IP Telephony and Phones
Labels
All Cisco Unity Users are Unable to receive Voicemail Messages frm cisco ip phones but its deliver to directly to MS-Outlook client.
Dear Support team,Cisco Unity 7.0 Build 7.0(2)  : When a Cisco Unity subscriber(user) check Voicemail messages :All the Cisco Unity users Unable to Deliver Voicemail Messages from cisco ip phones but its deliver to directly to MS-Outlook client.Voice...
CUCM Alternate Extension used to allow duplicated extensions
I am using the Alternate extension option to allow users in different partitions to have the same extension and this works fine.for example:Site 1                     Extension: 1234                     Partition:Site1                     ALT Extensi...
Resolved! Unable to retrieve spec for http://<CUCM IP Address Here>/inbox/gadgets/msg/msg-gadget.xml. HTTP error 504
I am getting this error when I attempt to use the unity connection web inbox. Does anyone know a solution for this or perhaps an article on a fix? I have look around but I can't seem to find anything so any help would be appricated.
Resolved! Hold & Transfer Problem on External Translated Calls (DID Mode)
HiWe have E1(voice) link connected to 2900 router,telephony service provider gave us 4 fixed  number with 4 variable extensions for example: 1234XXXXmy ip phones registred to Cisco Unified Call Manager 10.5.when I use PLAR for E1 voice-port to recept...
Resolved! SCCP phones have correct time format but SIP Phone have a wrong time zone and incorrect date format
Hello,I currently have about twenty phone SCCPAnd one SIP phoneI have an ISR2901, CME 10.5. , and I have set up an NTP All SCCP phones have the correct date format, and the correct time.My SIP Phone is registered, all work perfectly. The only concern...
jchevalon by Beginner
  • 658 Views
  • 7 replies
