11-03-2017 04:41 PM - edited 03-17-2019 11:32 AM
I apologies for what is likely to be a very trivial question to many but I'm learning from the ground up! (sub terrain in fact)
I have inherited a 2821 with CME installed. With that came a few 7970G phones and a 3750PS-S router.
So a few basic of questions....
1. Do I need to have a TFTP Server connected in the system somewhere?
2. If so, what files do I need server home folder, I have the latest 7970 SCCP tar. How is it added within the network?
3. Is there a how to anywhere out there? Despite my best efforts all the youtube/help content is aimed a few rungs above where I am right now. My learning style is practical so assemble/dissemble is the way I retain.
Any pointers are really appreciated.
Tom
11-03-2017 04:48 PM
If there is enough flash memory, then the router can act as a TFTP server.
11-03-2017 04:51 PM
Thanks - Is this configuration called something special or can you point me in the right direction? Thanks
11-03-2017 06:24 PM - edited 11-03-2017 06:26 PM
If the file(s) are in the flash of the router, do this:
conf t tftp flash0:filename.ext end
Do this to each file.
Optionally, you can specify which Interface TFTP can traverse:
conf t ip tftp source <BLAH> end
And you can make things faster too by increasing the TFTP block size.
conf t ip tftp block <up to 8192> end
11-03-2017 11:43 PM
Thanks. Not sure that is all immediately obvious to me but with some research around it that is going to be start.
If for instance I was to have a TFTP server sat on the port 48 of the C3750 who would the 7970's be directed towards it?
Right now I'm not able to make changes to any Network settings in the 7970 in the phone.
