I need to pull the virtual machine for CUCM 8.6 off the UCS server, rebuild the server and then restore it. Does any have a link to the best practices for copying the VM off of the server?
As mentioned previously in my previous article and following the same idea of certificate pinning in Cisco Meeting Server, to demonstrate this concept added since version 3.0. I used two different CA to sign :1-The WebBridge certificate with CA's certific...
view more
Certificate pinning is introduced on cisco meeting server starting in CMS 3.0 to help prevent man in the middle attack.But what is the Certificate Pinning?Traditionally, SSL Handshake consists on the validation of the server's certificate, let's say colla...
view more
In a Clustering over the WAN deployment, securing the ICCS (Intra-Cluster Communication Signaling) traversing the WAN can be a requirement. The IPSEC VPN Policy between nodes can be configured to secure the ICCS Traffic.To quickly verify that the IPSEC is...
view more
Attracted by the concept of dial plan and the passion of writing, I launched a challenge to write a workbook with practical scenarios covering in details this concept, the result is a workbook with 30 practice labs treating many components such route patt...
view more
Understanding Media Negociation in Interworking / Traversal Call : SIP <-> H323 through Expressway. Inside SDP and H245. Both signaling and Media goes through the Expressway so the IP address of expressway is offered to both SIP and H.323 endpoin...
view more
