BAT to update controlled devices while LDAP sync is enabled
Nerton
Our organization is doing a phone refresh on about 3300 devices and we've managed to BAT everything except for the controlled devices field under user profiles.
We try to do this through Bulk Administration > Users > Update Users and we use # as the variable to ignore fields.
The issue we run into is that the User ID field is needed to specify control the device but LDAP prevents this field from being "updated" (even though we don't want to change it) and the update fails as a result.
I can't imagine Cisco expects large enterprises to manually do this for every single device so I suspect I'm missing something. Any help would be appreciated!
Just remove the columns you do not want to update, never seen # being used for this purpose.
All you need is the mandatory field (UserID) and then any other column you want to update i.e. CONTROLLED DEVICE.
Also, you can use the "Update Users" sheet on the BAT.xls file you can download from your CUCM.
5 Replies 5
Chris Deren
Can you please attach an example of the BAT file you are attempting to run?
FIRST NAME
MIDDLE NAME
LAST NAME
USER ID
PASSWORD
MANAGER USER ID
DEPARTMENT
PIN
DEFAULT PROFILE
USER LOCALE
TELEPHONE NUMBER
PRIMARY EXTENSION
ASSOCIATED PC
IPCC EXTENSION
MAIL ID
PRESENCE GROUP
SUBSCRIBE CALLING SEARCH SPACE
ALLOW CONTROL OF DEVICE FROM CTI
DIGEST CREDENTIALS
USER GROUP
CONTROLLED PROFILE
CONTROLLED DEVICE
PASSWORD LOCKED BY ADMIN
PASSWORD CANT CHANGE
PASSWORD MUST CHANGE AT NEXT LOGIN
PASSWORD DOES NOT EXPIRE
PASSWORD AUTHENTICATION RULE
PIN LOCKED BY ADMIN
PIN CANT CHANGE
PIN MUST CHANGE AT NEXT LOGIN
PIN DOES NOT EXPIRE
PIN AUTHENTICATION RULE
ENABLE MOBILITY
ENABLE MOBILE VOICE ACCESS
REMOTE DESTINATION LIMIT
MAXIMUM WAIT TIME FOR DESK PICKUP
PASSWORD IMSINFO
PIN IMSINFO
USER PKID
JoeUser
SEPMAC
This is the format I got from here: https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html
It’s in a .csv file and it’s formatted the same as all of the other BAT jobs I do. The # is the variable I used for ignored fields and this is the error I received after it failed: Failure Details :
users Error Code Error Description
Warning :
LDAP Sync status is enabled. Some fields cannot be updated.
JoeUser It is not possible to convert between the specified types.
Result Summary :
UPDATE for 0 USERS passed.
UPDATE for 1 USERS failed.
Thanks for the help! I was wondering why so much information was required when all of the other files only required the desired fields *face palm*.
Laura_Morales
Besides the solution provided, which worked also for me, I realized when I exported the -end users- from Export menu, the field Controlled Device was named in the file as DEVICE NAME 1, DEVICE NAME 2, ..... But for updating an end user using Custom File, the field should be named CONTROLLED DEVICE 1, CONTROLLED DEVICE 2, .....
So keep that in mind, the column in the .csv file should be named CONTROLLED DEVICE 1 in order to associate a phone to an end user.
