IP Telephony and Phones
Labels
Hi All,I have problem when I upgrade the CUCM from 8.5.1.10000-26 to 8.6.2.20000-2.In the 8.5.1 version, I installed "ciscocm.refresh_upgrade_v1.1.cop.sgn" and I can see the COP installed when show the "show version active".After upgrade the 8.6.2, t...
by Not applicable
  • 1714 Views
  • 4 replies
Hi All, Issue When users dials from cisco IP phone to third party contact center IVR menu,The DTMF tones are not getting recognise. But when i dial from mobile phone it is working. Call Flow CUCM --> H323 gateway --> PSTN The inbound Dial Peer on ...
Devansh by Level 1
  • 523 Views
  • 5 replies
am stuck in problem, need little assistance regarding with CUCM, I have different model of IP phone, 6921,6941,8941,8945,9971 before i was using CUCM version 9 and now upgraded it to 11.0 everything is working perfectly, when i try to connect new box...
Hi Support, There is wrong time showing (1 hour difference) in all 7942 phones while other phones 7940 shows the correct time. CME clock shows the correct time, Correct Zone is set as well. The problem has occured after the Day light Summer time cloc...
cisco by Level 1
  • 2113 Views
  • 2 replies
Hi All, There is wrong time showing (1 hour difference) in all 7942 phones while other phones 7940 shows the correct time. CME clock shows the correct time, Correct Zone is set as well. The problem has occured after the Day light Summer time started....
cisco by Level 1
  • 354 Views
  • 0 replies
I have two fax machines that are connected to a VG224 and both those are having intermittent issues. Incoming fax fails on the remote end and an error is generated but at the remote end but for outgoing fax, no errors are generated. The only way to c...
Hello..... I have Cisco CallManager 7.1.5.33900-10  and server IBM HW Platform : 7825I4. Every time we restart the server, this shows the error: Ata4: port is slow to respond, please be patient (Status 0x80) while the system is in Bios. ata4 is the ...
All for Jabber on a CUCM cluster running 8.6 and Jabber on a different cluster running 10.5 will I need to Federate in order for teh Jabber clients to talk to each other or will an Intercluster trunk suffice? Thanks in advance! replies rated
