All, rebuilding an 8.6 Publisher. Subscriber is up. Security password has been lost. When I try to reset the security password on the Subscriber it tells me to enter the old password. If I knew the old password..........Anyway. can someone tel...
Hi I have a CUCM 8.6 with the device package "cmterm-devicepack8.6.2.26169-1.cop.sgn" installed for phones 78XX and the phones work fine, the phone register and update the locale to es_CO. But I can't see the phone information under application menu...
Hi all, I have CUCM 8.6 with h323 gateways for branches. It branch (cisco router) has E1 and FXO lines to make external call (dial-peer voice pots) and dial-peer voice voip to route calls to main office or between branches . So far , so goog. Now we ...
can i change the ringback tone that a customer her when calling ip phone registered with cucm from pstn to a music file?
Hello,I configured a CME 2811 to establish conferences. When I want to add a phone on the conference I have : "cannot complete conference".Here the harware inventory : NAME: "2811 chassis", DESCR: "2811 chassis"PID: CISCO2811 , VID: V02 , SN...
Hi, Another day at work, since Cairo Branch has changed their clock, all Cisco IP Phones gone mad and displaying wrong time. I can confirm few things, I have checked in CME listed below: Correct timezone configured on CME for Cairo "EET 2"Correct tim...
How to configure FQDN on CUCM PUB and SUB ? I have gone through docs and it says that just change server name from System menu of CUCM server ? I have seen issue like remote connection after doing that. So just wanted to know that is there any other ...
I am trying to integrate our CUCM cluster with the other site AVAYA system for which created SIP trunk but it shows Status - down & status Reason local=2 how can i come out of this.. We are using CUCM version 10.5 Aslo I found that from our CUCM ...
Dear All, Can I save extension numbers on IP phones for easy dialing?
Hi Expert I want to import CUCM end user data on DX70 and SX device contact list. Is there a any way for this implementation ? EX: There are 100 users provided on CUCM , i want to import those users data CUCM to SX80 and DX70 contact list without...
Hi guys, I'm deploying CUCM 10.5.2 with multisites.Each site has a Cisco 2901 in a latest release 15.4(3)M2 connected in SIP Trunk to the CUCM.Alls works fine (SIP SRST , SIP Trunks, PSTN ,etc...) but the only problem I have is the multicast MOH on t...
Hey folks, Am doing a FAC test. I have 1 Partition with 1 CSS with 2 difft. 10 digit extensions (55522220001 and 5553333001). Route Pattern: 9.555XXXXXXX pointing to Voice gateway. On Voice Router I have configured 2 dial-peers for incoming and outg...
Hello guys, I have 7821 and 9951 phones. CUCM are generates different varVQMetrics for different Ip Phone models. For example in this output you can see 7821 phone varvqmetrics. In this screenshot you can see 9951 varvqmetrics. I used same gatew...
Hello! Please help with the 7841 ip phones. Everything goes well before one of the phones has unable to register with the error "error verifying config" and then it happens more and more often. Sometimes full resetting helps and they register but i s...
Hi guys, i'm having some troubles with a router cisco 2800 series with a CUCM routing outgoing calls, all I receive is a fast busy tone from my CIPC when trying to reach a local or international number, any feedback would be appreciated, show run B...
| Subject | Author | Posted |
| 03-25-2025 06:06 AM | ||
| 03-21-2025 01:42 PM | ||
| 03-20-2025 05:12 AM | ||
| 03-19-2025 06:53 AM | ||
| 03-18-2025 05:41 AM |
| User | Count |
| 5 | |
| 2 | |
| 2 | |
| 1 | |
| 1 |
