IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5819 Views
  • 14 replies
Hi , we're looking to upgrade our estate from 10.5 to 11.5. When I look into PLM I notice that all the licences have a (10.x) next to them. My question is does a CUWL (10.x) licence for example work with a 11.5 CUCM.I'm guessing not maybe  but as a ...
m.batts by Level 4
  • 260 Views
  • 3 replies
description * * * Not In Use * * *!voice-port 0/1/0 connection plar 222033436!voice-port 0/1/1 connection plar 222033437!voice-port 0/1/2 connection plar 222033438!voice-port 0/1/3 description * * * Not In Use * * *!voice-port 0/2/0 description * * *...
hi All, We have an production voice gateway with E1 which talks h323 to our CUCM. We have just inserted a 4port FXO Card and we would like to route only all our mobile phone calls to it.   I am getting conflicting info by searching the forum and also...
Greetings.  I have an MOH problem.  When setting up a custom WAV file for participants waiting for the host in a Conference Now session, only the first person calling in hears the music.  Subsequent participants only hear dead air until the Host join...
Fax
We are facing Outbound fax issue while dialing specific number RightFax >> SIP >> Gateway >> PRI On Incoming dialpeer from sip dial-peer voice 2 voipsession protocol sipv2incoming called-number .codec g711ulawfax-relay ecm disablefax-relay sg3-to-g...
Hi guys, I'm with a problem, I can't call to specific number: +55 11 49505070 (From Brazil), but just of a specific locale (My enterprise). However, any other locale I can call to number. I made several test with the telephone service provider, but ...
cisco by Level 1
  • 1693 Views
  • 1 replies
