BACD Handoff to Extension
Nick Richards
Beginner
Beginner
I'm trying to get my BACD script (AA+Queue) to "handoff" the call to an extension/line, rather than queue to it.
To break it down:
I have the AA service, configured with "1" as the dial-by-extension-option
I have the Queue service configured with 4 additional hunt groups (param aa-hunt2 thru 5)
When I press "1", I dial the extension and hear ringtone, then voicemail if no answer.  This is perfect...
When I press any of the 2 thru 5 options, I'm trying to forward the call to a specific department's front desk.  However, the call gets queued rather than forwarded, and I hear hold music while the destination rings.  I do not want those options to receive any queue treatment-- no hold music, no special features, just a regular forwarded call.
What it does:
If i select option 1, then dial extension 1001 I hear the phone ring and [if no answer] go their voicemail.
If i select option 2 (param aa-hunt2 1001), I hear hold music and the timeout value sends me to central mailbox.
If i select option 3 (param aa-hunt3 1002), I hear hold music and the timeout value sends me to central mailbox.
What I want:
If i select option 2 (param aa-hunt2 1001), I hear the phone ring and [if no answer] go to voicemail for 1001.
If i select option 3 (param aa-hunt3 1002), I hear the phone ring and [if no answer] go to voicemail for 1002.
If i select option 4 (param aa-hunt3 1003), I hear the phone ring and [if no answer] go to voicemail for 1003.
If i select option 5 (param aa-hunt3 1004), I hear the phone ring and [if no answer] go to voicemail for 1004.
Is there any way to reconfigure or workaround this?  Can I hairpin a call, or invoke a service, or anything else??
Versions:
CME 8.6, IOS 15.1(4)M
Thanks in advance!
NR
As mentioned above: there is no way.
If you want an AA that you can fully control, use one on CUE.
9 Replies 9
sumimanc
Can i have the config please ???
sumit
service main_aa flash0:bacd_main/app-b-acd-aa-3.0.0.2.tcl
  paramspace english language en
  paramspace english index 1
  param handoff-string main_aa
  param voice-mail 4500
  param dial-by-extension-option 1
  paramspace english location flash0:bacd_main/
  param welcome-prompt _bacd_welcome_main.au
  param aa-pilot 1234
  param service-name main_queue
  param number-of-hunt-grps 6
service main_queue flash0:bacd_main/app-b-acd-3.0.0.2.tcl
  param aa-hunt4 1003
  param aa-hunt5 1004
  param queue-manager-debugs 1
  param aa-hunt6 1003
  param aa-hunt2 1001
  param aa-hunt3 1002
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
That is normal.
With B/ACD-AA, call to hunt-groups are always queued even momentarily, and never transferred directly as with extension transfer.
However from my experience, before the timer "second-greeting", callers should hear ringback (if a phone is ringing). After that, MoH.
Callers immediately hear MoH when going into queue.  Is there a variable I'm missing to support this ring-at-first behavior?
There is no variable that I know about. It may have to do with the fact you're using an extension and not a real hunt-group.
Is there no way to invoke the same process the Dial-By-Extension option uses?
Paolo is right on all accounts.
Here are my findings:
  • Forwarding a call from BACD to an extension provides the same MoH as if the call were in queue.  If that call is instead forwarded to a drop-through AA with no prompt specified, the caller hears ringback instead of MoH.
  • There is only one queue service allowed per device, a fact that is difficult to find in the standard documentation.  I had multiple queues configured, but all AAs referencing secondary queue(s) instead invoked the primary queue service.
Short story: Stick with CUE if you have enough ports.
NR
Nick, thank for your appreciation.
If you're interested in working out something without buying a CUE, contact me at the address present in my profile.
Recognize Your Peers
