IP Telephony and Phones
Labels
Resolved! CME doubt
hello all, am new to cme, i need to configure cme without seperate dhcp server. iis it good to configure with static ip heard cme can be configured in 2 way sccp and sip in which  case i should go for sip and sccp? is there any reference doc for my ...
Hi  I have a CUCM 10.5.2.10000-5 and a OpenLDAP in my OpenLDAP I have the user created and working, when I synchronize the CUCM with the OpenLDAP directory only synchronize a few user, and only one user with all parameters, if I review and compre the...
hi i config a pri GW ,the GW connect to CUCM use H323 when i call a pstn phone ,is all right but when i call the internal call from PSTN,i will receive next  signaling   Mar 17 11:17:10.848: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0F3A ...
bo liu by Level 4
  • 379 Views
  • 2 replies
I have an issue logging in cross cluster with 8961 phones. It works fine with 7945. With the 8961 phones the logout and corporate directory are missing.
hjs by Level 1
  • 226 Views
  • 1 replies
HI Guys, I have a problem in random call drops internal to external & vice versa CUCM ----H323---SIP-----ITSP follwing log appears in CUBE SIP: Internal Error (INVITE, invalid IE content): IEC=1.1.100.7.35.2 on callID -1 Please advice
Suchi by Level 1
  • 1119 Views
  • 1 replies
