Hello All
How do I use bat to associate the line to a user. I can't seem to find the relevant field in the bat template.
See attached print screen of the field in question.
Feisal
Hi Feisal,
Are you planning to associate the device to the user? if yes, use the BAT Users teplate and make number of controlled devices as 1, there will be an extra column getting added to this User telmplate fill it accordingly and upload it.
Hope it helps.
Anand
Please rate helpful posts !!
You already got a reply from Leonardo in your post about Jabber reporting and add CSF devices using BAT.
Here's the link again in case you missed it the first time.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080b6e537.shtml#prob1
Please rate all useful posts.
Hope this doc helps.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html#line
Andrew.
