IP Telephony and Phones
Labels
I know that AAR can be configured and used when bandwidth between 2 sites is not sufficient.  What I'm needing to do is cone up with a configuration that will route calls via the PSTN when the LAN connection between sites is down (automatically).   H...
SNMP Response failing alarm were trigger  >>No SNMP data is being reported from A-subpub01.abc.com Check that the snmp community has not been changed, either on the device or moniting tool If the SNMP credentials are correct, check that a firewall i...
S Sadiq by Level 1
  • 751 Views
  • 6 replies
