06-24-2015 02:24 PM - edited 03-17-2019 03:28 AM
Hello Support,
Is it possible to run dual PRI's that can route over the same phone numbers through the backup PRI in the event your primary PRI goes down? If so, what devices are typically needed for this?
Really am seeking a solution to keep our phones afloat in case our primary PRI goes down, so any solution would certainly be helpful.
Thanks in advance!
Solved! Go to Solution.
06-25-2015 08:44 AM
Correct, another common approach is to have separate Local and LD ISPs, having one provider to handle Local calls, and another for Long Distance.
Not sure if you are looking to implement new system or add onto an existing and which country you are at, but SIP trunking is the technology of choice for new implementations and same consideration needs to take place, hence many larger customer opt to get SIP trunks from 2 different carriers.
06-24-2015 03:21 PM
For outbound you are in full control, so simply configure your dial peers accordingly with preference command, or use trunk group configuration (assuming SIP or H323 config), if MGCP list accordingly in route group.
For inbound this is on telco and the only way to make it work is to have the telco company put both PRIs in common trunk group.
Chris
06-25-2015 07:58 AM
Thanks Chris!
We were really looking to use two separate providers for the PRI trunks though. We assume that if that ISP is having an issue, both our PRI lines will go down from them.
Is it just as simple as running the two separate PRI lines into a PBX and configuring the PBX as needed? Thanks again Chris!
06-25-2015 08:16 AM
Well, not that simple.
Again, lets separate inbound from outbound:
Outbound - You can certainly use both PRIs for outbound calling as long as the ISP does not do ANI screening, so if they only allow outbound calls with their calling party presentation you would need to mask the caller ID on the secondary PRI to something they trust
Inbound - you cannot have PRIs from different carriers in one trunk group, so each one would be responsible for different DIDs. I suppose you can do second set of DIDs and then perform translations to internal extensions, but to me it's not worth the effort.
06-25-2015 08:35 AM
Understood. So, a company looking for PRI redundancy just uses multiple trunks from the same ISP in most cases if they want numbers to stay the same?
06-25-2015 08:44 AM
06-25-2015 08:48 AM
With the SIP trunks from two providers scenario, in the event an entire trunk goes down from one provider, do larger companies configure numbers incoming and outgoing to route the same DIDs over the backup carrier?
06-25-2015 09:04 AM
No, you cannot share DIDs across providers, typically customer would use one provider to server some locations and another provider to server other locations, so that when one trunk is down it does not affect inbound calling to entire enterprise.
06-25-2015 09:33 AM
ask your telco providers what they can do may be for extfa charge
