05-04-2012 05:41 AM - edited 03-16-2019 10:59 AM
Hi All,
A very basic query regarding the barging sound.
THe user is requesting to get that so called - annoying beep according to them removed asap. So wanted the parameter on the device page, from where we can remove the same. Is it the single button barge option on device... or other ring settings on the specific line.
Abhishek
Solved! Go to Solution.
05-04-2012 05:55 AM
Hi Abhishek,
Hope all is well buddy
The individual and system settings are shown below;
With the party entrance tone feature, a tone plays on the phone when a basic call changes to a multiparty call; that is, when a basic call changes to a barged call, cBarged call, ad hoc conference, meet-me conference, or a joined call. In addition, a different tone plays when a party leaves the multiparty call.
If the controlling device, that is, the originator of the multiparty call has a built-in bridge, the tone gets played to all parties if you configured party tone entrance for the controlling device. When the controlling device leaves the call, Cisco Unified Communications Manager identifies whether another device on the call can play the tone; if another device on the call can play the tone, Cisco Unified Communications Manager plays the tone. If the controlling device cannot play the tone, Cisco Unified Communications Manager does not play the tone even if you enable the party entrance tone feature.
When a barge call gets created, the party entrance tone configuration of the barge target that shares the line with the barge initiator determines whether Cisco Unified Communications Manager plays the party entrance tone.
When a cBarge call gets created, the party entrance tone configuration of the cBarge target that shares the line with the cBarge initiator determines whether Cisco Unified Communications Manager plays the party entrance tone. However, if the call for the target is an existing ad hoc conference that is in the same cluster, the party entrance tone configuration for the ad hoc conference controller determines whether Cisco Unified Communications Manager plays the tone.
To use the party entrance feature, ensure that you turned the privacy feature off for the devices and ensure that the controlling device for the multiparty call has a built-in bridge. In addition, either configure the Party Entrance Tone service parameter, which supports the Cisco CallManager service and the entire cluster, or configure the Party Entrance Tone setting per directory number in the Directory Number Configuration window (Call Routing > Directory Number). For information on the service parameter, click the question-mark button in the Service Parameter window. For information on the Party Entrance Tone setting in the Directory Number Configuration window, refer to the "Directory Number Configuration Settings" section in the Cisco Unified Communications Manager Administration Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmfeat/fsbarge.html#wp1094768
Cheers!
Rob
"Everything is broken" - Bob Dylan
05-04-2012 05:55 AM
Hi Abhishek,
Cheers!
Rob
05-04-2012 06:11 AM
Awesome Rob..
Not everything is fine..
The manager flunged the phone on the wall because of the beep .
05-04-2012 06:12 AM
If only i could have given you a slam dunk 10 pointer for this , Thanks again
05-04-2012 06:17 AM
Hi Abhishek,
You are always welcome my friend
If the manager threw the phone against the wall because of the Beep then
he/she has bigger problems than a Barge tone I guess my new
signature really is true in this case.
Take care...there's nothing you can do about crazy users
Cheers!
Rob
