I have a new 7975 Cisco IP Phone that is disconnected continuously. I followed the next steps: - Change Network port - Change Module Phone - Change Phone
All, Rebuilding a Subscriber in a 8.6(2) cluster. The publisher Host name has an underscore in it. For the Subscriber rebuild, I am on the First Node Access Configuration screen and it is telling me only Alpha Numeric characters and hyphens are ...
Hi there, I have CUCM-BE running on a BE6000M. The CUBE is also running on this device and the device is in the DMZ. So set-up is: CUBE <---DMZ--->F5 firewall <----> ITSP Note: CUBE is on a private IP address and only one interface is been used Th...
Hello All I met a strange issue. Please tell me if you have any advice. Thank you in advance ! Call manger version is 10.5.2 . Phone is 7941. The phone speaker button light automatically when I pick up the handle to answer a incoming cal...
Hi Guys i have a task to link CUCME and Avaya server by SIP trunk i have a CUCME and some cisco ip phones om my site and want to link it with Avaya server located at another branch so i don`t have problem with configure cisco IP Phones with sip prot...
What is the best practice to get old modems to work on a VG350? The scenario is: VG350 (SCCP) > CUCM > MGCP (voice gateway) > PRI. The Fax passthrough vs modem passthrough is somewhat confusing in the documentation. We are migrating a site from a Nor...
Hi, Please give me solution, I use Cisco Phones and i want to lock with code pin some phone Thank you
Hello all, Am deploying Cisco expressway in my lab, want to know the port details of edge servers to be opened in firewall for internet login can any one help ?
Hi, Can i please be directed of how to get reports from CUCM 10.5. i am asked to provide the report of an external number, who called this number xxxxxx and from which extension ? please advise, Thank You, Erin
Hi All, I'm having trouble registering my ATA 187 in 10.5. I've attached my config, ccsip debug, and a screenshot of the ata webpage. the ATA looks to have the DN's, but won't register. Any ideas? voice service voip ip address trusted list ipv4 10...
We are going to add 2 cucm subscribers in an existing cucm cluster ( v 10.5.1 )Is there something that i need to take care of besides of doing this action after hours? Because i've understood that if you add a subscriber to an cluster all the acti...
Peeps Peeps, got the following issue when calling out a trunk across to NZ. I dial +6412345678 which is directed to another CUCM cluster in NZ, from Australia. However, as soon as it starts ringing the phone's display shows: 1012345678 which is ...
Hello, We have recently ran into an ambiguity with Cisco about supported hardware platforms for Unity Connection. Plan was to migrate CUC 8.6 on MCS to 10.5 on UCS E140S. While, there are conflicting options from Cisco whether E140S supports CUC 10....
Hi All, Please help me on how to change the router from CME to SRST mode, because CME only shown on the mode options "no SRST". Thanks and regards, Ralph
Dears, I am translating extension 111 after office hrs and weekends by TOD to a GSM number it is working fine for both internal and external users but the problem is I don't want a internal user's calls to be translated to the GSM number I want only ...
| Subject | Author | Posted |
| 03-09-2026 11:06 AM | ||
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM |
