Walkthrough Wednesdays
458
Highlighted
Beginner
Basic Dial Peer question
OK - sometimes this stuff just doesn't work like I expect it to for no apparent (to me) reason. Platform is CME.
I want to send outgoing calls to a specific number via h323 to a remote site.  I have several dial-peers, but I believe that only two are relevant to this discussion:
dial-peer voice 4 pots
description Outbound 10 digit calls
destination-pattern [2-9]..[2-9]......
port 0/0/0
forward-digits all
dial-peer voice 500 voip
description To voice mail
destination-pattern 6512221212
session target ipv4:10.22.12.12
dtmf-relay h245-alphanumeric
codec g711ulaw
If i pick up a phone and dial 6512221212 my call is routed dial peer 4 every time.  Please help me understand why!
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
I assume the IP 10.22.12.12 is reachable from the local H.323 gateway. For a pots and a voip dial-peer i have not seen this problem occuring but this problem occurs for 2 voip dial-peers.  You need to give preference command to make things work in that case.
Which version of IOS are you running?
Post the output of show dialplan pattern 6512221212 from the gateway. Also post the output of debug voip dial-peer when a call is made to 6512221212.
Nitesh
PS:Pl rate helpful posts
3 REPLIES 3
Highlighted
Enthusiast
Nitesh
Highlighted
I haven't done a lot of IOS dial peers, mostly CUCM.  When I have used preference before, it was always for trunk selection - it never occured to me that it would affect pattern selection.  I forget that the selection criteria is by number of positions matched, so
number 6512221212 matches pattern 6512221212 in 10 positions
  and
number 6512221212 matches pattern .......... in 10 positions
It doen't seem like it should be a tie (particularly for a call manager guy like me!) but it is.
Thanks so much Nitesh!
Highlighted
Ya i do understand that. Happens to most of us.
Good to know that the issue has been resolved.
Mark this thread as answered if you feel this issue has been resolved just for the sake of completeness.
Nitesh
Content for Community-Ad
