IP Telephony and Phones
Personalize banner_3
Labels
Dear all, We have a requirement to deploy 8841 3pcc ip phones and we have grandstream ucm6302a. What are the requirements in this scenario. Online posts points towards templates and provisioning the phones to grandstream. Kindly help and if templates...
user1981 by Frequent Visitor
  • 341 Views
  • 0 replies
Hello,I have a cisco 7421 (non-3pcc version) and I am trying to connect it to my 3cx instance. I have the tftp server setup with the config file and I can see the request being made on tcpdump, but the phone report TFTP timeout on the file.I also see...
onus22 by Community Member
  • 1545 Views
  • 7 replies
Hello everyone,I am currently working on a phone that functions completely fine when calling other phones on the same network. Not only the phone is able to make calls to any phone on the same LAN, it is also able to make calls to different WANs. How...
Hi thereI have a problem with anumber of the 7921 phones we have no longer charging in their docks.If you put a fully charged battery in the phone then it will work fine, placing the phone in a dock to charge brings up a picture of a plug with a red ...
pjonessas1 by Community Member
  • 5181 Views
  • 11 replies
How do I setup IP Phones physical connection via switch and router, to assign IP Phones to CUCM? I currently have a CME configuration with two IP Phone assigned and working; I can make calls successfully.But now I want to delete the IP Phones off the...
adsuther1 by Level 1
  • 3175 Views
  • 3 replies
Hello, I have an Auto Attendant I created and under the Greeting Standard I have the checkbox to "allow transfers to Numbers not associated with Users or Call Handler" checked, I modified the restriction tables to allow transfers to the extension num...
jeanalain_t by Frequent Visitor
  • 1622 Views
  • 3 replies
Hello,I have topology for my cucm is : PSTN -> Cisco ISR SRST - UCCX - CUCMWhen i try to make an call from my mobile to my PSTN, the call is answered by IVR then i press one (the call should go to receptionist), when call transferred from IVR to rece...
hs08 by VIP
  • 322 Views
  • 0 replies
