new install of CER in Germany. First time. Germany has TWO emergency numbers that I am aware of 110 and 112. During installation of the CER VM, Asked what the emergency number is. In the US 911 used. However how do I put TWO numbers in the CER, ...
have a customer that we are going to be upgrading from 12.5 to 14.0 in the near term. They still have a bunch of 79xx phones that are not deprecated (yet) in 14.0. Just wondering if anyone has upgraded to 14.0 and the phone are still working or did y...
Help with Directory Number issue. We are experiencing a sporadic, yet consistent issue where directory numbers, when called, go straight to voicemail. DND is not active, the device is on-hook and the max call/busy trigger is set to 4/2 respectively. ...
Hi,We have Jabber 14.x installed on Windows 10. The cameras in use are Cisco Desk Cameras.The bug is replicated as follows:1. Have camera shutter closed before call2. Place a call via Jabber to another user3. After the call is up, open the shutter af...
HelloDo Cisco buy back unused and used IP phones?Model: 7861 / 8841 / 8831 / 8851
Hi, The ask from the customer is to configure CP-8845 video phone, on Panasonic (KS-NS 300 ). Can we achieve this? If yes, what is the procedure?
HelloStill a greenhorn at all this CUCM stuff. I am trying to add new phones to CUCM using the BAT configuration file. I found this YouTube video that's walking me through it: https://www.youtube.com/watch?v=pM6FVdTP-iI I am at the part (~2:04 into ...
We have bought 10 new Cisco wireless 840 phone and implemented them on the call manager.The phones are working fine.... Except.....We cant use the device in the Finesse as contact center device.When we select the device in Jabber is will not support ...
I would like to update the firmware of a Cisco ata 190. I don't have access to the CUCM so I want to do it from the GUI. I have downloaded the firmwares from the cisco website and when I go to the GUI of the ATA to insert the files, I get this error ...
hi all,i think there is an option to enable mail notification for sudden ip phone and DX70 goes unregister to take action.i mean i need to get mail of CEO`s ip phone was unregistered or his DX70 too.any guide for this?
Hi All,We are planning to upgrade our current CME 2900 series with a newer Cisco 8200 series. Additionally, we are also looking to replace our existing Cisco 8821 wireless phones with the newer Wireless Phone 840 and 860 models.I'm curious if the new...
Hi folksIs there a way to send the dtmf attached on the sip invite, or in somewhere in the signaling process on an enbloc string like 81 1111 1111 - 1234 (where 81 1111 1111 is our did, and the 1234 is the dtmf)?Thank you in advance.
Hi guys, we are actually struggling to integrate the new 840 phones in the Jabber client as controlled device. It worked with the 79xx, 88xx, all the used phones before, regardless if wired or wireless, the config on the callmanager seems to be corre...
Hi, experts, Trying to regenerate an expired certificate due to a late check while running cucm 11.5.Can I restart the service by regenerating the expired certificate?Or do I have to get a new one when it expires? Expired certificates are listed be...
How to use Webex Room Bar in CUCM 11.5 version?Hello, heroes of cisco I have a question. my customer company is using CUCM version 11.5 The customer wants to use the Cisco Room Bar without upgrading the version of CUCM. I know that the Room Bar templ...
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
2 | |
1 | |
1 |
