Resolved! Call redirect
Hi , I have one issue I wanted to direct the 858 xxx xxxx (receptionist when customer chooses 0 for operator) to the hunt group 888 xxx xxxx? how can I do that ?
I have scoured the documentation for the different types of cards and as many datasheets as I could possibly find. I cannot locate a specific place that dictates exactly how many individual serial circuits are able to be used on a 4431 router. Techni...
Hello All,I was wondering if Jabber for Windows (in softphone mode) can fallback in srst. In my environment when Jabber goes in srst it looses connectivity towards the HQ where CUPS and CUCM servers are located.I read some docs and - hope I did under...
Can they load custom wallpapers and ringtones themselves? Or is this something that has to still be done with TFTP? Just was wondering if these phones were more user friendly to the end users to set up the way they wanted too.Thank you!!Telecom Techn...
Hi, firmware upgrade fails from SCCP69xx.9-1-1-0 to SCCP69xx.9-4-1-3SR2. I am using call manager 10.5. is there intermediate firmware upgrade required? can you give upgrade path please. it is 6921 model phones direct upgrade not possible.
Hi, We have a CME running 11.5 and are using 7841 SIP phones. If we enter the digits and then hit the call button the call goes through. If we lift the handset we have dialtone but when we dial the number we get dead air for a few seconds and then f...
All, is there a way I can export the external mask for all phones? I don;t mind if there has to be other information ihcluded. It would be nice to see teh entire mask and not just 305222XXXX. Thanks in advance Replies rated
Hello everyone, we are currently trying to set up a couple of 8861 phones over wifi with EAP-TLS authentication. It works perfectly fine when we install a User-Installed certificate and the Trust Certificate for the Radius manually through the phone ...
Hello, I have a installed a CUCM in v11 and was trying to create a DRS (backup) only account. I have created a new account with "set account name " with Privilege level of Ordinary, the lowest, but that account have to much access. Questions: 1 - Ca...
Hi GuysI´ve a CME with SIP Trunk to ITSP and registered as well. My issue is that, incoming calls are not working, per debug I´m receiving: Nov 1 11:59:34.670: //46650/7D711B609860/SIP/Msg/ccsipDisplayMsg:Sent:SIP/2.0 484 Address IncompleteVia: SI...
I work in an open office space and was wondering if instead of an audible ring, one could get a visual alert on their computer screen that the phone is ringing and also have a caller ID included in that alert.
Hi, does anyone have a SKU for the USB OTG Cable for the cp-8821-k9= ? Thanks Boris
Hi All, Issue happen after CUCM upgrade from version 8.6 to 11.0.1.21900-11 and find it in recent days.Cluster has 4 nodes (1 Pub and 3 subs): From the CUCM CLI Publishers and GUI Subscribers (OS Admin page--show status ) the time is correct but the...
Hello,I followed the procedure "How to Configure Unified Communication Manager Directory Integration in a Multi-Forest Environment" many times but I have always the same problem : no users in ADSI Edit MMC, no users in CUCM. Domains Trusts Relations...
Hi All, Good Day. We would like to ask if what would be the resolution for the detected vulnerability for the Cisco IP Phone below? Are there any patch upgrade or IP Phone firmware installation/upgrade we need to do/apply to resolve it? Thank ...
Subject | Author | Posted |
01-16-2025 02:00 AM | ||
01-08-2025 01:34 AM | ||
01-05-2025 12:44 AM | ||
01-03-2025 09:47 AM | ||
12-30-2024 03:11 PM |
User | Count |
5 | |
3 | |
2 | |
1 | |
1 |
