IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1179 Views
  • 6 replies
Resolved! CUC call routing
Dear All, I have a quick question. When the board number 29001 is called (internally or externally) a welcome prompt is being played and then it is prompting to enter desired extension or press 0 for operator. I can see the call handler configured fo...
Syed by Participant
  • 213 Views
  • 3 replies
Dear All, We planned to upgrade from CWMS 2.5 to 2.6 .  This is consider as Minor upgrade or Major upgrade ? If it's Major upgrade what about license ? Same license can be used for 2.6 also ? Any upgrade kit need to order to get the new license for ...
gpsriramdc by Enthusiast
  • 107 Views
  • 1 replies
Hi, We have a VG350 voice gateway connected to the CUCM. One of the FXO ports has got a direct PSTN line, and another has a PBX trunk connection. The PBX connection allows you access to the national PSTN if you use the route pattern 910[1-8]XXXXXXXX...
For an inter cluster non gatekeeper controlled trunk to work between two separate call managers, do the call managers have to be on the same version software release?  We have one cluster on 8.5.1 and the other cluster on version 10. I looked around ...
Has anyone ever run into this issue before? I have a cisco model 8845 video phone that on a secondary line appearance which is set for flash only it continues to ring? We are using 9.1 software on our call manager. Any suggestions as to what to try? ...
