IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5808 Views
  • 14 replies
Hi folks, May be this is stupid question. Customer has VERINT as call recording solution. VERINT is configured with JTAPI user pointing to Publisher. In case, if Publisher goes down then CTI communication breaks and call recording stops. Is there a...
We have a two story building with 7821's upstairs and downstairs. When calls are made between floors, it sounds like you are talking under water. When calls are made to phones on the same floor the sound is good. Could it be the multicast? No errors ...
Hi,for some years i had the num2name script via ISDN up and working. No we change to SIP and i have the problem that it shows the name correct on the cisco phone but as soon as i pickup the phone the call is disconnected.See here the debug from VGW:R...
thorstenn by Level 4
  • 1007 Views
  • 8 replies
HI All  Cisco 7961 phone is giving wrong time ..  the setup is just upgraded fro CUCM 8.6 to 11.5 . after the upgrade only the issue started . we have around 10 phone of 7961 on site only 1 phone is having the issue . all the phones are running wit...
