Looking for information related to Automation UCCE agents and CM Phone additions
I did this and it didn't change anything, is this really supposed to work? Set the Incoming Calling Party National Number Prefix setting in Call Manager service parameters, advanced - to 91 Or do I have to add translation patterns like I have seen...
Hello, Self Care Portal Version 10.5.1. CUCM version 10.5.1.10000-7. When users log into the Self Care Portal and add Speed Dial Numbers they do not populate on the phone. Using 8945 phones btw. On the 8945's when the user presses the directories ...
User has accidently removed the cable while the Cisco IP Phone 7945 is in "Upgrading" state and after that its not coming up. after connecting it to other port the lights are Blinking but Phone display is Blank and not coming up.. below are the tf...
Im using the Spark client free version, can I place PSTN calls? Looks like I can only call other Spark clients / SIP URIs, also no Voicemail How can I call FreeSpark from other external systems? I have an EX90 but dunno what is my Free Spark SIP URI?...
I recently purchased a 7962G VOIP phone for my home office, which according to my IS department, will replicate exactly the 7962G setup I have on my desk at work. I was told by IS that the phone at home would be a clone of the one at work - when the ...
Hey guys, we have an branch office with a 50.000kbps connection to the main office.I know it is more than enough for 3 calls or a bit more but we would like to check whether it is possible to limit the video bandwidth.In the callstatics I can see th...
Hi Guys, I have registered 7940 CP with SCCP Protocol which is connected to Brocade Switch. But phone not getting IP. I have manually configured also, cucm version is 10.5 switch brand : brocade poe switch is brocade switch SCCP Protocol defaultly?
If we have a campus site with one physical address and 6 buildings - bld1, bld2, bld3, bld4, bld5, bld6 - do we have to create 6 different ERLs with their associated ALI records? 5592223331 - ALI-1 - 1234 Main St - bld1 5592223332 - ALI-2 - 1234 Mai...
Hi All I am looking at a small office solution for 20 users approx, for most sites we use CME, however the management can be a pain due to the gui etc. Would it be better to go for a BE6000S? would I get the same functionality out the box ? why would...
Hi . We have users synced with AD . I was checking out CUCM and see we have 395 local enabled users and 390 Active LDAP Synchronized User. I see many duplication = Active LDAP Synchronized User also exist as local enabled users but with different US...
Hi We have a remote site and phones are registered to centralised cucm. CUCM---->SIPTrunk-->CUBE(Remote Site)--->ITSP.Can we configure the SIP SRST fall back for this scenario..? to make sure the phone are registered to local cube router and make ca...
Hi, I'm attempting a trial upgrade of CUCM from version 9.1 to 11.5 just to see if i encounter any problems in advance of the actual upgrade. We have built a new CUCM Publisher based on a DRS Restore of the original, this server sits on VMWare (HP C...
According to http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118893-technote-cucm-00.html Jabber clients do not support Security By Default. So if the CTL file changes (e.g Publisher certifi...
Hello, I have a CUCM cluster with two CUCMs located in the HQ (only one site). Sometimes when I make calls from specific IP phones I hear a robotic voice (internal calls only). I have changed my port configuration observing the same result. When I se...
Subject | Author | Posted |
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM | ||
04-14-2025 01:50 PM | ||
04-14-2025 08:21 AM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
