Please , I have installed cucm 10 , and i insert ip phone into by using BAT, my worry is about how can i change the language of ip phone??thank you.
Hey Everyone,I'm having difficulty with a particular request from one of our clients. They want to have an extension on their phone that will block the Calling Name and Calling Number when making Local/Long Distance calls. So I created a new Partitio...
Hello, Although it is not stated or clear in the data sheet, our customer is looking forward to have the following two features on DX80: 1- Show personal directory of Outlook along with Corporate Directory (The user is able to browse the personal d...
Hello all, All of a sudden when the router creates it's automatic dial-peer for a hunt pilot, it is adding the "$" at the end. Because of this, the default "dial-peer hunt 0" does not work the way I want it as it is explicitly matching my hunt pilo...
Hello, We are getting unknown protocol drops cisco voice router 2921. We are facing sometimes NO AUDIO issue with cisco IP Phones. When they are dialing exten to exten. How to resolve pls advise ASPL. IOS ver is c2900-universalk9-mz.SPA.152-4.M...
Hello All, I have a CUCM 9.1 and 2 sites in it. For inter site call we prefix a code (telnet number) to target extn. I have a situation when user A from site 1 calls user B site 2 with PSTN number, call is clearing. But when he dials telnet number, ...
Hi, when i try and use RTMT to check server i get the following warning attached about iowait time. The VMs i have loaded for pub and sub are not under load at all. Not sure why getting this message. I clock OK and it just sites there and the next ...
Hi folks, Am configuring Extension Mobility in lab, its configured as per Cisco documentation. Suppose, if I get request to configure EM for 20 users, do I need to create 20 end users and subscribe EM service on those 20 IP phones? I've enabled mult...
Hi, I setup Attendant console Advanced server , but client doesn't connect to database ,only works basic call function. I tested with win10 & 8. What could be the issue? Thanks Suchira
Since the CUCM cluster upgrade from 10.5(1) to 10.5(2) this past Monday night, the 7965 operator phone has been having issues with the two 7916 sidecars randomly rebooting. The latest firmware is installed on the phone and sidecars. Our customer tri...
Hi , I need to change MOH for all users/phones regularly. Currently no MOH is selected in phone & line configuration. What is the most suitable method to update MOH in all users/lines regularly? Thanks Suchira
One of our customer is replacing 2800 routers with 4331 routers. Existing 2800 has 2 PRI's in one of the routers when we tried to configure those in new 4331 router we had some issues with clocking commands. I did read this doc http://www.cisco.com/c...
I'm trying to see if anyone has any ideas for what we are looking to do. In a hospital we have a registration area were patients register for services. What we would like to do with our CUCM system is to have buttons on the phones (7965) in the regis...
Hi, I have a lab setup with two cluster, over TLS SIP trunk. I have installed respective trust-certificates in each CM, and RG, RL, RP to route calls. When a call is made over the trunk, I see some signaling traffic over port 5061, however it gives a...
Are they field replaceable? What are the specifications (manufacturer, p/n) and source for replacement?
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
| 件名 | 投稿者 | 投稿済み |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| ユーザー | カウント |
| 5 | |
| 2 | |
| 2 | |
| 2 | |
| 1 |
