bandwidth requirement for call signaling, cucm on the cloud.
hamed1900
How I can calculate bandwidth requirenemnt for call signaling and TFTP for remote Site using cucm, Unity, Contact Centre on the Cloud?
Hamed
Hi Hamed,
It depends the encapsulation used to send/receive packets but for SCCP/SIP signaling I always assume the10% bandwith use for RTP as a guideline for the signaling bandwith.
When you're running TFTP there's not way to assume a amount of bandwith because the phones always will try to download the files as fast as they can because is a application not just signaling. Remember TFTP is on the application layer:
OSI model
7. Application layer
6. Presentation layer
5. Session layer
4. Transport layer
3. Network layer
2. Data link layer
1. Physical layer
Please rate all useful posts
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice, CCNP Voice Certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Hi Leo,
Thank you for your reply.
If the UC solution is on the cloud, I do not need to consider RTP as it runs between users in this case.
For TFTP fair enogh, I agree with you but how much bandwidth exactly CUCM uses for  signaling  per Call?
Hamed Monfared
It depend the codec you're running. Use the link give by Islam below.
islam.kamal
Level 10
Level 10
Your required bandwidth will be based on your codec which will be used , kindly find the below links
https://learningnetwork.cisco.com/docs/DOC-7873
https://learningnetwork.cisco.com/thread/26795
https://learningnetwork.cisco.com/docs/DOC-11113
Thank you
please rate if this will help
