IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5886 Views
  • 14 replies
Hi, I have something weird, I configured a System Call Handler in Unity Connection and assign it an extension. In CUCM I create a CTI route point with the same extension and do a forward all to voice mail. When I dial the extension from the CTI route...
I am running cme 11.5 with 7841 SIP phones.  A wireshark capture shows RTP streams going through the CME router and not directly between phones.  Is this normal?  Should I see RTP chatter between two SIP phones ? AT
AT by Level 1
  • 1318 Views
  • 3 replies
Hi, I have CME version 10.5, and combination of SIP & SCCP phones. This is about remote presence using BLF speed dial. - SIP phone (8851) on site A can view SCCP ephone dn on the same site -> OK - The same SIP phone on site A can't view SCCP ephone ...
Resolved! 911 and Mobility
Hello, in Communications Manager 9.x and above is there a way to compensate for 911 calls when a user is at a location other than where their DID resides WITHOUT having Cisco Emergency Responder deployed? Example.   Jabber user resides in Office ...
I use the SPA 122 which has the following specs: Version 1.4.1 (002) Model: SPA122, LAN, 2 FXS Product ID: SPA122 Hardware Version: 1.0.0 Firmware Version: 1.4.1 (002) Oct 26 2015 Problem: 1- The software gets corrupted again every few days! ...
Khaled Fa by Level 1
  • 495 Views
  • 4 replies
