Im struggling with QoS configuration on my local network (check attached file). I made basic configuration.
There is vlan from switch card on router to phones and WAN port to PC. Everything works fine. Then I establish connection between routers through radios and I need to configure QoS in this network to prioritize communication between IP phones. Can someone please give me advice of basic configuration to my routers. Its needed that ip phones have priority.
Thank you!
