02-21-2018 09:42 AM - edited 03-17-2019 12:15 PM
Our organization is doing a phone refresh on about 3300 devices and we've managed to BAT everything except for the controlled devices field under user profiles.
We try to do this through Bulk Administration > Users > Update Users and we use # as the variable to ignore fields.
The issue we run into is that the User ID field is needed to specify control the device but LDAP prevents this field from being "updated" (even though we don't want to change it) and the update fails as a result.
I can't imagine Cisco expects large enterprises to manually do this for every single device so I suspect I'm missing something. Any help would be appreciated!
Solved! Go to Solution.
02-21-2018 02:20 PM
Just remove the columns you do not want to update, never seen # being used for this purpose.
All you need is the mandatory field (UserID) and then any other column you want to update i.e. CONTROLLED DEVICE.
Also, you can use the "Update Users" sheet on the BAT.xls file you can download from your CUCM.
02-21-2018 12:58 PM
Can you please attach an example of the BAT file you are attempting to run?
02-21-2018 02:08 PM
FIRST NAME |
MIDDLE NAME |
LAST NAME |
USER ID |
PASSWORD |
MANAGER USER ID |
DEPARTMENT |
PIN |
DEFAULT PROFILE |
USER LOCALE |
TELEPHONE NUMBER |
PRIMARY EXTENSION |
ASSOCIATED PC |
IPCC EXTENSION |
MAIL ID |
PRESENCE GROUP |
SUBSCRIBE CALLING SEARCH SPACE |
ALLOW CONTROL OF DEVICE FROM CTI |
DIGEST CREDENTIALS |
USER GROUP |
CONTROLLED PROFILE |
CONTROLLED DEVICE |
PASSWORD LOCKED BY ADMIN |
PASSWORD CANT CHANGE |
PASSWORD MUST CHANGE AT NEXT LOGIN |
PASSWORD DOES NOT EXPIRE |
PASSWORD AUTHENTICATION RULE |
PIN LOCKED BY ADMIN |
PIN CANT CHANGE |
PIN MUST CHANGE AT NEXT LOGIN |
PIN DOES NOT EXPIRE |
PIN AUTHENTICATION RULE |
ENABLE MOBILITY |
ENABLE MOBILE VOICE ACCESS |
REMOTE DESTINATION LIMIT |
MAXIMUM WAIT TIME FOR DESK PICKUP |
PASSWORD IMSINFO |
PIN IMSINFO |
USER PKID |
JoeUser |
SEPMAC |
This is the format I got from here: https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/bulk-administration-tool/110967-bat-00.html
It’s in a .csv file and it’s formatted the same as all of the other BAT jobs I do. The # is the variable I used for ignored fields and this is the error I received after it failed: Failure Details :
users Error Code Error Description
Warning :
LDAP Sync status is enabled. Some fields cannot be updated.
JoeUser It is not possible to convert between the specified types.
Result Summary :
UPDATE for 0 USERS passed.
UPDATE for 1 USERS failed.
02-21-2018 02:20 PM
02-21-2018 02:28 PM
Thanks for the help! I was wondering why so much information was required when all of the other files only required the desired fields *face palm*.
12-27-2020 10:53 AM
Besides the solution provided, which worked also for me, I realized when I exported the -end users- from Export menu, the field Controlled Device was named in the file as DEVICE NAME 1, DEVICE NAME 2, ..... But for updating an end user using Custom File, the field should be named CONTROLLED DEVICE 1, CONTROLLED DEVICE 2, .....
So keep that in mind, the column in the .csv file should be named CONTROLLED DEVICE 1 in order to associate a phone to an end user.
