Showing results forĀ
Search instead forĀ
Did you mean:Ā
Basic IVR (interactive voice response) on Cisco IOS Router 2800
ronin
Hi all
I have a sip trunk and 4 fxo module on my cisco 2811 router.
A and I want to configure a basic IVR on my router but I do not know in which format should I create my sound files and record them in Router (compact flash or USB cool-disk? )
And how should I configure a basic and simple IVR on router?
  Do you have any sample config to share with me ?
Thanks in advance
6 Replies 6
Flo.Matalis
You may refer to this document for the IVR:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/bacd/configuration/guide/cme40tcl/40bacd.pdf
Page 10:
If you do rerecord any of the audio files, note that the Cisco Unified CME B-ACD prompts require a G.711 audio file (.au)
format with 8-bit, mu-law, and 8-kHz encoding.
Thanks for your reply
unfortunately I have problem in opening the link
would you please send me the pdf file ?
thanks in advance
Attached you may find all you need.
Hope this helps,
G
Hope the above helps,
gsotirop
Thanks Geos.
thank you so much
I ll check it
5 Stars to Ronin who also suggested this solution :)
gsotirop
