IP Telephony and Phones
Labels
I know that AAR can be configured and used when bandwidth between 2 sites is not sufficient.  What I'm needing to do is cone up with a configuration that will route calls via the PSTN when the LAN connection between sites is down (automatically).   H...
SNMP Response failing alarm were trigger  >>No SNMP data is being reported from A-subpub01.abc.com Check that the snmp community has not been changed, either on the device or moniting tool If the SNMP credentials are correct, check that a firewall i...
S Sadiq by Beginner
  • 461 Views
  • 6 replies
Hi, all,I am new to Cisco VoIP, I am trying to set up a SRST router in remote office. The router is a 2801, it has 4 FXO ports on it. I configured MGCP and pointed MGCP call-agent to HQ CCM. "sh ccm-manager" on router shows that it is registered with...
oldcreek12 by Beginner
  • 13209 Views
  • 20 replies
  • 5 Helpful votes
