B-ACD on CME Not working
zarafa.nicolas
I have configured B-ACD on CME. the problem is when i call the hut pliote number(300) , i dont hear any thing , and after 10 sec i m redirected to the Ephone-DN (1100).
The scenario that i want to use is :  when the caller call the hunt pilote number (3000) , the caller hear the welcome message, and after 10 sec , the call is redirected to the ephone-dn 1100.
Please , find the configuration :
application
service aa flash:app-b-acd-3.0.0.2.tcl
  paramspace english index 1
  param number-of-hunt-grps 1
  param queue-len 15
  param dial-by-extension-option 1
  paramspace english language en
  param max-time-vm-retry 2
  param aa-hunt1 3000
  param aa-pilot 3000
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt en_bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 700
  param service-name queue
service queue flash:app-b-acd-aa-3.0.0.2.tcl
  param queue-len 15
  param aa-hunt1 3000
  param queue-manager-debugs 1
dial-peer voice 1000 voip
service aa
destination-pattern 3000
session target ipv4:100.80.50.254
incoming called-number 3000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
ephone-dn  1  dual-line
number 1100
label STANDARD
description 1100
name STANDARD
corlist incoming INTERNE
corlist outgoing INTERNE
hold-alert 30 originator
ephone-dn  2
number 5000
label appelant
description appelant
name appelant
telephony-service
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
moh-file-buffer 10000
authentication credential secretname psswrd
max-ephones 265
max-dn 250
ip source-address 100.80.50.254 port 2000
auto assign 1 to 10
auto assign 1 to 20
service phone webAccess 0
system message TTTT
cnf-file location flash:
cnf-file perphone
  load 7962 SCCP42.9-1-1SR1S.loads
load 6921 SCCP69xx.9-1-1-0.loads
load 6961 SCCP69xx.9-1-1-0.loads
time-zone 22
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh hold1.wav
multicast moh 239.10.16.4 port 16384
web admin system name admin password admin
dn-webedit
time-webedit
transfer-system full-consult
directory last-name-first
create cnf-files version-stamp Jan 01 2002 00:00:00
Please , would you help me to resolve this issue
Thanks in advance
Nicolas
12 Replies 12
paolo bevilacqua
You need to configure drop-through mode for the call to go automatically to a destination. That is explained in the B-ACD documentation.
Chris Deren
You are using the wrong tcl scripts for the applications
AA should be using AA script, and queue should be using acd script, you have:
Also, the queue script aa-hunt 1 should point to the hunt pilot, you are pointing back to the AA:
param aa-hunt1 3000
Chris
Hi all ,
i have the same issue
i m using Cisco CME and i want to use B-ACD Script. i want only when the caller ( outside our inside) can call the number 4000 and then hear the "welcome message". and after that, the call go the the number 1000.
The problem, is when i call the number "4000", the call can't be established.
Please find the Configuration of the B-ACD :
application
service aa flash:app-b-acd-aa-3.0.0.2.tcl
  param second-greeting-option 1
  param call-time-call-retry 700
  paramspace english index 0
  param handoff-string aa
  param aa-pilot 4000
service queue flash:app-b-acd-3.0.0.2.tcl
  param queue-len 10
  param aa-hunt1 7000
service aa
destination-pattern 4000
session target ipv4:192.168.100.1
  incoming called-number 4000
codec g711ulaw
no vad
ephone-hunt 1 sequential
pilot 7000
list 1000
timeout 10
Plase, would mind tohelp to resolve this usse
Thanks in advance
Hicham
Please read my post above.
Hi all , the Script work .
application
  param drop-through-option 1
  param aa-pilot 8000
  param drop-through-prompt _bacd_welcome.au
  param voice-mail 5000
  param queue-len 10
  param aa-hunt1 5071
dial-peer voice 1000 pots
service aa
incoming called-number 8000
port 0/1/0
dial-peer voice 2000 voip
service aa
destination-pattern 8000
codec g711ulaw
pilot 5071
list 1100
timeout 10
Another question if it’s possible. I want that  for the External incoming calls, the caller hear the Welcome message and in parallel the phone ring (1100) ?
thanks
I don't see how this would be possible.
Chris
Could you help please ?
I have the same problem and is not working till now
I am having similar issues to those described here, in my case the calls are accepted by the aa and are forwarded to the hunt group, they ring until the hunt list times out and then the call terminates. The call is not pulled back into the queue after the 'param call-retry-timer' expires.
I have a working configuration at another site where the call flow behaves as expected, my sw versions and config is identical as far as I can tell.
I do notice one small difference with the 'sh call application session' command
The working system, while idle has the following
CMEworking#sh call application sess
Session ID 2
            App: RetrProxy
           Type: Service
            Url: builtin:RetrievalProxy_Service.C
Session ID 259
        Session name: 1
             App: callq
           Type: Service
            Url: flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
While the other unit only has the one Session up
CME-not-working#sh call application sess
Session ID 259
        Session name: 1
             App: callq
           Type: Service
Config as below
application  service aa flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
   param aa-pilot 70030
   paramspace english location flash:/bacdprompts/
   param second-greeting-time 30
   param drop-through-prompt not_set
   param call-retry-timer 20
   param voice-mail 70000
   param max-time-call-retry 90
   param service-name callq
service callq flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
   param queue-len 10
   param aa-hunt1 70040
session
   start 1 callq
dial-peer voice 70030 voip
description pilot for ACD Queue
service aa
destination-pattern 70030
session protocol sipv2
session target ipv4:172.30.129.254
incoming called-number 70030
codec g711ulaw
no vad
pilot 70041
list 70201, 70202, 70203
timeout 3, 3, 3
description Reception Hunt Group
Which IOS are you running on the two sites?
I am running 15.1(4)M3 at both sites
TCL Scripts 3.0.0.2
I have logged a TAC case, will post back early next week with the outcome
Can you take "debug voice application scripts" and "debug ephone hunt", with "terminal monitor".
You can also try a reload just fo the sake of it.
Unrealated, as an improvement for call qwuality, you can tie aa service to pots DP. You can keep the voip DP for testing from internal phones.
DOUG GODING
Thanks all for the input
I worked out the resolution for this one while I was setting up another CME router
If MOH is not configured this issue comes up
Once MOH was configured, this issue went away
Looking back through the following document
'Cisco Unified CME B-ACD and Tcl Call-Handling Applications'
I found this statement which explains the issue I have been experiencing
Prerequisites
In Cisco Unified CME 4.2 and later versions, music on hold (MOH) must be configured for services using MOH. If an MOH server is not available, incoming calls disconnect. For configuration information, see “Configuring Music on Hold” in the Cisco Unified CME System Administrator Guide.
