38 192.168.1.5 5059: 070590: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:38 192.168.1.5 5060: 070591: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting server EDB flag
Aug 09 08:03:38 192.168.1.5 5061: 070592: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Events still active on this Subscription Dialog
Aug 09 08:03:38 192.168.1.5 5062: 070593: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
Aug 09 08:03:38 192.168.1.5 5063: 070594: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
Aug 09 08:03:38 192.168.1.5 5064: 070595: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting Client EDB flag
Aug 09 08:03:38 192.168.1.5 5065: 070596: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
Aug 09 08:03:38 192.168.1.5 5066: 070597: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x48210D64)
Aug 09 08:03:38 192.168.1.5 5067: 070598: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x48210D64) for reuse
Aug 09 08:03:38 192.168.1.5 5068: 070599: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPITerminateEvent: Freeing SCB(0x4E2ED5F4), 0 active events present
Aug 09 08:03:38 192.168.1.5 5069: 070600: Aug  9 08:03:38.251 EDT: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[2581] removed.
Aug 09 08:03:38 192.168.1.5 5070: 070601: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromClientTable: Removing SCB(0x4E2ED5F4) with Key(E0639ABE-A2E411DF-A97FA2EC-4EA10D61@192.168.3.11ECA0F34-0) from Client Table
Aug 09 08:03:39 192.168.1.5 5071: 070602: Aug  9 08:03:38.251 EDT: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromSubIDTable: Removing SCB(0x4E2ED5F4) with Key(5605) from SubID Table
Aug 09 08:03:39 192.168.1.5 5072: 070603: Aug  9 08:03:38.255 EDT: //0/000000000000/SIP/Info/sipSPIFreeOneSCB: EnQing SCB(0x4E2ED5F4) for reuse
Too much debug, include only ccsip message as indicated before.
I am having some trouble with the router becoming unresponsive when playing with this almost like the call is get
ting stuck in some kind of loop or something, anyway I am going to try to set this up in a router
we are not using this weekend and see if I can replicate the issues on it. That way I am not having to reboot our main router, If anybody has any ideas before then I'll be glad to take them.
thanks again,
Gary
Also use stable IOS only, eg 12.4.22 YB5, 12.5(0)M3
And a modicum of debug only.
