IP Telephony and Phones
Labels
Hi Expert, I had deploy Cisco CCM 11.0.1.20000 firstly, and there are call pickup group are workable. After we upgraded the CCM to 11.0.1.22900-14, the call pickup function failed as following condition: 1. When mobile phone call to IP Phone A, anot...
osw200051 by Level 1
  • 378 Views
  • 4 replies
I would like to migrate from CME to BE6000S.  My biggest concern is my SIP trunk to Windsream via MPLS network.  Will I be able to duplicate this connection on the 2921 router?  Will I need a CUBE license?  Some other license? Thanks,Diego
tato386 by Level 6
  • 668 Views
  • 7 replies
Hi There, I am receiving the following error message from RTMT. UsedDiskSpace : 93 MessageString : Common Disk utilization hits LWM! AppID : Cisco Log Partition Monitoring Tool ClusterID : NodeID : SCCM50005P  TimeStamp : Wed Nov 23 11:34:35 EST 201...
mightyking by Level 6
  • 7592 Views
  • 11 replies
Hello, I use CUCM v.10.5 and CUBE. CUCM and CUBE is connected by H323 gateway. On CUBE i have SIP trunk to PSTN provider. Now i use phones: 6921 (SCCP) and 8831 (SIP). I have problem with dtmf on SIP phones. If i have call from outside with dtmf opti...
ukaszquz by Level 1
  • 591 Views
  • 1 replies
Hi Community, We have Cisco CME router 2921 and we have issue on the fxo port which got stuck because of incoming and outgoing calls. To make it work again I need to do a shut and no shut command on the voice port. Or disconnect and reconnect again ...
Hi, I currently have an old CUCM system that is unable to dial any mobile number that starts 073.   I'm assuming that this is down to an old dial plan being installed.  As this box no longer has any support on it (due for retirement soon) is there ...
Hi Everyone;I'm trying to solve to following problem (Please see the picture in attachment) :1) I have two sites, two CME Routers and I have the same dialing plan.2) I want to save the same dialing and I want to permit the communication between the t...
kadd.aziz by Level 1
  • 1793 Views
  • 7 replies
