Hi All, I have configured h323 gateway from hq to pstn . when I try to call the following numbers from hq IP phone to Pstn phone am getting reorder tone . 912012517295 , 914087071222 . The output trace as follows Bearer Capability i = 0x8090A2 ...
Hello. We have CUCM v9.1.2 and phones 9951, 9971. When we tried to organize conference on 9971 (this phone with CKEM module), conference softkey not appeared. Algoritm of our actions: 1. We call from 9971 to second phone 2. Than push to conference bu...
Hello Friends Please help me understand the usage or function of MRGL on the below setup. PSTN ---- Gateway ---SIP trunk --- CUCM ---- Phones We have unicast enabled. We have a SIP trunk from CUCM to Gateway. The phones have assigned a MRGL. Simi...
Team, 1) I am trying to understand why 8831 is loading with current image when it is not there in device defaults. Attached screenshot where you can see requested load id is 9-3-3-5( Also present in device default) but phone actually takes 10.3.1 IS...
Hi All, I am using a remote LAB set up from one of cisco training providers. I have two phones at HQ site one is 9971 and other is 7962 phone. I have R1 router on Hq site which i am using to make outbound calls to PSTN phone .I have set up this as ...
Hi Experts, Some of the phones for outgoing calls are getting failed. History of the problem is that we have seperate PT and CSS for E1 and SIP trunks, e.g Before SIP_CSS contains SIP-PTs and E1-PTs, where E1_CSS has only E1-PTs. Offcourse the sepera...
Hi Team, I am using voice gateway model 2800 & 3800 and have plans to upgrade the existing CUCM to version 10.5. Will I still be able to use these gateways with the new CUCM version? Thank you in advance. -Karan
Hi All,I have problem when I upgrade the CUCM from 8.5.1.10000-26 to 8.6.2.20000-2.In the 8.5.1 version, I installed "ciscocm.refresh_upgrade_v1.1.cop.sgn" and I can see the COP installed when show the "show version active".After upgrade the 8.6.2, t...
Hi All, Issue When users dials from cisco IP phone to third party contact center IVR menu,The DTMF tones are not getting recognise. But when i dial from mobile phone it is working. Call Flow CUCM --> H323 gateway --> PSTN The inbound Dial Peer on ...
am stuck in problem, need little assistance regarding with CUCM, I have different model of IP phone, 6921,6941,8941,8945,9971 before i was using CUCM version 9 and now upgraded it to 11.0 everything is working perfectly, when i try to connect new box...
Enterprise is installed. Any major pros or cons either way? About 10 operators in total Thanks in advance Replies rated.
Somehow I accidentally turned DND on my phone. I have been all over the buttons, menus and options but cannot find anything for this function.
Hi Support, There is wrong time showing (1 hour difference) in all 7942 phones while other phones 7940 shows the correct time. CME clock shows the correct time, Correct Zone is set as well. The problem has occured after the Day light Summer time cloc...
Hi all, I have CUCM 10.5 with Cisco 7821 and 7945 endpoints. Internal calls are fine. However, I get voice quality issue with outbound calls from Cisco 7821 endpoint. The lost packet rate is always about 2 % with just Cisco 7821 series. Meanwhile, I ...
Hi All, There is wrong time showing (1 hour difference) in all 7942 phones while other phones 7940 shows the correct time. CME clock shows the correct time, Correct Zone is set as well. The problem has occured after the Day light Summer time started....
Subject | Author | Posted |
03-20-2025 05:12 AM | ||
03-20-2025 03:51 AM | ||
03-19-2025 06:53 AM | ||
03-18-2025 05:41 AM | ||
03-16-2025 03:42 AM |
User | Count |
6 | |
2 | |
2 | |
2 | |
1 |
