Cisco Community Designated VIP Class of 2020
331
Highlighted
Beginner
Background Images on 7940/7960s:
I am trying to add background images to IP phones on CUCM 4.1(3). I note the following documents which contain all of the info:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/4_1_3/english/administration/guide/7961cus.html
HOWEVER, I am using 7940/7960s. Can anyone confirm whether the file formats are the same or, if they're different, what the correct requirements are.
Everything much appreciated...
Cheers,
Stu
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: Background Images on 7940/7960s:
No, they're not the same
7940/60 only accept idle images, you search either CCO for idle image or NetPro as there are hundreds of posts on this
PLEASE search NetPro for answers before posting
java
if this helps, please rate
java
1 REPLY 1
java
java
Content for Community-Ad
FusionCharts will render here
