04-22-2015 12:18 AM - edited 03-17-2019 02:45 AM
what is the bandwidth requirement of cisco 9971 model phone during registration?
04-22-2015 12:31 AM
SRND has bandwidth calculation/requirement for both media and signaling...
04-22-2015 01:38 AM
vivek, can you please giv me the link of SRND
04-22-2015 01:53 AM
SRND has bandwidth calculation for voice and video traffic.I wanted to know about the bandwidth requirement during the registration process of cisco 9971 ip phone.
04-22-2015 02:09 AM
Check chapter 3-49 "Provisioning for Call Control Traffic" in SRND version 10. You will get what you are looking for.
04-22-2015 12:28 PM
Thanks a lot Vivek... I went through it...but I think it talks about the bandwidth provisioning for voice traffic..for signalling and once the call is established....I neeed to know the bandwidth required just for registration ...i.e. in the following steps ( only registration without placing any call)
1. The phone contacts the TFTP server and requests the Certificate Trust List file .
2. The phone contacts the TFTP server and requests its SEP<mac-address>.cnf.xml configuration file.
3. The Phone downloads the default configuration XMLDefault.cnf.xml file from the TFTP server.
4. The SIP phone requests a firmware upgrade (Load ID file) and upgrades the firmware image automatically when required for a new version of CUCM.
5. The phone downloads the SIP dial rules configured for that phone.
6. The phone Establish connection with the primary CUCM and the TFTP server end to end.
7. The phone Registers with the primary CUCM server listed in its configuration file.
8. The phone downloads the appropriate localization files from TFTP.
9. The phone downloads the softkey configurations from TFTP.
10. The phone downloads custom ringtones (if any) from TFTP.
Also, I need t o know if the bandwidth required for this process is same for all phone models or different? Specifically, I need this data for Cisco 9971 model.Please help...Thanks..
05-09-2015 02:54 PM
Hi noc mcc
Do you found your answers?
br Oleksandr
06-11-2015 01:48 AM
no oleksandr, can you help?
04-22-2015 12:29 PM
04-22-2015 01:47 AM
12-06-2018 09:02 AM
I have the same question or nose if it is similar or different
I would like to know how much bandwidth is consumed, only when the phone is registered, without making any calls, just registered, what happens is that we will place a centralized solution and we need to size QoS with the SP to guarantee good voice communication through the WAN, in a remote location I will have 140 telephones and I need to know how much BW needed separates for the voice QoS,
There is documentation of how much you consume per call according to the codec, but you can not find any document of how much a Cisco phone consumes just because it is registered to the Call Manager (this is for remote sites that go through a wan)
Any comments will be welcome.
Carlos P
12-06-2018 01:37 PM
I hope everybody found this link https://cway.cisco.com/tools/vccalc/ for call estimates
Registration estimates are different, just consider the boot up process for an IP Phone and measure that.
The file size (based on feature, dialplan, protocol and phone model) varies + all registration signaling messages will give you the bandwidth for a phone - It is something you will have to measure on your own most of the time.
Actual calls will consume more bandwidth so as long as you have your math right for your QoS policies, you should not have problems with registration.
