07-04-2011 09:45 AM - edited 03-16-2019 05:46 AM
hi! What's the advantage of having 2x PRI ports? Is there any limitation of concurrent call in 1 PRI port? Is it 30 concurrent call or depend on the line that we are subscribing to? What are the type of line available and different between these lines?
Thanks.
07-04-2011 03:01 PM
Ok
Advantage of having 2 pri is more channels redundancy as well also it depends how big ur network is and how many channels u need
The limitation of using 1 pri for in and out calls again depends on the size if ur network if it's quickly over utilized the you might need another pri but using in and out in the same pri with right number of pri and channels based on the network need has no issue !
Pri are two types mainly in isdn
E1 which gives you 30 channels
And t1 gives you 23 channels
Depending on ur region you can know which one u can use
Hope this help
If helpful rate
07-05-2011 03:57 AM
hi! Thanks for the reply, the 30 channels here (E1), does that means 30 concurrents call session? or is it outgoing 30 concurrent calls + 30 concurrent incoming calls, thus total 60 calls?
07-05-2011 04:18 AM
Those are 30 DS0s. One DS0 = 1 call. You get 30 calls per E1.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-05-2011 07:41 AM
hi! Does that mean if i've a site with 100 users and i want to ensure that the system can cover >=60% concurrent call of that 100 users, i will need at least 2 PRI interface in my mediaGW with subscription of 2x E1 ISDN lines? Is my concept correct?
What's the next higher capacity interface after PRI? What happen if i've a site with 1000 users? I will need xx number of PRI interface with xx number of E1 ISDN lines?
Thanks.
07-05-2011 10:04 AM
You might also look into SIP trunks if you want more capacity.
java
