IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5654 Views
  • 14 replies
Hello, CUCM 10.5.2 SU1  I have a situation with some single number reach users infrequently, where out of the blue they no longer can call inbound to our system from their cell phone if it is same number as their single number reach, remote destinati...
Hi,We have a lot of 7914 add on module connected on 7960/7961 model of ip phones.On ccm 4.X server,how can I know the count of number of 7914 add on modules in the cluster?I tried through Device >> Phones >> find phones where Device Type...But does'n...
k.ms by Level 1
  • 1627 Views
  • 8 replies
Hello, I have a Cisco 2921 with CUBE enabled on it with 10 sessions, i'd like to upgrade the number of sessions by adding L-FL-CUBEE-25=, but when i looked on the internet i didn't find any way to upgrade the number of sessions using the purchased l...
Hi all I need to do this in order for our carrier to not drop the call......... INVITE sip:07714602016@10.220.90.28:5060 SIP/2.0 P-Asserted-Identity: "Anonymous" <sip:Anonymous@10.226.6.254>   <-------convert this to: INVITE sip:07714602016@10.220...
b.t by Level 1
  • 332 Views
  • 1 replies
Unable to make call from 8941 ip phone to some external numbers..Iam able make calls to all external calls from 6921 which belongs to same css of 8941.Its not the css or firmware issue.Already upgraded to latest firmware and checked the configuraton ...
In an effort to add more DSP resources to our CUBE, we added the offer-all option on the voice-class command in the dial-peer interface. I need clarification on why the following configuration results in the codecs being used for G711 to G711 calls.v...
Hi Guys i need your immediate help. I am trying to troubleshoot an e1 pri issue where calls are not being sent out the E1. Instead it is being sent to the analog trunks which are second in line. Is there any commands that can show me when a call is ...
rramlal by Level 1
  • 479 Views
  • 9 replies
