04-20-2007 06:46 AM - edited 03-14-2019 09:05 PM
Hello , I need a example for configure two 3640 back to back with fxs to fxo. voip-a---3640-fxs-fxo-3640--voip-b. My problem is when call from voip-a to the voip-b , and recive disconnect from voip-b , in the voip-a hear ringback all time
04-20-2007 07:08 AM
This is typical of fxo/fxs. Look at:
http://cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
on CCO.
Try configuring both ports for ground start or another disconnection supervision as explained in the document.
04-20-2007 07:34 AM
I see this later but I have loop-start configured .
Need change to Ground?
04-20-2007 08:02 AM
Have you read the document? It will explain you why without supervision your lines are going to remain stuck all the time. So, either ground-start, or other disconnection supervision must be configured.
